Just learned about these cool boards about a month ago.
Was easy to setup took less than 30 minutes to go from shipping box to a useable wifi enabled computer.
So far, all I got to say is 3,138mb for os? Reminds me of M$Windows bloat ware.
-------------------------------------------------------------------------------------------------------------------------------------jamesh wrote:That 3.8 also contains a lot of other stuff, not just the OS. Linux itself (the kernel) is about 3 MB or so IIRC.
Mathematica, Scratch, Sonic Pi, loads of other stuff make up the rest of the space etc.
Start with TinyCore LinuxLevel7 wrote:Just learned about these cool boards about a month ago.
You do not appear to have more than 4 USB Devices, surely having this is Peripheral Bloat...Level7 wrote:........and a 7 port powered hub.
It all fits really nicely on an 8GB SDCard (even without purging some of the junk). You'd have a hard job to find any version of Windows that fits in less than 8GB.Level7 wrote: So far, all I got to say is 3,138mb for os? Reminds me of M$Windows bloat ware.
______________________________________________________________________________________________fruitoftheloom wrote:You do not appear to have more than 4 USB Devices, surely having this is Peripheral Bloat...Level7 wrote:........and a 7 port powered hub.
The RPi B+ & 2B can deliver 1200ma total for USB if you use a good quality 5V 2A+ Power Supply
https://projects.drogon.net/testing-set ... berry-pi-b
https://www.raspberrypi.org/help/faqs/#power
+1fruitoftheloom wrote: Start with TinyCore Linux
Hardly. People were running Windows since before a gigabyte disk was imaginable. I once pruned all the cruft from Windows XP and got that down to about 250MB and it was far less for Windows 98. A default install of XP is around 1GB. As time has gone on, it does seems to me there has been a lot of bloat for not much gain, and Linux seems to have also followed that path.DougieLawson wrote:You'd have a hard job to find any version of Windows that fits in less than 8GB.
Best of luck of running Raspbian with port forwarding and the username|password is default.DougieLawson wrote:I meant supported versions of Windows, not their old unsupported and unsupportable versions.
Best of luck running a copy of XP on the public internet, it's about four minutes before that thing will be hacked to destruction.
Mac System6 also had a small footprint, but totally irrelevent to original mis-informed statement from the OPdrgeoff wrote:I had Windows, the very first version. IIRC it came on about 6 floppies. That was about the same time a hard disk was added to my office 286 PC. I had said that a 10 Mbyte drive would be enough but someone else decided we should have 20 Mbyte ones. (For those who were not even born at the time, those 'M's are not typos!)
I also had Windows 2. That too came on floppies. And Windows 3 and 3.1
I still have an unopened pack of 23 floppies for Windows 95.
One should be able to use 2 gig cards and have plenty of space free for adding whatever one might need. Perhaps not in the main download but in some sort of "Lite" version. 8gig cards might be cheap but 2gig ones can be free. If you're paying $5 for your board, that's a good price for the boot part.DougieLawson wrote:Level7 wrote:8GB SDCards are cheap. Now even the 16GB cards are also cheap.
Certainly this will give you the other side of the argument. Before people would stop complaining, Tiny Core was really a gem not even including things beyond enough to just boot and access their repo for things the support for formatting a disk. Now they have several versions which actually include support built right in for wifi.fruitoftheloom wrote:Start with TinyCore Linux
Nobody but the most insane, stupid, cretinous moron (or naïve newbie) would do such a thing.expandables wrote: Best of luck of running Raspbian with port forwarding and the username|password is default.
Less than one minute of destruction.
16GB Samsung branded cards cost £5 ($7.50).stderr wrote:One should be able to use 2 gig cards and have plenty of space free for adding whatever one might need. Perhaps not in the main download but in some sort of "Lite" version. 8gig cards might be cheap but 2gig ones can be free. If you're paying $5 for your board, that's a good price for the boot part.DougieLawson wrote:8GB SDCards are cheap. Now even the 16GB cards are also cheap.
It is often remarkable that the most basic command line program that one might try to use is *not* included in all that stuff. I don't mean in Raspbian specifically, this is true of Debian and Ubuntu and I suppose the others. They also like to cut things up into tiny pieces so you won't add more than you need which suggests they care about every byte but then they start out by including the kitchen sink even if your computer is going to be out in the garage.Level7 wrote:So far, all I got to say is 3,138mb for os? Reminds me of M$Windows bloat ware.
I thought that I'd given a reason for using 2 gig cards by pointing out that they can be free. If £5 doesn't matter to the user, then why are people so excited about the Pi Zero? Perhaps I'm missing something but I think that this excitement is proof that price is important.DougieLawson wrote:16GB Samsung branded cards cost £5 ($7.50).stderr wrote:One should be able to use 2 gig cards and have plenty of space free for adding whatever one might need. Perhaps not in the main download but in some sort of "Lite" version. 8gig cards might be cheap but 2gig ones can be free. If you're paying $5 for your board, that's a good price for the boot part.DougieLawson wrote:8GB SDCards are cheap. Now even the 16GB cards are also cheap.
http://www.ebuyer.com/704182-samsung-16 ... b-sp16d-eu
there's no possible reason left to use anything smaller.
Excuse me? You're complaining about the size of Raspbian (around 4GB) and you're planning to add 1400GB of disk space? I think your space priorities are a little out of line.Level7 wrote: I have 4 350GB USB hard drives and a printer to hook up yet. So I need the extra ports. I'm looking at using my Pi as a desktop.
I maintain several websites. Tho I have been watching the price of the larger USB HD's just haven't got down to where I want to lay out the cash for them yet.
He can't boot from those drives so it is a little unfair to compare them to boot drive bloat. But if 4gig, some of which is crap, is enough to make things work more easily for people, I guess that's a price to pay that could be worth it.W. H. Heydt wrote:Excuse me? You're complaining about the size of Raspbian (around 4GB) and you're planning to add 1400GB of disk space? I think your space priorities are a little out of line.Level7 wrote: I have 4 350GB USB hard drives
Not unfair at all.stderr wrote:He can't boot from those drives so it is a little unfair to compare them to boot drive bloat.W. H. Heydt wrote:Excuse me? You're complaining about the size of Raspbian (around 4GB) and you're planning to add 1400GB of disk space? I think your space priorities are a little out of line.Level7 wrote: I have 4 350GB USB hard drives
