I am having issues with my sense hat since upgrading to the new raspbian release, i re imaged ny sd card with the latest noobs incase something went wrong.
basically i can use all the sensor features but i cant make the led matrix work
any ideas
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Re: Sense Hat Issue
Could you please provide more information?
What output are you seeing, what are you trying to do and so on....
Re: Sense Hat Issue
Hi so the reading of the sensors deem to work
I'd I do a show_message it doesn't raise an error but nothing appears on matrix but it looks like the code is still running
Re: Sense Hat Issue
Hi There,
I have been doing some further testing today on the problem I mentioned here
I have written the following
from sense_hat import SenseHat
sense=SenseHat()
sense.set_pixel(1,1,255,,0)
then do a
sense.get_pixel(1,1)
the return value is (248,0,0)
I am assuming this means it has believed to have set pixel 1,1 with the right colour yet no colour is shown on the led matrix,
If I do a sense.temperature it returns the current temperature.
any ideas?
sense=SenseHat()
then do a
any ideas?
Re: Sense Hat Issue
Think I may have just seen an issue on the pcb fb1 looms like it has a missing component guessing it been knocked at some point
Can I just solder a link across this?
- Davespice
- Forum Moderator
- Contact: Twitter
Re: Sense Hat Issue
Hi there!lmoss30 wrote:from sense_hat import SenseHat
sense=SenseHat()
then do a
This is an expected behavior due to how the numbers are bit shifted to fit into the Linux frame buffer memory.
It's explained in the API documentation here: http://pythonhosted.org/sense-hat/api/#get_pixels
Re: Sense Hat Issue
thanks for the response,
could you comment on the missing component on my board, it has been knocked at some point, can i solder a link across?
- Davespice
- Forum Moderator
- Contact: Twitter
Re: Sense Hat Issue
Can you post a picture with a circle drawn around the area of the mission component?
Try and make sure it's in focus, blurry pictures won't help. Then I should be able to tell.
Re: Sense Hat Issue
at work at the moment so will later but it was FB1, location directly diagonal to the joysstick
- Davespice
- Forum Moderator
- Contact: Twitter
Re: Sense Hat Issue
Ah if it's FB1 in the top left corner, this is a ferrite bead that connects 5 volts to the board. You can replace this with a wire bridge.
Re: Sense Hat Issue
Thanks for confirming that, I no have a working sense hat again
What does the ferrite bead do?
- Davespice
- Forum Moderator
- Contact: Twitter
Re: Sense Hat Issue
It's just used to suppress or filter the amount of high frequency electromagnetic interference (EMI) coming from the 5 volt power supply you're using.
