edmundhei
Edimax EW-7811UTC WIFIAC NOT WORKING
Wed Feb 10, 2016 11:06 pm
I tired these method but it didn't work
viewtopic.php?p=514365#p514365
viewtopic.php?f=28&t=117596
the WiFi adapter is being pick up while i run lsusb command
but when i use lsmod, i can't see the driver running.
Is it because raspberry pi don't support WiFi ac?
MrEngman
Re: Edimax EW-7811UTC WIFIAC NOT WORKING
Thu Feb 11, 2016 7:48 am
The EW-7811UTC requires a driver installing. I have compiled drivers for it, for raspbian, and it works at 5GHz.
If you are using raspbian, wheezy or Jessie, post the output of command uname -a and I can give you the commands to download and install the version of the driver you need.
MrEngman
Roark
Fri Feb 12, 2016 5:50 pm
I'm having the same problem, my uname -a information is:
Linux raspberrypi 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/Linux
Thanks for the help, you are a gentleman and a scholar
MrEngman
Sat Feb 13, 2016 6:31 am
Roark wrote:I'm having the same problem, my uname -a information is:
Try this to download and install the driver
wget https://dl.dropboxusercontent.com/u/80256631/8812au-4.1.13-v7-826.tar.gz
tar xzf 8812au-4.1.13-v7-826.tar.gz
./install.sh
Reboot after installing the driver. Then you will need to configure your wifi to connect to your network.
MrEngman
Roark
Sat Feb 13, 2016 8:16 pm
Thanks for the help, it works great now
Roark
Sun Feb 21, 2016 4:55 pm
Sorry to bother you again, but I'm having the same problem after updating raspbian, I tried the previous driver and it didn't work, my uname -a information is now:
Linux raspberrypi 4.1.17-v7+ #838 SMP Tue Feb 9 13:15:09 GMT 2016 armv7l GNU/Linux
Thanks again for the help, and if you could tell me how to compile the driver myself so I don't run into this problem every time I update that would be great.
MrEngman
Sun Feb 21, 2016 6:10 pm
Roark wrote:Sorry to bother you again, but I'm having the same problem after updating raspbian, I tried the previous driver and it didn't work, my uname -a information is now:
You could try
wget https://dl.dropboxusercontent.com/u/80256631/8812au-4.1.17-v7-838.tar.gz
tar xzf 8812au-4.1.17-v7-838.tar.gz
./install.sh
MrEngman
vgonzal
Mon Feb 22, 2016 9:43 am
Hi.
I've problems with the
Linux raspberrypi 4.1.18+ #845 Thu Feb 18 19:37:13 GMT 2016 armv6l GNU/Linux
Which module can I use for this kernel?
Thanks in advance.
MrEngman
Mon Feb 22, 2016 2:39 pm
vgonzal wrote:Hi.
Thanks in advance.
Try this
wget https://dl.dropboxusercontent.com/u/80256631/8812au-4.1.18-845.tar.gz
tar xzf 8812au-4.1.18-845.tar.gz
./install.sh
As I am away from home for a few weeks I do not have an 8812au wifi adapter to test the driver with, but I think it should be OK.
MrEngman
cowboyrx
Edimax EW-7822UAC WIFIAC NOT WORKING
Mon Feb 22, 2016 11:25 pm
Downloaded, installed and rebooted the following as per my kernel version on my rpi2 device running rasbian:
https://dl.dropboxusercontent.com/u/802 ... 845.tar.gz
insmod 8812au.ko loads the module, but adapter not working still
lsusb always show the adapter, but not recognized via iwconfig and no blue activity light on the adapter either
MrEngman
Re: Edimax EW-7822UAC WIFIAC NOT WORKING
Tue Feb 23, 2016 1:34 am
cowboyrx wrote:Downloaded, installed and rebooted the following as per my kernel version on my rpi2 device running rasbian:
Did you run commands
wget https://dl.dropboxusercontent.com/u/80256631/8812au-4.1.18-v7-845.tar.gz
tar xzf 8812au-4.1.18-v7-845.tar.gz
./install.sh
to install the driver? You need to run command ./install.sh to install the driver correctly.
Please reboot and then post the output of commands
uname -a
lsusb
lsmod
MrEngman
cowboyrx
Tue Feb 23, 2016 2:29 am
My wifi device is Edimax 7822 UAC
I used the steps you mentioned. Here is the outputs as requested
[email protected] ~ $ uname -a
Linux raspberrypi 4.1.18-v7+ #845 SMP Thu Feb 18 19:45:28 GMT 2016 armv7l GNU/Linux
[email protected] ~ $ lsusb
lBus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 004: ID 7392:a822 Edimax Technology Co., Ltd
[email protected] ~ $ lsmod
Module Size Used by
arc4 1718 0
ecb 1963 0
md4 3375 0
md5 1783 1
hmac 2835 1
nls_utf8 1154 1
cifs 378619 2
snd_bcm2835 19802 3
snd_pcm 73442 1 snd_bcm2835
snd_seq 52642 0
snd_seq_device 3445 1 snd_seq
snd_timer 18792 2 snd_pcm,snd_seq
snd 50779 11 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
cfg80211 389253 0
rfkill 16036 2 cfg80211
bcm2835_gpiomem 2860 0
bcm2835_rng 1763 0
uio_pdrv_genirq 2944 0
uio 7753 1 uio_pdrv_genirq
I am now able to use this adapter, using this method:
insmod 8812au.ko
ifup wlan0
iwlist wlan0 scan
[email protected] ~ $ iwconfig
wlan0 IEEE 802.11AC ESSID:"XXXXX_5G" Nickname:"<[email protected]>"
Mode:Managed Frequency:5.745 GHz Access Point: 14:DD:A9:8A:94:9A
Bit Rate:867 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality=100/100 Signal level=100/100 Noise level=0/100
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
eth0 no wireless extensions.
Error during boot while trying to load module 8812au via /etc/modules:
"Exec format error"
Need help with following:
need the 8812au module to autoload/install at bootup. Added it to /etc/modules but get errors during boot.
vnzjunk
Wed Feb 24, 2016 2:16 am
Hi
I got my Pi today and am having fun setting it up except for the same wifi issue that the other fellow had/has. When I hover my mouse pointer it says eth0 connected
but also wlan0 not associated.
Here is the output of the commands. The 3rd line down from the top seems to indicate that the wifi dongle has been installed and is being seen by the pi.
Any help would be greatly appreciated. The lan connection is working fine and at least that is getting me going. But I am getting tired of tripping over the not long enough (barely) cable.
Thanks in advance
[email protected]:~ $ lsusb
Bus 001 Device 006: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 005: ID 046d:c51b Logitech, Inc. V220 Cordless Optical Mouse for Notebooks
Bus 001 Device 004: ID 413c:2005 Dell Computer Corp. RT7D50 Keyboard
[email protected]:~ $ lsmod
Module Size Used by
cfg80211 399468 0
rfkill 16799 2 cfg80211
bcm2835_rng 1824 0
bcm2835_gpiomem 3023 0
snd_bcm2835 19739 3
snd_pcm 75040 1 snd_bcm2835
snd_timer 19138 1 snd_pcm
snd 52636 9 snd_bcm2835,snd_timer,snd_pcm
8192cu 528485 0
uio_pdrv_genirq 2986 0
uio 8228 1 uio_pdrv_genirq
evdev 10552 4
i2c_dev 6108 0
fuse 82598 3
ipv6 343556 30
MrEngman
Wed Feb 24, 2016 7:59 am
vnzjunk wrote:Hi
Thanks in advance
Module Size Used by
cfg80211 399468 0
bcm2835_rng 1824 0
snd_bcm2835 19739 3
8192cu 528485 0
evdev 10552 4
i2c_dev 6108 0
fuse 82598 3
ipv6 343556 30
Take a look here https://www.raspberrypi.org/documentati ... /README.md
MrEngman
MrEngman
Wed Feb 24, 2016 8:44 am
cowboyrx wrote:My wifi device is Edimax 7822 UAC
Module Size Used by
arc4 1718 0
ecb 1963 0
md4 3375 0
md5 1783 1
hmac 2835 1
nls_utf8 1154 1
cifs 378619 2
snd_bcm2835 19802 3
snd_seq 52642 0
cfg80211 389253 0
bcm2835_rng 1763 0
insmod 8812au.ko
ifup wlan0
iwlist wlan0 scan
"Exec format error"
Unfortunately I don't have a 8812au wifi adapter with me in Dubai to test the driver but I've no reason to think there should be an issue with it as I can get the driver to install and load without problems.
I installed the module using the exact commands I mentioned in my previous post
./install.sh
To check the situation using file /etc/modules, I edited the /etc/modules file adding module name 8812au and rebooted and the module loads without any problems. However, you should not need to use file /etc/modules to get the module to load if you used the commands above. It should load automatically when you have your wifi adapter connected to the Pi.
I would suggest you download and install the driver again using the commands above, including the ./install.sh command, and reboot and then see what happens.
MrEngman
James62370
Sat Mar 26, 2016 3:46 am
Hello, I too am trying to get this adapter to work on a pi zero in order to run raspbian. Are the drivers specific to each device. Thank you in advance for your help.
MrEngman
Sat Mar 26, 2016 3:55 pm
James62370 wrote:Hello, I too am trying to get this adapter to work on a pi zero in order to run raspbian. Are the drivers specific to each device. Thank you in advance for your help.
Each driver will usually control a number of different wifi adapter based on the chip set the wifi adapter uses. The driver will also generally need to be compiled to be compatible with the kernel version you use, so if you change/update the kernel version you will need to update the driver.
I'm running an EW-7811UTC on a Pi 2 B with the 8812au driver I compile. I also have a Linksys WUSB6300 running on a Pi Zero with the same 8812au driver.
You will need to install the version of the driver compatible with the kernel version you are using as folllows.
Using my standard wifi driver naming format you can download and install the driver using commands
wget https://dl.dropboxusercontent.com/u/80256631/8812au-kernel-build.tar.gz
tar xzf 8812au-kernel-build.tar.gz
./install.sh
replacing kernel and build with the values from the command uname -a.
As an example for a Pi 2 B using raspbian 4.1.18-v7+ #845 use commands
./install.sh
For the Pi Zero and Pi A/A+/B/B+ the kernel version will not have -v7 like
./install.sh
Run command uname -a to find the kernel version and build your kernel version is and replace the kernel and build values in the commands above with the ones the uname -a command shows.
To configure the wifi to connect to your wireless network edit file /etc/wpa_supplicant/wpa_supplicant.conf like
update_config=1
network={
	ssid="network-name"
	psk="network-password"
I also have a script that will automatically check if there is a wifi driver available and will install it if there is. You can download and install it using commands
wget https://dl.dropboxusercontent.com/u/80256631/install-wifi.tar.gz
tar xzf install-wifi.tar.gz
Use command ./install-wifi -h to see the info on how to use it.
MrEngman
James62370
Sun Mar 27, 2016 3:46 am
Thank you very much for your detailed explanation. Unfortunately, I am rather new to the linux world. I will definitely give your suggestions a try. Your help is very much appreciated.
Update: I just wanted to update this post. In the past, I'd pretty much given up on trying to get wifi to work on my Pi2. With your help, I've been able to get this WiFi working with all of my Raspberry Pi's including my new Pi Zero. Thank you again for providing assistance and being selfless in helping others.
randomenthusiast
Fri May 06, 2016 7:34 pm
MrEngman,
From what I've seen in the forums, you've done quite a bit of work compiling the driver for the Edimax EW-7811UTC wireless adapter for various kernels and sharing it with others. I have not found it for 4.1.19v7-aufs armv7l GNU/Linux. The driver provided by the manufacturer seems to be written for an older kernel. I was wondering what the whole process you underwent to create these pre-compiled driver modules for other forum members. It would be great to have the module, so I could install it. But it would be better to be able to re-compile the driver every time the kernal is upgraded. I would be eternally grateful for a little how-to! Ie. give a man a fish vs teach a man to fish.
Thanks in advance!
njohnsn
Fri May 27, 2016 3:18 pm
Mr EngMan,
I just upgrade my Pi 3 to 4.4.11 and my driver for the 7811 will not load.
Where can I find the latest driver ?
Thanks.
MrEngman
Fri May 27, 2016 5:50 pm
njohnsn wrote:Mr EngMan,
Thanks.
Take a look at this post on how to determine the driver to download and install.
It also points to a script I have generated that will automatically determine if a driver is available and install it if there is.
MrEngman
njohnsn
Fri May 27, 2016 6:56 pm
Got it! Thanks so much!
-Neil
saintnick
Wed Jun 15, 2016 2:20 pm
Mr EngMan,
Do you have any suggestion why my 5GHz SSID from my ASUS RT68U(Merlin) won't show up for the 7811UTC in Openelec 6.0.3 on my RPi3?
It's strange because other 5GHz SSID's from neighbours and my chromecasts do show.
Connecting to my 2.4 GHz SSID from the same router works fine.
MrEngman
Wed Jun 15, 2016 4:39 pm
saintnick wrote:Mr EngMan,
I am just trying a 7811UTC on a Pi 3B and it has connected to my 5GHz AP, a Netgear WAC120, without problems.
The only thing I can think of at the moment is something to do with the set up of the RT68U on 5GHz. But what I have no idea.
MrEngman
saintnick
Wed Jun 15, 2016 10:44 pm
Solved.
I got it to work with this answer from Edimax support:
The EW-7811UTC cannot detect all frequencies. If your router is using a channel which is not supported the adapter will not detect it.
This adapter only supports channels that are within band 1 and band 2. You can try to set a fixed channel on your router, using the lower 5GHz channels.
Thank you for your effort.
I guess I didn't try/vary enough...
