AlwinHummels
My RPi 3 Gives wrong Info or Not?
Thu Mar 03, 2016 9:40 am
I have a strange issue, yesterday I've got my new RPi 3 and I Installed OpenElec 6.0.3. on it so far so good.
But when I'm Looking at the Hardware Information on Kodi I got This:
CPU: ARMv7 Procesor rev 4(v7.I)
BoGoMips: 76.00
Hardware: BCM2709
Revision: a02082
Serial:***************
CPU temperature: 82 C
CPU speed: 1200
CPU speed is right but CPU and Hardware NOT imo
This is what it should be:
Quad-core 1200MHz 64bit ARMv8-processor (BCM2837 chipset)
or am I wrong here?
Is this a OpenElec Issue or Do I have a wrong RPi3?
drgeoff
Re: My RPi 3 Gives wrong Info or Not?
Thu Mar 03, 2016 12:06 pm
If the onboard Wi-Fi is working then your RPi must have a BCM2837.
Thu Mar 03, 2016 12:14 pm
AlwinHummels wrote:I have a strange issue, yesterday I've got my new RPi 3 and I Installed OpenElec 6.0.3. on it so far so good.
BoGoMips: 76.00
Hardware: BCM2709
Revision: a02082
CPU speed: 1200
or am I wrong here?
I believe from other comments that is correct but confusing, but as long as you get Revision a02082 it is a RPi 3B
Retired disgracefully.....
RaTTuS
Thu Mar 03, 2016 12:23 pm
P2
 cat /proc/cpuinfo
processor       : 0
model name      : ARMv7 Processor rev 5 (v7l)
BogoMIPS        : 38.40
Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xc07
CPU revision    : 5
processor       : 1
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xc07
CPU revision    : 5
processor       : 2
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xc07
CPU revision    : 5
processor       : 3
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xc07
CPU revision    : 5
Hardware        : BCM2709
Revision        : a01041
pi 3
 cat /proc/cpuinfo
processor       : 0
model name      : ARMv7 Processor rev 4 (v7l)
BogoMIPS        : 76.80
Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 1
BogoMIPS        : 76.80
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 2
BogoMIPS        : 76.80
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 3
BogoMIPS        : 76.80
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
Hardware        : BCM2709
Revision        : a02082
Covfefe
IanH
Fri Mar 04, 2016 11:17 am
I've just dd'd 2016-02-09-raspbian-jessie-lite.img onto a MicroSD, and my Pi 3 gives:
[email protected]:~ $ cat /proc/cpuinfo
processor	: 0
BogoMIPS	: 38.40
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd03
CPU revision	: 4
processor	: 1
BogoMIPS	: 38.40
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd03
CPU revision	: 4
processor	: 2
BogoMIPS	: 38.40
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd03
CPU revision	: 4
processor	: 3
BogoMIPS	: 38.40
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd03
CPU revision	: 4
Hardware	: BCM2709
Revision	: a02082
Serial		: (mumble)
https://github.com/IanHarvey
joan
Fri Mar 04, 2016 11:23 am
There is an outside possibility that ARMv7 is reported as the powers that be realised that all the GPIO libraries might be broken if ARMv8 was reported.
lb
Fri Mar 04, 2016 11:56 am
It is perfectly normal that ARMv7 is reported. The CPU is capable of ARMv8, but Raspbian and all other distributions still use a 32 bit ARM kernel and userland. The CPU boots up in 32 bit compatibility mode.
IanH
Fri Mar 04, 2016 12:56 pm
I was just reporting that I got half the BogoMIPS that @RaTTuS had, which seems a little odd. Using lscpu I get a likely looking:
Architecture:          armv7l
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    4
Socket(s):             1
Model name:            ARMv7 Processor rev 4 (v7l)
CPU max MHz:           1200.0000
CPU min MHz:           600.0000
Re. ARMv8, I'm guessing it won't be possible to boot a 64-bit kernel (e.g. one of Linaro's) without support from Broadcom. The start.elf has to magically set up a load of memory data structures and ARM registers before it lets the ARM run kernel.img. I don't quite understand how it does this, but it'll be different between AArch32 and AArch64 ABI's. So almost certainly 64-bit support won't be possible without a new start.elf, which is proprietary BCM code.
wintermute83
Thu Jul 28, 2016 10:31 pm
Hi everyone,
I just got a pi 3, my goal is to have it running nextcloud and kodi.
I was checking temperatures and found something wierd. No matter how many firefox instances I open simultaneosly cpu freq never goes higher than 800. At idle it sits at 600mhz. Temps are around 57ºC at idle ( room temperature around 32 ).
This is the output of the comands that you suggested to check the cpu.
processor : 0
BogoMIPS : 51.20
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 51.20
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 51.20
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 51.20
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2709
Revision : a22082
Serial: xxxxxxxxxxxxx
CPU(s): 4
Socket(s): 1
CPU max MHz: 800.0000
Shouldn´t max CPU Mhz be 1200¿
Also I´m getting a maximun of 5Mbits on internet tests when my windows computer gets 15, so I´m worried that this pi 3 could be faulty.
Thanks in advance.
d3m0nkingx
Sun May 07, 2017 2:57 am
/proc/cpuinfo does not report the cores as ARM Cortex-A53 when running in 32 bit mode for two reasons:
The kernel is a V6 kernel; it is unaware of the V8 architecture so the CPU cores must present themselves in a way compatible with the V6 (Raspberry Pi 1)
Many drivers, libraries, services, utilities, and the kernel itself, use the information in /proc/cpuinfo to determine how to behave.
