Angel__
GPIO without keyboard (Python)
Sun Mar 13, 2016 12:51 am
I have succedded in reading and writing digital signals with import RPi.GPIO (in Python).
However I was forced to write in the terminal something like "sudo python example_gpio.py" in order to have root privilegies.
Assuming that I have to use the Raspberry pi without keyboard (and with a touch screen), how can I manage to do that?
How can I start this example from the desktop?
Thank you
qwertyuiopzxcvbnm
Re: GPIO without keyboard (Python)
Sun Mar 13, 2016 6:27 pm
If the raspberry pi has wifi, or you are able to connect wifi to it through USB, you could always SSH in from another computer and run the program from there. Raspberry Pi have a great tutorial on setting up SSH here:
https://www.raspberrypi.org/documentati ... ccess/ssh/
Angel__
Mon Mar 14, 2016 4:01 pm
Thank you very much for your contribution Mr qwert...
I am pursuing the Rpi 3 (I will have it in a week), which has wifi. The problem is that I want my RPi to work by itself, as a portable central unit that controls something; and forcing it to be connected to a laptop reduces the portability.
I have been told about other packages (gpio zero) that does not require root privilegies. I am afraid that I have to move to this package ( the one that I have used is RPio). It is not a major problem, but entails some hours.
Thank you again anyway.
elParaguayo
Mon Mar 14, 2016 4:18 pm
Am I missing something? Assuming your script runs without the need for any keyboard input, then why don't you just set the script to run as root at boot? There's no need to SSH in at that point. Plenty of threads in the forum about doing that.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Angel__
Tue Mar 15, 2016 11:21 am
Gracias elParaguayo
I have tried that too. But I had some problems because I also have graphical items (using Tkinter) and there appear some errors related to importing the library tkinter. In fact I do not know if the operating system is corrupted. I will install Jessie and hope to solve the problems.
Anyway, I will insist in launching during startup, although I would prefer that user can decide when to launch it from the desktop.
elParaguayo
Tue Mar 15, 2016 12:15 pm
Now I'm confused, if the user can decide to launch from the desktop, what's the input method that will be used? I thought the whole point was that you didn't have any input devices other than the GPIO.
I'd be amazed if there isn't another thread in this forum about getting Tkinter scripts to launch at boot.
Angel__
Tue Mar 15, 2016 10:20 pm
Just for your curiosity, I am using a touch screen to introduce some basic options and to represent evolution of digitial inputs.
I am new in Raspberry and in Linux and I am afraid that I might have modified some files.
Since I can see that there is not a straightforward line of actuation, I am decided to install Jessie and begin to explore in forums for these issues.
tom.slick
Wed Mar 16, 2016 12:10 am
Create a bash script that launches your python script.
#!/bin/bash
Clicking on the bash script will launch the python script with sudo
as long as you don't need to type in a password it will work.
Thu Mar 17, 2016 6:47 pm
tom.slick wrote:Create a bash script that launches your python script.
#!/bin/bash
Why not add a sensible shebang line to your python program and avoid needing yet another bash task running to launch your python task?
#!/usr/bin/sudo /usr/bin/python
This is a doctor free zone.
HankB
Thu Mar 17, 2016 8:07 pm
The RPi.GPIO module does not require root to run. The user it runs as must be in the gpio group (in /etc/group)
[email protected]:~ $ grep gpio /etc/group
gpio:x:997:pi,hbarta
Pi is there by default and I added myself using 'sudo' and my favorite text editor.
Ordinarily I try really hard not to run stuff as root, but if this is an 'appliance' with no network connection there seems to be little risk.
I found instructions here for one way to autostart a GUI program on a Raspberry Pi: http://raspberrypi.stackexchange.com/qu ... ut-desktop I'm sure there are others.
HTH,
hank
Angel__
Sun Mar 20, 2016 11:28 am
Thank you very much Dougie and Tom.
Your solutions solved my problem at the very first attempt.
With regard to Hank's solution, I am new in Linux and I do not exactly how to include pi in the gpio's group (although it does not seem difficult). Since the problem is solved,I have not tried this solution. I apologize for, despite polite Hank's suggestion, not trying it.
Additional note:
I also had another problem related to importing Tkinter
At first I wrote "import tkinter" (or "from tkinter import *") with low cases, which gave me no error if I ran from the idle editor.
However, if I tried to launch the script in the way you have suggested I got the error "ImportError: No module named 'Tkinter' ".
I think that it is an error related to the python version.
Changing to Tkinter (with first upper case), everything now is fine: I can launch the script from the desktop with graphical interface and I can access the gpio.
Angel__
Sun Mar 20, 2016 11:30 am
I forgot. Thank you very much Hank aswell
Return to “Python”
