Do you overclock your raspberry pi? If you do, what settings do you use, and how do you check to make sure your overclock is stable?
For me, I have a raspberry pi 2, and these are the settings I use in config.txt:
temp_limit=76 #I set this 9 degrees lower than the default value, just to be careful
arm_freq=1000 #100MHz faster than default
core_freq=350 #also 100MHz faster than default
avoid_pwm_pll=1
over_voltage=1 #my stability tests failed without this. I personally won't ever set this to be higher than 2
I also wrote another similar script that uses 'imagemagick' instead of lame. I ran four instances of these scripts to load each of the raspberry pi's cores, and left them running for about two hours (but with a desk fan blowing on the rasberry pi to prevent overheating)
I know it's probably not an optimal way to test for reliability, but it seems to have worked well enough.
I can post the scripts I made if anyone wants them.
Anyway, if you overclock, how do you personally test for stability?
