i ran "ifconfig -a | dmesg"
[email protected]:~ $ ifconfig -a | dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.17-v7+ (
[email protected]) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #838 SMP Tue Feb 9 13:15:09 GMT 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80860f00, node_mem_map b9bb4000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 12 pages/cpu @bafb1000 s20416 r8192 d20544 u49152
[ 0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2709.boardrev=0xa02082 bcm2709.serial=0xb814297c smsc95xx.macaddr=B8:27:EB:14:29:7C bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939508K/966656K available (5944K kernel code, 534K rwdata, 1660K rodata, 440K init, 757K bss, 18956K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807753c4 (7605 kB)
.init : 0x80776000 - 0x807e4000 ( 440 kB)
.data : 0x807e4000 - 0x80869a68 ( 535 kB)
.bss : 0x8086c000 - 0x8092975c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000027] Switching to timer-based delay loop, resolution 52ns
[ 0.000249] Console: colour dummy device 80x30
[ 0.001309] console [tty1] enabled
[ 0.001359] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001427] pid_max: default: 32768 minimum: 301
[ 0.001737] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001780] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002788] Initializing cgroup subsys blkio
[ 0.002836] Initializing cgroup subsys memory
[ 0.002885] Initializing cgroup subsys devices
[ 0.002928] Initializing cgroup subsys freezer
[ 0.002978] Initializing cgroup subsys net_cls
[ 0.003047] CPU: Testing write buffer coherency: ok
[ 0.003136] ftrace: allocating 20289 entries in 60 pages
[ 0.050952] CPU0: update cpu_capacity 1024
[ 0.051015] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.051049] [bcm2709_smp_prepare_cpus] enter
[ 0.051210] Setting up static identity map for 0x8240 - 0x8274
[ 0.052985] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.053188] [bcm2709_secondary_init] enter cpu:1
[ 0.053232] CPU1: update cpu_capacity 1024
[ 0.053239] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.053627] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.053795] [bcm2709_secondary_init] enter cpu:2
[ 0.053817] CPU2: update cpu_capacity 1024
[ 0.053823] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.054192] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.054323] [bcm2709_secondary_init] enter cpu:3
[ 0.054344] CPU3: update cpu_capacity 1024
[ 0.054350] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.054414] Brought up 4 CPUs
[ 0.054513] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.054542] CPU: All CPU(s) started in HYP mode.
[ 0.054568] CPU: Virtualization extensions available.
[ 0.055281] devtmpfs: initialized
[ 0.073673] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.073950] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.074809] pinctrl core: initialized pinctrl subsystem
[ 0.075390] NET: Registered protocol family 16
[ 0.080526] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081537] bcm2709.uart_clock = 48000000
[ 0.085254] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.085303] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.085473] Serial: AMBA PL011 UART driver
[ 0.085623] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.588222] console [ttyAMA0] enabled
[ 0.592308] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.664593] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.673265] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.681535] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.688434] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.694222] SCSI subsystem initialized
[ 0.698163] usbcore: registered new interface driver usbfs
[ 0.703757] usbcore: registered new interface driver hub
[ 0.709176] usbcore: registered new device driver usb
[ 0.714758] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-01 17:51
[ 0.750043] Switched to clocksource arch_sys_counter
[ 0.794403] FS-Cache: Loaded
[ 0.797547] CacheFiles: Loaded
[ 0.808758] NET: Registered protocol family 2
[ 0.814082] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.821278] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.827917] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.834407] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.840402] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.847079] NET: Registered protocol family 1
[ 0.851751] RPC: Registered named UNIX socket transport module.
[ 0.857691] RPC: Registered udp transport module.
[ 0.862429] RPC: Registered tcp transport module.
[ 0.867150] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.874593] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.883792] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.903336] VFS: Disk quotas dquot_6.6.0
[ 0.907576] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.916716] FS-Cache: Netfs 'nfs' registered for caching
[ 0.922980] NFS: Registering the id_resolver key type
[ 0.928088] Key type id_resolver registered
[ 0.932325] Key type id_legacy registered
[ 0.938335] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.945911] io scheduler noop registered
[ 0.949860] io scheduler deadline registered (default)
[ 0.955300] io scheduler cfq registered
[ 0.961107] BCM2708FB: allocated DMA memory fa800000
[ 0.966106] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.991584] Console: switching to colour frame buffer device 160x64
[ 1.009838] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 1.017249] vc-cma: Videocore CMA driver
[ 1.021255] vc-cma: vc_cma_base = 0x00000000
[ 1.026031] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.031522] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.037165] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.056953] brd: module loaded
[ 1.067097] loop: module loaded
[ 1.071170] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[ 1.079649] Loading iSCSI transport class v2.0-870.
[ 1.085298] usbcore: registered new interface driver smsc95xx
[ 1.091207] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.297325] Core Release: 2.80a
[ 1.300567] Setting default values for core params
[ 1.305459] Finished setting default values for core params
[ 1.511467] Using Buffer DMA mode
[ 1.514838] Periodic Transfer Interrupt Enhancement - disabled
[ 1.520772] Multiprocessor Interrupt Enhancement - disabled
[ 1.526428] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.530873] Dedicated Tx FIFOs mode
[ 1.534675] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[ 1.544685] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.561640] dwc_otg: Microframe scheduler enabled
[ 1.561692] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803fcf78
[ 1.567708] WARN::hcd_init_fiq:413: FIQ ASM at 0x803fd2d4 length 36
[ 1.574073] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89a000
[ 1.580193] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.589362] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.600937] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 1.610780] Init: Port Power? op_state=1
[ 1.618870] Init: Power Port (0)
[ 1.626414] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.637399] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.648820] usb usb1: Product: DWC OTG Controller
[ 1.657676] usb usb1: Manufacturer: Linux 4.1.17-v7+ dwc_otg_hcd
[ 1.667836] usb usb1: SerialNumber: 3f980000.usb
[ 1.677263] hub 1-0:1.0: USB hub found
[ 1.685208] hub 1-0:1.0: 1 port detected
[ 1.693653] dwc_otg: FIQ enabled
[ 1.693663] dwc_otg: NAK holdoff enabled
[ 1.693672] dwc_otg: FIQ split-transaction FSM enabled
[ 1.693703] Module dwc_common_port init
[ 1.693956] usbcore: registered new interface driver usb-storage
[ 1.704351] mousedev: PS/2 mouse device common for all mice
[ 1.714750] bcm2835-cpufreq: min=600000 max=1200000
[ 1.724046] sdhci: Secure Digital Host Controller Interface driver
[ 1.734376] sdhci: Copyright(c) Pierre Ossman
[ 1.743172] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.753123] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 1.800285] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.813578] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.825944] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.835705] usbcore: registered new interface driver usbhid
[ 1.846408] usbhid: USB HID core driver
[ 1.855741] Initializing XFRM netlink socket
[ 1.864137] NET: Registered protocol family 17
[ 1.873804] Key type dns_resolver registered
[ 1.882634] Registering SWP/SWPB emulation handler
[ 1.890147] Indeed it is in host mode hprt0 = 00021501
[ 1.904529] registered taskstats version 1
[ 1.912896] vc-sm: Videocore shared memory driver
[ 1.921664] [vc_sm_connected_init]: start
[ 1.930157] [vc_sm_connected_init]: end - returning 0
[ 1.940388] Waiting for root device /dev/mmcblk0p2...
[ 1.956338] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.970611] mmc0: new high speed SDHC card at address 0001
[ 1.980710] mmcblk0: mmc0:0001 0000 14.8 GiB
[ 1.990620] mmcblk0: p1 p2
[ 2.052367] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.063843] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.070081] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.075170] Indeed it is in host mode hprt0 = 00001101
[ 2.270380] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.281303] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.293922] hub 1-1:1.0: USB hub found
[ 2.302551] hub 1-1:1.0: 5 ports detected
[ 2.529728] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 2.540189] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[ 2.549515] EXT4-fs (mmcblk0p2): recovery complete
[ 2.578115] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.590391] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.601146] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.613447] devtmpfs: mounted
[ 2.621008] Freeing unused kernel memory: 440K (80776000 - 807e4000)
[ 2.710355] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.721477] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.735698] smsc95xx v1.0.4
[ 2.803317] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:14:29:7c
[ 2.910090] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 2.929377] random: systemd urandom read with 80 bits of entropy available
[ 2.944587] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.962840] systemd[1]: Detected architecture 'arm'.
[ 3.020368] usb 1-1.3: New USB device found, idVendor=04b4, idProduct=6560
[ 3.031890] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.044539] hub 1-1.3:1.0: USB hub found
[ 3.053144] hub 1-1.3:1.0: 4 ports detected
[ 3.124877] NET: Registered protocol family 10
[ 3.135324] systemd[1]: Inserted module 'ipv6'
[ 3.147779] systemd[1]: Set hostname to <raspberrypi>.
[ 3.228786] uart-pl011 3f201000.uart: no DMA platform data
[ 3.340139] usb 1-1.3.1: new low-speed USB device number 5 using dwc_otg
[ 3.569369] usb 1-1.3.1: New USB device found, idVendor=413c, idProduct=2107
[ 3.581096] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.589697] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.590175] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.590257] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 3.628136] usb 1-1.3.1: Product: Dell USB Entry Keyboard
[ 3.628148] usb 1-1.3.1: Manufacturer: Dell
[ 3.652378] systemd[1]: Starting Remote File Systems (Pre).
[ 3.668136] systemd[1]: Reached target Remote File Systems (Pre).
[ 3.679049] systemd[1]: Starting Encrypted Volumes.
[ 3.694102] systemd[1]: Reached target Encrypted Volumes.
[ 3.704366] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.723963] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.738416] systemd[1]: Starting Swap.
[ 3.752760] systemd[1]: Reached target Swap.
[ 3.761943] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 3.778468] systemd[1]: Starting Root Slice.
[ 3.793302] systemd[1]: Created slice Root Slice.
[ 3.802878] systemd[1]: Starting User and Session Slice.
[ 3.818851] input: Dell Dell USB Entry Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:413C:2107.0001/input/input0
[ 3.818854] systemd[1]: Created slice User and Session Slice.
[ 3.818954] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.864524] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.875397] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.893058] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.905193] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.910331] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-3f980000.usb-1.3.1/input0
[ 3.940469] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.951801] systemd[1]: Starting udev Control Socket.
[ 3.968039] systemd[1]: Listening on udev Control Socket.
[ 3.978692] systemd[1]: Starting udev Kernel Socket.
[ 3.994509] systemd[1]: Listening on udev Kernel Socket.
[ 4.004868] systemd[1]: Starting Journal Socket.
[ 4.010082] usb 1-1.3.2: new low-speed USB device number 6 using dwc_otg
[ 4.031709] systemd[1]: Listening on Journal Socket.
[ 4.041734] systemd[1]: Starting System Slice.
[ 4.056840] systemd[1]: Created slice System Slice.
[ 4.066688] systemd[1]: Starting File System Check on Root Device...
[ 4.085812] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 4.103161] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.114644] systemd[1]: Starting system-autologin.slice.
[ 4.131947] systemd[1]: Created slice system-autologin.slice.
[ 4.142944] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 4.160215] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.171840] systemd[1]: Starting Increase datagram queue length...
[ 4.183426] usb 1-1.3.2: New USB device found, idVendor=413c, idProduct=3010
[ 4.195560] usb 1-1.3.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.216944] systemd[1]: Starting Restore / save the current clock...
[ 4.217520] input: HID 413c:3010 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:413C:3010.0002/input/input1
[ 4.219423] hid-generic 0003:413C:3010.0002: input,hidraw1: USB HID v1.00 Mouse [HID 413c:3010] on usb-3f980000.usb-1.3.2/input0
[ 4.279184] systemd[1]: Starting udev Coldplug all Devices...
[ 4.299112] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.320125] systemd[1]: Mounting Debug File System...
[ 4.372661] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.384550] systemd[1]: Mounted Huge Pages File System.
[ 4.413942] systemd[1]: Starting Load Kernel Modules...
[ 4.437529] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.461497] systemd[1]: Starting Slices.
[ 4.477346] systemd[1]: Reached target Slices.
[ 4.495420] systemd[1]: Mounted Debug File System.
[ 4.511610] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.527083] fuse init (API version 7.23)
[ 4.539754] systemd[1]: Started Increase datagram queue length.
[ 4.554902] i2c /dev entries driver
[ 4.571132] systemd[1]: Started File System Check on Root Device.
[ 4.588956] systemd[1]: Started Restore / save the current clock.
[ 4.610802] systemd[1]: Started Load Kernel Modules.
[ 4.627921] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.645445] systemd[1]: Time has been changed
[ 4.662589] systemd[1]: Started udev Coldplug all Devices.
[ 4.821642] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.842002] systemd[1]: Mounting Configuration File System...
[ 4.861577] systemd[1]: Starting Apply Kernel Variables...
[ 4.881745] systemd[1]: Mounting FUSE Control File System...
[ 4.901580] systemd[1]: Starting Syslog Socket.
[ 4.918462] systemd[1]: Listening on Syslog Socket.
[ 4.918643] systemd[1]: Starting Journal Service...
[ 4.933889] systemd[1]: Started Journal Service.
[ 5.066909] systemd-udevd[108]: starting version 215
[ 5.671672] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.708524] random: nonblocking pool is initialized
[ 5.709821] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.401998] systemd-journald[106]: Received request to flush runtime journal from PID 1
[ 6.664923] bcm2835-rng 3f104000.rng: hwrng registered
[ 7.737291] cfg80211: Calling CRDA to update world regulatory domain
[ 7.824469] Adding 102396k swap on /var/swap. Priority:-1 extents:5 across:339968k SSFS
[ 7.971679] cfg80211: World regulatory domain updated:
[ 7.971701] cfg80211: DFS Master region: unset
[ 7.971712] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.971727] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.971740] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.971752] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.971766] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.971781] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.971794] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.971806] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.971818] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 8.472499] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 8.472940] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
