Sheddyian
Wheezy apt-get update errors (collabora)
Wed Mar 02, 2016 2:48 pm
I've been updating my various Pis today, I have one that runs a little webserver and is still running under Wheezy.
I'm getting errors when running
sudo apt-get update && sudo apt-get upgrade
. Output is this :
[email protected] ~ $ sudo apt-get update && sudo apt-get upgrade
Ign http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://repository.wolfram.com stable Release.gpg
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Err http://raspberrypi.collabora.com wheezy/rpi armhf Packages
  403  Forbidden
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en
Ign http://archive.raspberrypi.org wheezy/main Translation-en
Hit http://repository.wolfram.com stable/non-free armhf Packages
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en
Ign http://repository.wolfram.com stable/non-free Translation-en
W: Failed to fetch http://raspberrypi.collabora.com/dists/wheezy/rpi/binary-armhf/Packages  403  Forbidden
E: Some index files failed to download. They have been ignored, or old ones used instead.
I'm posting this to ask
a) is there anything I can do to circumvent it (I'm not knowingly using collabora) and
b) does someone at raspberrypi.org need to change some permissions somewhere? :D
Ian
ShiftPlusOne
Re: Wheezy apt-get update errors (collabora)
Wed Mar 02, 2016 3:10 pm
The collabora and wolfram repos haven't been needed for ages and are safe to remove. However, wheezy is unsupported.
Sheddyian
Wed Mar 02, 2016 3:48 pm
ShiftPlusOne wrote:The collabora and wolfram repos haven't been needed for ages and are safe to remove. However, wheezy is unsupported.
Ah, ok.
I went to /etc/apt/sources.list.d/
and commented out the entry in
collabora.list and
wolfram.list
and the problem has gone away.
I realise Wheezy isn't supported, just not got around to the upgrade yet as I was keen to avoid a fresh install
Ian
lsavidge
Thu Mar 03, 2016 11:37 am
I get this error as well. I have checked the sources.list and I have this in it:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
So, if wheezy is unsupported, what is supported now? Also, what should I be putting in the sources.list? As far as I understand the above URL redirects to a proper source.
Thanks,
ShiftPlusOne
Thu Mar 03, 2016 1:01 pm
lsavidge wrote:I get this error as well. I have checked the sources.list and I have this in it:
Thanks,
https://www.raspberrypi.org/blog/raspbi ... e-is-here/
plugwash
Thu Mar 03, 2016 1:12 pm
You also need to check the files in sources.list.d
lsavidge
Thu Mar 03, 2016 3:46 pm
Ok, the sources.list contains:
In sources.list.d there are 2 files:
collabora.list
raspbi.list
collabora.list contains:
deb http://raspberrypi.collabora.com wheezy rpi
raspi.list contains:
deb http://archive.raspberrypi.org/debian/ wheezy main
I can see Jessie is the latest. I'm running a Model B+ and I run it as a headless system. So, a couple of questions:
What do I need to do to the apt config to get rid of the 403 error?
Can I upgrade to jessie?
If so, how do I configure apt to upgrade to jessie?
Thanks,
ShiftPlusOne
Thu Mar 03, 2016 3:49 pm
Delete collabora.list
I believe the blog post I linked has upgrade instructions in it somewhere.
Edit: MAKE A BACKUP!
Thu Mar 03, 2016 3:50 pm
lsavidge wrote: Can I upgrade to jessie?
viewtopic.php?f=66&t=121880
Retired disgracefully.....
lsavidge
Thu Mar 03, 2016 4:13 pm
Was just reading this. I think I'll give it a whirl.
Cheers.
