Laurens-wuyts
RPi3 a2db
Tue Mar 08, 2016 2:26 pm
Hello everyone
Is it possible to use a2db Bluetooth headphones with the build in Bluetooth of the raspberry pi 3?
i can pair using bluetoothctl, but I don't come further.
I have tried many solutions online, but none worked. :(
Thanks in advance
Laurens
Douglas6
Re: RPi3 a2db
Tue Mar 08, 2016 4:29 pm
I have not seen a guide for A2DP on Jessie. I'm sure it's not hard to do. You will need to install PulseAudio and some Bluetooth modules, and configure a few things. I may write it up soon, but I'm waiting on my Pi3. This thread may help: https://github.com/ev3dev/ev3dev/issues/198
Laurens-wuyts
Re: RPi3 a2db
Tue Mar 08, 2016 9:44 pm
Thanks for the answer and the link.
I'm going to try it asap and let you know how it goes. ;)
Maybe I'll write a guide myself. :)
Laurens
Douglas6
Re: RPi3 a2db
Tue Mar 08, 2016 10:42 pm
Yay! I'd like to see it with PulseAudio running in 'system mode'; I think that thread discusses it.
0tting
Re: RPi3 a2db
Tue Mar 08, 2016 10:59 pm
I just managed to get BT audio up and running on the RPi3 using this guide: https://github.com/davidedg/NAS-mod-con ... Audio5.txt
But what I can't figure out is how to auto connect to the bluetooth speaker after a reboot.
Laurens-wuyts
Re: RPi3 a2db
Wed Mar 09, 2016 8:39 am
0tting wrote:I just managed to get BT audio up and running on the RPi3 using this guide: https://github.com/davidedg/NAS-mod-con ... Audio5.txt
Thanks for the link. I followed it and it worked like a charm! ;)
Laurens
Douglas6
Re: RPi3 a2db
Wed Mar 09, 2016 2:08 pm
0tting wrote:But what I can't figure out is how to auto connect to the bluetooth speaker after a reboot.
Try adding this at the end of /etc/pulse/system.pa
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
Also, I find a resample method of 'speex-fixed-3' gives noticeably better sound quality than 'trivial', without much more CPU.
PreSpawn
Re: RPi3 a2db
Fri Mar 11, 2016 10:06 pm
Hey! i made myself a car hands free bluetooth device. When starting the car my rpi boots up and connects my phone. I achieved this with a simple script:
#!/bin/bash
sleep 30
echo -e 'power on \nconnect XX:XX:XX:XX:XX:XX\nquit' | bluetoothctl
AND added it to crontab:
@reboot sh ~/blueconnect.sh
*/5 * * * * sh ~/blueconnect.sh
now at boot up my phone is autmatically connected, and if i go out of range and come back, it will soon reconnect.
question, new here: is this enough elaboration for this forum or should i add a "nano ~/xxx", "crontab -e" etc. ?
Return to “Raspbian”
