Having a frustrating time today, for some reason motion is fouled up. Has been fine for months, no issues.
Today, RPi Cam interface is working fine, if I use internal motion, all is well. Just external. I'd like to use motion for some quirks. Any ideas what to check? I click begin motion detection start and the display freezes, clock on cam output hangs and that's it, need to reboot. Have waited up to 5 mins. Have removed RPi cam with script ./remove.sh, deleted var/www/ then purge removed motion, cloned to RPi folder, new install and still same. On Wheezy. Considering chucking towel in, grabbing Jessie and trying that!
Any pointers welcomed, not sure what other details to give at this point
edit: If I visit
http://localhost/cam_pic.php as suggested in troubleshooter section, I get the picture of when I pressed start motion, no updates to it if this helps
edit 2: if I do ps -e | grep motion, I get: 11610 ? 00:00:00 motion
Not sure what the ? in that means
edit 3 (gah!) ok, I copied the motion.conf.1 file from RPi cam clone folder to /etc/motion/, rebooted and now it works. Am I missing something here, does the installer not do this? Anyways, lesson learned, all ok now
edit 4: I don't know hehe, motion runs but no setting on the edit motion settings page. ??
