Cannot upgrade RPi to JDK 1.8
Hello. I've been trying to troubleshoot this issue, but I haven't had much luck. When I run "sudo apt-get install oracle-java8-jdk" everything installs fine. However when I run "java -version" it's still coming up as version 1.6. How do I remedy this?
Re: Cannot upgrade RPi to JDK 1.8
Are you running the latest Jessie Raspbian? How and when did you install it?
My Jessie gives
What do you get from
That should show either jessie or wheezy
My Jessie gives
pi@raspberrypi ~ $ java -version
java version "1.8.0"
Java(TM) SE Runtime Environment (build 1.8.0-b132)
Java HotSpot(TM) Client VM (build 25.0-b70, mixed mode)
apt-cache policy
You can edit .bashrc in your home directory. Add two lines:
alias java=/path/to/your/java/binary
alias javac=/path/to/your/javac/binary
