napajedlaci.cz
Where do I download wheezy?
Mon Feb 22, 2016 11:25 am
Where do I download wheezy? Thank you for the URL.
PeterO
Re: Where do I download wheezy?
Mon Feb 22, 2016 11:28 am
Wheezy is depreciated. It has even been removed from the download page.
You should be using Jessie now. https://www.raspberrypi.org/downloads/raspbian/
PeterO
RaTTuS
Contact: Twitter YouTube
Mon Feb 22, 2016 11:29 am
why not jessie
"embrace the new!"
Covfefe
Mon Feb 22, 2016 11:49 am
napajedlaci.cz wrote:Where do I download wheezy? Thank you for the URL.
Last release of Wheezy was July 2015 http://downloads.raspberrypi.org/raspbian/images
scruss
Mon May 23, 2016 1:38 am
Pronouns: he/him
Mon May 23, 2016 8:55 am
After THREE MONTHS the OP would of found out I put the wrong date in, anyway Wheezy is EOL !!
scruss
Mon May 23, 2016 5:35 pm
These answers stick around longer in search engines' memory than just the OP's query.
I can't see any reason for running Wheezy either, but people keep asking.
Pronouns: he/him
Mon May 23, 2016 7:51 pm
napajedlaci.cz never really needed wheezy for any particular reason.
Else he would have been back here in that last few months.
blaablaaguy
Mon May 23, 2016 8:16 pm
scruss wrote:These answers stick around longer in search engines' memory than just the OP's query.
Because Jessie broke 4gb sd cards. :(
This signature intentionally left blank.
kusti8
Mon May 23, 2016 9:23 pm
Which is why there is Jessie Lite.
blaablaaguy
Mon May 23, 2016 9:38 pm
Jessie Lites has no gui. Its only for the uber 31337
ShiftPlusOne
Mon May 23, 2016 9:48 pm
blaablaaguy wrote: Jessie Lites has no gui. Its only for the uber 31337
sudo apt-get install --no-install-recommends raspberrypi-ui-mods
shuckle
Tue May 24, 2016 7:05 am
My reason to still use wheezy is that streaming camera works easier than in jessie.
Tue May 24, 2016 9:32 am
shuckle,
It would be interesting to here what problems you have had with that on Jessie. It's next on my list of things to do.
Jednorozec
Tue May 24, 2016 10:29 am
Another reason to use Wheezy is that it doesn't use systemd(emonic). Also, the version of Nautilus is very much better than the one in Jessie.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
Tue May 24, 2016 10:41 am
Jednorozec,
I hear a lot of criticism of systemd. I have not looked into it enough to know how much of that is warranted. I however my experience with it on the desktop and the Pi has been as follows.
In general use one does not even know it's there. Seems to et everything working fine just like SysV Init did.
When do actually want get something running as a service at boot time a systemd .service file is short and sweet and sytemctl makes enable/disable, start/stop very easy. A lot nicer than hacking scripts.
Example: My propanel.service
[Service]
WorkingDirectory=/home/pi/propanel
ExecStart=/usr/local/bin/node --expose-gc /home/pi/propanel/assets/server-bundle.js
Restart=always
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=propanel
User=root
Group=root
Environment=NODE_ENV=production
[Install]
WantedBy=multi-user.target
Tue May 24, 2016 10:46 am
Jednorozec wrote:Another reason to use Wheezy is that it doesn't use systemd(emonic). Also, the version of Nautilus is very much better than the one in Jessie.
The issue with Wheezy is it does not natively boot on a RPi 3B or Zero, so you need an older RPi to update Wheezy first.
If SystemD is a perceived issue, then there is always Slackware.....
shuckle
Tue May 24, 2016 11:48 am
Heater wrote:shuckle,
You can see the issue here:
viewtopic.php?f=38&t=142279
I was able to get it to work by adding :demux=h264 as explained in
viewtopic.php?f=43&t=146597
But it still is not as reliable as with wheezy (where it has not yet ever failed).
shuckle
Tue May 24, 2016 11:52 am
Heater wrote:Jednorozec,
[Service]
Restart=always
User=root
Group=root
[Install]
There is a common problem mentioned several times in the forums that rc.local is not working with systemd as it used to work in wheezy. There is no quarantee that rc.local runs when the system is really up. I have had to add sleeps into rc.local so that my code works normally. Not a big deal, but nasty when you face it first time (and it slows down the jessie boot making it slower than wheezy)
6by9
Tue May 24, 2016 12:04 pm
I've commented on your first thread. If we can nail it down to a kernel/firmware vs VLC change, then it can be taken further.
RaTTuS
Tue May 24, 2016 12:09 pm
shuckle wrote:...
there are better ways of running things at start using systemd than using rc.lcoal
Covfefe
Tue May 24, 2016 12:23 pm
shuckle,
So the problem is that something changed. Admittedly that is a bit annoying when it happens before
one is aware that it might.
However one should not be using rc.local anyway it has been depreciated in Debian for a decade and a half. The recommended way is copy /etc/init.d/Skeleton to a new init script for whatever you want to happen while changing runlevels, then use insserv to enable it.
See article here:
http://bencane.com/2011/12/30/when-its- ... -rc-local/
And Debian docs here:
https://wiki.debian.org/LSBInitScripts/ ... yBasedBoot
shuckle
Tue May 24, 2016 12:43 pm
Heater,
I do not think it is obsolete:
http://forums.debian.net/viewtopic.php?f=5&t=124740
And it sure is simpler that building a real startup script.
Tue May 24, 2016 12:51 pm
No, not "obsolete", "deprecated".
It is provided for the use of the system administrator and compatibility reasons. As it says in the forum you linked to.
That implies to me that it is not the recommended thing to use.
mikerr
Tue May 24, 2016 2:30 pm
I took the last Raspbian Wheezy (2015-05-07) and updated it to run on pi zero & pi3 :
https://sourceforge.net/projects/raspbian-wheezy-pi/
1.3GB download, needs at least 4GB SD card
