Arjan
RPi 2 : SPI : Not reliable? (SOLVED)
Sun Feb 28, 2016 9:13 am
Please see the two SPI timing diagrams for Model A+ and Model 2 with the same data.
The Model A+ gives a nice SPI stream, where the stream for Model 2 has some gaps in the stream.
The code below is running on bare-metal.
Any thoughts why there a gaps in the SPI stream for the Model 2?
Many thanks in advance,
Arjan
Model A+
Model 2
#define WS2812B_HIGH_CODE			0xF8		///< b11111000
#define WS2812B_LOW_CODE			0xC0		///< b11000000
#define WS2812B_SLOTS_PER_PIXEL		3			///< RGB
void ws2812b(const uint8_t *dmx_data) {
	int i;
	uint8_t mask = 0x80;
	uint16_t dmx_data_index = 0;
	bcm2835_spi_setClockDivider((uint16_t) ((uint32_t) BCM2835_CORE_CLK_HZ / (uint32_t) 6400000));
	bcm2835_spi_chipSelect(BCM2835_SPI_CS0);					// Just in case we have a multiplexer
	bcm2835_spi_setChipSelectPolarity(BCM2835_SPI_CS0 , LOW);	// Just in case we have a multiplexer
	// Clear TX and RX fifos
	BCM2835_PERI_SET_BITS(BCM2835_SPI0->CS, BCM2835_SPI0_CS_CLEAR, BCM2835_SPI0_CS_CLEAR);
	// Set TA = 1
	BCM2835_PERI_SET_BITS(BCM2835_SPI0->CS, BCM2835_SPI0_CS_TA, BCM2835_SPI0_CS_TA);
	for (i = 0; i < ((int)170 * (int)WS2812B_SLOTS_PER_PIXEL); i++) {
		mask = 0x80;
		while (mask != 0) {
			// Maybe wait for TXD
			while (!(BCM2835_SPI0->CS & BCM2835_SPI0_CS_TXD))
			if (dmx_data[dmx_data_index] & mask) {
				BCM2835_SPI0->FIFO = (uint32_t) WS2812B_HIGH_CODE;
			} else {
				BCM2835_SPI0->FIFO = (uint32_t) WS2812B_LOW_CODE;
			while ((BCM2835_SPI0->CS & BCM2835_SPI0_CS_RXD)) {
				(void) BCM2835_SPI0->FIFO;
			mask >>= 1;
		dmx_data_index++;
	// Wait for DONE to be set
	while (!(BCM2835_SPI0->CS & BCM2835_SPI0_CS_DONE)) {
	// Set TA = 0
	BCM2835_PERI_SET_BITS(BCM2835_SPI0->CS, 0, BCM2835_SPI0_CS_TA);
http://www.raspberrypi-dmx.org/
Open Source DMX/RDM/MIDI/OSC/Art-Net/sACN solutions
joan
Re: RPi 2 : SPI : Not reliable?
Sun Feb 28, 2016 9:39 am
I can't see any indication of a time scale. What bps?
Arjan
Sun Feb 28, 2016 9:55 am
Hi Joan,
I have set
and this results in a 6 MHz SPI clock.
The timing for each byte varies a lot on the Model 2. It is working fine on the Model A+.
Any pointers for what is happening here is much appreciated.
Thanks, Arjan
Arjan
Mon Mar 28, 2016 3:10 pm
With many thanks to rst (https://github.com/rsta2/circle) I have found the issue.
The CPU cores 1-3 are continuously reading a local mailbox register to get a start address. They are competing for bus time with core 0 what slows it down. And it breaks the SPI output.
At startup I am putting the unused cores to sleep https://github.com/vanvught/rpidmx512/b ... are.c#L230
The SPI output is fine now.
- Arjan
RPi Open Source DMX/RDM : http://www.raspberrypi-dmx.com/
