The link by the date is for Raspbian Wheezy, it should feasible to install Wheezy but will likely need to be updated on another RPi before RPi0 is supportedharwoodr wrote:link to HiPi http://raspberrypi.znix.com/hipidocs/contents.htm
If you build wheezy on another RPi then run sudo rpi-update it will boot OK on a Pi0.harwoodr wrote:Thanks i will try that see if wheezy will boot at all
