real_ale
Raspberry Pi 3 Bluetooth Setup
Tue Mar 01, 2016 12:04 pm
How do i setup bluetooth on RPi 3.
Douglas6
Re: Raspberry Pi 3 Bluetooth Setup
Tue Mar 01, 2016 12:13 pm
sudo apt-get install pi-bluetooth
seems to be the best way
tonywaite
Tue Mar 01, 2016 3:24 pm
Just a quick 'hello world' that may be helpful!
- the first release of Raspbian Jessie for the Pi3 (26th Feb 2016) has pi-bluetooth pre-loaded and working 'out of the box';
- so if you type 'sudo service bluetooth status' and return, it should show 'active (running)';
- and if you have an adjacent *active* BLE device and type 'sudo hcitool lescan' and return ...
... you should see the callsign of the active BLE devices that it spotted;
jigneshkerai89
Tue Mar 01, 2016 5:23 pm
Followed the following:
sudo apt-get install bluetooth bluez blueman
sudo reboot
wait for reboot - The current raspian image does not have native support for the inbuilt bluetooth on the RPi 3. However if you run hciconfig - It will shows the BD address of the Pi. Run hcitool scan to get the BD address of the pairable devices in range.
Then follow:
sudo bluetoothctl
in the [bluetooth]# type agent on followed by default-agent
To pair type pair xx:xx:xx:xx:xx:xx where xx:xx:xx:xx:xx:xx is your BD address of the device you want to pair
Next type trust xx:xx:xx:xx:xx:xx
I am using bluetooth to connect to serial on python so I simply run sudo rfcomm bind 0 xx:xx:xx:xx:xx:xx via subprocess.call to created a serial port.
Make sure to run sudo rfcomm release 0 at the end of the script to release the serial port
HenkVB
Thu Mar 03, 2016 3:06 pm
Tried to execute your commands. After "sudo bluetoothctl" I get the command-line "[bluetooth]#"
So far so good, however at that point my usb-keyboard does'nt respond anymore. I can only get back with the command "Ctrl C" to the previous (standard) command-line.
Any suggestions on this?
Douglas6
Thu Mar 03, 2016 3:52 pm
That probably means that the Bluetooth daemon is not running (bluetoothctl is somewhat lacking in error handling). The daemon should start automatically after a reboot. Check the status from a command-line with
systemctl status bluetooth
or you can start it manually with
sudo systemctl start bluetooth
frankymusic
Thu Mar 03, 2016 4:42 pm
Hi all,
I received my Rpi 3 today, together with a BT keyboard "ultron"...
hcitool scan delivers the BT address of my keyboard (20:73:AB:00:0D:C3).
Until "agent on" and "default-agent" everything runs as expected, but...
... the "pair" (together with the address of that keyboard) always says:
20:73:AB:00:0D:C3 not available...
Does anybody get an idea?
Thanks in advance
Frank
HenkVB
Thu Mar 03, 2016 6:44 pm
Douglas6 wrote:That probably means that the Bluetooth daemon is not running (bluetoothctl is somewhat lacking in error handling). The daemon should start automatically after a reboot. Check the status from a command-line with
Thanks for the tip, works fine!
silenced
Fri Mar 04, 2016 7:46 pm
frankymusic wrote:Hi all,
Thanks in advance
Frank
Do try the following:
• sudo bluetoothctl
• agent on
• default-agent
• scan on
• pair xx:xx:xx:xx:xx (device id)
(if asked for a "PIN code" -> enter that "PIN code" on your bluetooth keyboard and press ENTER on the bluetooth keyboard)
• trust xx:xx:xx:xx:xx (if not asked for a pin code this may work too)
• connect xx:xx:xx:xx:xx
That's how I got my bluetooth keyboard with integrated mousepad running. (This one: http://www.amazon.de/gp/product/B00GHO9DJW (not available for sale anymore.))
ta2025
Fri Mar 04, 2016 8:15 pm
Any other ideas?
I have confirmed BT is running in my Pi3.
I have done a complete system update.
I did a firmware update.
I do an hcitools scan and I get an address of my BT speaker
I do exactly what Frank did and I get the same message.
Device A0:E9:D8:00:3B:98 is not available.
I followed up with:
and I have tried many times.
Douglas6
Fri Mar 04, 2016 8:50 pm
What type of device is it? Are you sure it's in discoverable mode when you try to pair with it?
ta2025
Tue Mar 08, 2016 4:55 pm
Douglas6 wrote:What type of device is it? Are you sure it's in discoverable mode when you try to pair with it?
Absolutely. Not my first rodeo with bluetooth devices :)
There seems to be be multiple generations of bluetooth stacks in the RP community in general. Some of the information is probably old.
Douglas6
Tue Mar 08, 2016 5:10 pm
Sorry, I'm straw-clutching here; no offense intended. I've not run into that error. Did you turn 'scan on' in bluetoothctl and wait for the device to appear?
hamdy.aea
Sat Mar 12, 2016 3:57 pm
I have paired my Raspberry Pi 3 to my Hardman Kardon bluetooth soundstick. The status is OK but i receive no sound on the speakers.
Hamdy Abou El Anein
Sat Mar 12, 2016 4:16 pm
hamdy.aea wrote:I have paired my Raspberry Pi 3 to my Hardman Kardon bluetooth soundstick. The status is OK but i receive no sound on the speakers.
https://wiki.debian.org/BluetoothUser/a2dp
adieu
hamdy.aea
Sat Mar 12, 2016 5:22 pm
Now I have another problem. The bluetooth adapter is not found.
Hamdy Abou El Anein
hamdy.aea
Sat Mar 12, 2016 5:30 pm
[email protected]:~# hcitool dev
Devices:
Hamdy Abou El Anein
pauly
Sat Mar 12, 2016 8:43 pm
I get "Device is not available: No such device" when I try to scan, what am I missing?
[email protected]:~ $ hcitool scan
[email protected]ecam:~ $ sudo bluetoothctl
[bluetooth]# agent on
Agent registered
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# list
[bluetooth]# devices
[bluetooth]# scan
Missing on/off argument
[bluetooth]# scan on
No default controller available
[bluetooth]# list
[bluetooth]# power on
[bluetooth]# quit
Agent unregistered
[email protected]:~ $ systemctl status bluetooth
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
   Active: active (running) since Sat 2016-03-12 20:35:25 UTC; 2min 46s ago
     Docs: man:bluetoothd(8)
 Main PID: 2689 (bluetoothd)
   Status: "Running"
   CGroup: /system.slice/bluetooth.service
           └─2689 /usr/lib/bluetooth/bluetoothd
[email protected]:~ $ sudo hcitool scan
[email protected]:~ $ hcitool dev
Devices:
Douglas6
Sat Mar 12, 2016 9:22 pm
Pauly: you are missing either the latest firmware on a Pi3, or a recognized Bluetooth dongle on a Pi1-2.
pauly
Sat Mar 12, 2016 9:26 pm
thanks, I have a pi3, thought everything was as up to date as could be. Have updated with rpi-update and still the same result. Anything else I can try?
Eaglepete
Sun Mar 13, 2016 12:03 pm
Hi All.
New member & also new to RPi :shock: so please be gentle with me :D
Just got RPi 3 for Kodi use :roll: managed to install from noobs without keyboard ( had to borrow a wired mouse but no keyboard ) Installed openelec , checked zeroconf , enabled Bluetooth etc ( as directed by yatse app ) but it won't find my mini keyboard ( the type you get with an m8 android box from eBay )
Have connected yatse ( eventually ) but really would like my keyboard !!!
I can't follow the prompts above as I don't know where or if I can put them in as it boots straight into Kodi ??
Any help would be much appreciated 8-)
phiv
Sun Mar 13, 2016 12:32 pm
I have the same problem as Pauly. Devices are not listed in
hcitool dev
, yet when I run
dmesg | grep Blue
shows the driver is loaded correctly (I think). Should I see more in this output?:
[ 1486.123815] Bluetooth: Core ver 2.21
[ 1486.123898] Bluetooth: HCI device and connection manager initialized
[ 1486.123916] Bluetooth: HCI socket layer initialized
[ 1486.123928] Bluetooth: L2CAP socket layer initialized
[ 1486.123957] Bluetooth: SCO socket layer initialized
[ 1486.164113] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1486.164133] Bluetooth: BNEP filters: protocol multicast
[ 1486.164152] Bluetooth: BNEP socket layer initialized
I run OSMC; I tried
sudo apt-get install rpi-update
in case the firmware is out of date but the rpi-update package is not in the repo. Manually getting and running rpi-update gives the following errors, so I did not proceed.
[email protected]:~$ sudo rpi-update
You appear to be trying to update firmware on an incompatible distribution. To force update, run the following:
sudo -E RPI_UPDATE_UNSUPPORTED=0 rpi-update
Any other ideas?
phiv
Sun Mar 13, 2016 12:49 pm
Ok, I risked it and updated firmware, which OSMC normally blocks until it is tested with the distribution. Same issue:
 *** Downloading specific firmware revision (this will take a few minutes)
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   168    0   168    0     0    902      0 --:--:-- --:--:-- --:--:--   908
100 49.3M  100 49.3M    0     0  1232k      0  0:00:40  0:00:40 --:--:--  130k
 *** Updating firmware
 *** Updating kernel modules
 *** depmod 4.1.19+
 *** depmod 4.1.19-v7+
 *** Updating VideoCore libraries
 *** Using HardFP libraries
 *** Updating SDK
 *** Running ldconfig
 *** Storing current firmware revision
 *** Deleting downloaded files
 *** Syncing changes to disk
 *** If no errors appeared, your firmware was successfully updated to 2a7eb4fc4cef07906c36e9adcf76f053daabe371
 *** A reboot is needed to activate the new firmware
[email protected]:~$ dmesg | grep Blue
[email protected]:~$ hcitool dev
Devices:
[email protected]:~$ systemctl status bluetooth
* bluetooth.service - Bluetooth service
  Drop-In: /etc/systemd/system/bluetooth.service.d
           `-local.conf
   Active: active (running) since Sat 2016-03-12 20:05:09 EST; 11h ago
 Main PID: 844 (bluetoothd)
   Status: "Running"
           `-844 /usr/lib/bluetooth/bluetoothd
phiv
Sun Mar 13, 2016 12:53 pm
The bluetoothctl shows no device even though the agent seems to work:
[bluetooth]# agent-on
Invalid command
Agent registered
[bluetooth]# list
[bluetooth]# list
[bluetooth]#
Douglas6
Sun Mar 13, 2016 2:35 pm
If you are running the latest Raspbian image, or using NOOBS 1.8, it will just work. If you are trying to upgrade a Wheezy image, see various threads on this forum. If you're using NOOBS < 1.8, you may be out of luck, and will have to flash a new card. If you are running OSMC, or other OS, it's best to ask on their forum.
