The wait is over
2GB card should be fine.-rw-r--r-- 1 jah jah 1458569216 Nov 21 21:32 2015-11-21-raspbian-jessie-lite.img
-rw-r--r-- 1 jah jah 392967934 Nov 26 19:21 2015-11-21-raspbian-jessie-lite.zip
dpkg -l
ii acl 2.2.52-2 armhf Access control list utilities
ii adduser 3.113+nmu3 all add and remove users and groups
ii alsa-utils 1.0.28-1 armhf Utilities for configuring and using ALSA
ii apt 1.0.9.8.1 armhf commandline package manager
ii apt-utils 1.0.9.8.1 armhf package management related utility programs
ii aptitude 0.6.11-1 armhf terminal-based package manager
ii aptitude-common 0.6.11-1 all architecture independent files for the aptitude package m
ii avahi-daemon 0.6.31-5 armhf Avahi mDNS/DNS-SD daemon
ii base-files 8+rpi1 armhf Debian base system miscellaneous files
ii base-passwd 3.5.37 armhf Debian base system master password and group files
ii bash 4.3-11 armhf GNU Bourne Again SHell
ii bash-completion 1:2.1-4 all programmable completion for the bash shell
ii bind9-host 1:9.9.5.dfsg-9+deb armhf Version of 'host' bundled with BIND 9.X
ii binutils 2.25-5 armhf GNU assembler, linker and binary utilities
ii bsdmainutils 9.0.6 armhf collection of more utilities from FreeBSD
ii bsdutils 1:2.25.2-6 armhf basic utilities from 4.4BSD-Lite
ii build-essential 11.7 armhf Informational list of build-essential packages
ii bzip2 1.0.6-7 armhf high-quality block-sorting file compressor - utilities
ii ca-certificates 20141019 all Common CA certificates
ii cifs-utils 2:6.4-1 armhf Common Internet File System utilities
ii console-setup 1.123 all console font and keymap setup program
ii console-setup-linux 1.123 all Linux specific part of console-setup
ii coreutils 8.23-4 armhf GNU core utilities
ii cpio 2.11+dfsg-4.1 armhf GNU cpio -- a program to manage archives of files
ii cpp 4:4.9.2-2 armhf GNU C preprocessor (cpp)
ii cpp-4.9 4.9.2-10 armhf GNU C preprocessor
ii crda 3.13-1 armhf wireless Central Regulatory Domain Agent
ii cron 3.0pl1-127+deb8u1 armhf process scheduling daemon
ii curl 7.38.0-4+deb8u2 armhf command line tool for transferring data with URL syntax
ii dash 0.5.7-4 armhf POSIX-compliant shell
ii dbus 1.8.20-0+deb8u1 armhf simple interprocess messaging system (daemon and utilitie
ii dc 1.06.95-9 armhf GNU dc arbitrary precision reverse-polish calculator
ii debconf 1.5.56 all Debian configuration management system
ii debconf-i18n 1.5.56 all full internationalization support for debconf
ii debconf-utils 1.5.56 all debconf utilities
ii debianutils 4.4 armhf Miscellaneous utilities specific to Debian
ii dhcpcd5 6.7.1-1+rpi5 armhf DHCPv4, IPv6RA and DHCPv6 client with IPv4LL support
ii diffutils 1:3.3-1 armhf File comparison utilities
ii dmidecode 2.12-3 armhf SMBIOS/DMI table decoder
ii dmsetup 2:1.02.90-2.2 armhf Linux Kernel Device Mapper userspace library
ii dosfstools 3.0.27-1 armhf utilities for making and checking MS-DOS FAT filesystems
ii dphys-swapfile 20100506-1 all Autogenerate and use a swap file
ii dpkg 1.17.25 armhf Debian package management system
ii dpkg-dev 1.17.25 all Debian package development tools
ii e2fslibs:armhf 1.42.12-1.1 armhf ext2/ext3/ext4 file system libraries
ii e2fsprogs 1.42.12-1.1 armhf ext2/ext3/ext4 file system utilities
ii ed 1.10-2 armhf classic UNIX line editor
ii fake-hwclock 0.9 all Save/restore system clock on machines without working RTC
ii fakeroot 1.20.2-1 armhf tool for simulating superuser privileges
ii fbset 2.1-28 armhf framebuffer device maintenance program
ii file 1:5.22+15-2 armhf Determines file type using "magic" numbers
ii findutils 4.4.2-9 armhf utilities for finding files--find, xargs
ii firmware-atheros 0.43+rpi3 all Binary firmware for Atheros wireless cards
ii firmware-brcm80211 0.43+rpi3 all Binary firmware for Broadcom 802.11 wireless cards
ii firmware-libertas 0.43+rpi3 all Binary firmware for Marvell Libertas 8xxx wireless cards
ii firmware-ralink 0.43+rpi3 all Binary firmware for Ralink wireless cards
ii firmware-realtek 0.43+rpi3 all Binary firmware for Realtek wired and wireless network ad
ii g++ 4:4.9.2-2 armhf GNU C++ compiler
ii g++-4.9 4.9.2-10 armhf GNU C++ compiler
ii gcc 4:4.9.2-2 armhf GNU C compiler
ii gcc-4.6-base:armhf 4.6.4-5+rpi1 armhf GCC, the GNU Compiler Collection (base package)
ii gcc-4.7-base:armhf 4.7.3-11+rpi1 armhf GCC, the GNU Compiler Collection (base package)
ii gcc-4.8-base:armhf 4.8.4-1 armhf GCC, the GNU Compiler Collection (base package)
ii gcc-4.9 4.9.2-10 armhf GNU C compiler
ii gcc-4.9-base:armhf 4.9.2-10 armhf GCC, the GNU Compiler Collection (base package)
ii gdb 7.7.1+dfsg-5 armhf GNU Debugger
ii gdbserver 7.7.1+dfsg-5 armhf GNU Debugger (remote server)
ii geoip-database 20150317-1 all IP lookup command line tools that use the GeoIP library (
ii gnupg 1.4.18-7 armhf GNU privacy guard - a free PGP replacement
ii gpgv 1.4.18-7 armhf GNU privacy guard - signature verification tool
ii grep 2.20-4.1 armhf GNU grep, egrep and fgrep
ii groff-base 1.22.2-8 armhf GNU troff text-formatting system (base system components)
ii gzip 1.6-4 armhf GNU compression utilities
ii hardlink 0.3.0 armhf Hardlinks multiple copies of the same file
ii hostname 3.15 armhf utility to set/show the host name or domain name
ii ifupdown 0.7.53.1 armhf high level tools to configure network interfaces
ii info 5.2.0.dfsg.1-6 armhf Standalone GNU Info documentation browser
ii init 1.22 armhf System-V-like init utilities - metapackage
ii init-system-helpers 1.22 all helper tools for all init systems
ii initramfs-tools 0.120 all generic modular initramfs generator
ii initscripts 2.88dsf-59 armhf scripts for initializing and shutting down the system
ii insserv 1.14.0-5 armhf boot sequence organizer using LSB init.d script dependenc
ii install-info 5.2.0.dfsg.1-6 armhf Manage installed documentation in info format
ii iproute2 3.16.0-2 armhf networking and traffic control tools
ii iptables 1.4.21-2 armhf administration tools for packet filtering and NAT
ii iputils-ping 3:20121221-5 armhf Tools to test the reachability of network hosts
ii isc-dhcp-client 4.3.1-6 armhf DHCP client for automatically obtaining an IP address
ii isc-dhcp-common 4.3.1-6 armhf common files used by all of the isc-dhcp packages
ii iw 3.17-1 armhf tool for configuring Linux wireless devices
ii kbd 1.15.5-2 armhf Linux console font and keytable utilities
ii keyboard-configuration 1.123 all system-wide keyboard preferences
ii klibc-utils 2.0.4-2+rpi1 armhf small utilities built with klibc for early boot
ii kmod 18-3 armhf tools for managing Linux kernel modules
ii krb5-locales 1.12.1+dfsg-19+deb all Internationalization support for MIT Kerberos
ii less 458-3 armhf pager program similar to more
ii libacl1:armhf 2.2.52-2 armhf Access control list shared library
ii libalgorithm-c3-perl 0.09-1 all Perl module for merging hierarchies using the C3 algorith
ii libalgorithm-diff-perl 1.19.02-3 all module to find differences between files
ii libalgorithm-diff-xs-perl 0.04-3+b1 armhf module to find differences between files (XS accelerated)
ii libalgorithm-merge-perl 0.08-2 all Perl module for three-way merge of textual data
ii libapt-inst1.5:armhf 1.0.9.8.1 armhf deb package format runtime library
ii libapt-pkg4.12:armhf 1.0.9.8.1 armhf package management runtime library
ii libarchive-extract-perl 0.72-1 all generic archive extracting module
ii libasan1:armhf 4.9.2-10 armhf AddressSanitizer -- a fast memory error detector
ii libasound2:armhf 1.0.28-1+rpi1 armhf shared library for ALSA applications
ii libasound2-data 1.0.28-1+rpi1 all Configuration files and profiles for ALSA drivers
ii libatomic1:armhf 4.9.2-10 armhf support library providing __atomic built-in functions
ii libattr1:armhf 1:2.4.47-2 armhf Extended attribute shared library
ii libaudit-common 1:2.4-1 all Dynamic library for security auditing - common files
ii libaudit1:armhf 1:2.4-1 armhf Dynamic library for security auditing
ii libavahi-common-data:armhf 0.6.31-5 armhf Avahi common data files
ii libavahi-common3:armhf 0.6.31-5 armhf Avahi common library
ii libavahi-core7:armhf 0.6.31-5 armhf Avahi's embeddable mDNS/DNS-SD library
ii libbind9-90 1:9.9.5.dfsg-9+deb armhf BIND9 Shared Library used by BIND
ii libblkid1:armhf 2.25.2-6 armhf block device id library
ii libboost-iostreams1.49.0 1.49.0-4+b2 armhf Boost.Iostreams Library
ii libboost-iostreams1.50.0 1.50.0-1+b2 armhf Boost.Iostreams Library
ii libboost-iostreams1.53.0 1.53.0-6+b2 armhf Boost.Iostreams Library
ii libboost-iostreams1.54.0:a 1.54.0-5 armhf Boost.Iostreams Library
ii libboost-iostreams1.55.0:a 1.55.0+dfsg-3 armhf Boost.Iostreams Library
ii libbsd0:armhf 0.7.0-2 armhf utility functions from BSD systems - shared library
ii libbz2-1.0:armhf 1.0.6-7 armhf high-quality block-sorting file compressor library - runt
ii libc-bin 2.19-18+deb8u1 armhf GNU C Library: Binaries
ii libc-dev-bin 2.19-18+deb8u1 armhf GNU C Library: Development binaries
ii libc6:armhf 2.19-18+deb8u1 armhf GNU C Library: Shared libraries
ii libc6-dbg:armhf 2.19-18+deb8u1 armhf GNU C Library: detached debugging symbols
ii libc6-dev:armhf 2.19-18+deb8u1 armhf GNU C Library: Development Libraries and Header Files
ii libcap-ng0:armhf 0.7.4-2 armhf An alternate POSIX capabilities library
ii libcap2:armhf 1:2.24-8 armhf POSIX 1003.1e capabilities (library)
ii libcap2-bin 1:2.24-8 armhf POSIX 1003.1e capabilities (utilities)
ii libcgi-fast-perl 1:2.04-1 all CGI subclass for work with FCGI
ii libcgi-pm-perl 4.09-1 all module for Common Gateway Interface applications
ii libclass-c3-perl 0.26-1 all pragma for using the C3 method resolution order
ii libclass-c3-xs-perl 0.13-2+b1 armhf Perl module to accelerate Class::C3
ii libcloog-isl4:armhf 0.18.2-1 armhf Chunky Loop Generator (runtime library)
ii libcomerr2:armhf 1.42.12-1.1 armhf common error description library
ii libcpan-meta-perl 2.142690-1 all Perl module to access CPAN distributions metadata
ii libcryptsetup4:armhf 2:1.6.6-5 armhf disk encryption support - shared library
ii libcurl3:armhf 7.38.0-4+deb8u2 armhf easy-to-use client-side URL transfer library (OpenSSL fla
ii libcwidget3:armhf 0.5.17-2 armhf high-level terminal interface library for C++ (runtime fi
ii libdaemon0:armhf 0.14-6 armhf lightweight C library for daemons - runtime library
ii libdata-optlist-perl 0.109-1 all module to parse and validate simple name/value option pai
ii libdata-section-perl 0.200006-1 all module to read chunks of data from a module's DATA sectio
ii libdb5.3:armhf 5.3.28-9 armhf Berkeley v5.3 Database Libraries [runtime]
ii libdbus-1-3:armhf 1.8.20-0+deb8u1 armhf simple interprocess messaging system (library)
ii libdebconfclient0:armhf 0.192 armhf Debian Configuration Management System (C-implementation
ii libdevmapper1.02.1:armhf 2:1.02.90-2.2 armhf Linux Kernel Device Mapper userspace library
ii libdns-export100 1:9.9.5.dfsg-9+deb armhf Exported DNS Shared Library
ii libdns100 1:9.9.5.dfsg-9+deb armhf DNS Shared Library used by BIND
ii libdpkg-perl 1.17.25 all Dpkg perl modules
ii libdrm2:armhf 2.4.58-2 armhf Userspace interface to kernel DRM services -- runtime
ii libedit2:armhf 3.1-20140620-2 armhf BSD editline and history libraries
ii libestr0 0.1.9-1.1 armhf Helper functions for handling strings (lib)
ii libevent-2.0-5:armhf 2.0.21-stable-2 armhf Asynchronous event notification library
ii libexpat1:armhf 2.1.0-6+deb8u1 armhf XML parsing C library - runtime library
ii libfakeroot:armhf 1.20.2-1 armhf tool for simulating superuser privileges - shared librari
ii libfcgi-perl 0.77-1+b1 armhf helper module for FastCGI
ii libffi6:armhf 3.1-2 armhf Foreign Function Interface library runtime
ii libfile-fcntllock-perl 0.22-1+b1 armhf Perl module for file locking with fcntl(2)
ii libfreetype6:armhf 2.6-2rpi1rpi1g armhf FreeType 2 font engine, shared library files
ii libfreetype6-dev 2.6-2rpi1rpi1g armhf FreeType 2 font engine, development files
ii libgcc-4.9-dev:armhf 4.9.2-10 armhf GCC support library (development files)
ii libgcc1:armhf 1:4.9.2-10 armhf GCC support library
ii libgcrypt20:armhf 1.6.3-2 armhf LGPL Crypto library - runtime library
ii libgdbm3:armhf 1.8.3-13.1 armhf GNU dbm database routines (runtime version)
ii libgeoip1:armhf 1.6.2-4 armhf non-DNS IP-to-country resolver library
ii libglib2.0-0:armhf 2.42.1-1 armhf GLib library of C routines
ii libglib2.0-data 2.42.1-1 all Common files for GLib library
ii libgmp10:armhf 2:6.0.0+dfsg-6+rpi armhf Multiprecision arithmetic library
ii libgnutls-deb0-28:armhf 3.3.8-6+deb8u3 armhf GNU TLS library - main runtime library
ii libgnutls-openssl27:armhf 3.3.8-6+deb8u3 armhf GNU TLS library - OpenSSL wrapper
ii libgomp1:armhf 4.9.2-10 armhf GCC OpenMP (GOMP) support library
ii libgpg-error0:armhf 1.17-3 armhf library for common error values and messages in GnuPG com
ii libgssapi-krb5-2:armhf 1.12.1+dfsg-19+deb armhf MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii libhogweed2:armhf 2.7.1-5 armhf low level cryptographic library (public-key cryptos)
ii libicu52:armhf 52.1-8+deb8u3 armhf International Components for Unicode
ii libident 0.22-3 armhf simple RFC1413 client library - runtime
ii libidn11:armhf 1.29-1 armhf GNU Libidn library, implementation of IETF IDN specificat
ii libirs-export91 1:9.9.5.dfsg-9+deb armhf Exported IRS Shared Library
ii libisc-export95 1:9.9.5.dfsg-9+deb armhf Exported ISC Shared Library
ii libisc95 1:9.9.5.dfsg-9+deb armhf ISC Shared Library used by BIND
ii libisccc90 1:9.9.5.dfsg-9+deb armhf Command Channel Library used by BIND
ii libisccfg-export90 1:9.9.5.dfsg-9+deb armhf Exported ISC CFG Shared Library
ii libisccfg90 1:9.9.5.dfsg-9+deb armhf Config File Handling Library used by BIND
ii libisl10:armhf 0.12.2-2 armhf manipulating sets and relations of integer points bounded
ii libiw30:armhf 30~pre9-8 armhf Wireless tools - library
ii libjpeg62-turbo:armhf 1:1.3.1-12 armhf libjpeg-turbo JPEG runtime library
ii libjson-c2:armhf 0.11-4 armhf JSON manipulation library - shared library
ii libk5crypto3:armhf 1.12.1+dfsg-19+deb armhf MIT Kerberos runtime libraries - Crypto Library
ii libkeyutils1:armhf 1.5.9-5 armhf Linux Key Management Utilities (library)
ii libklibc 2.0.4-2+rpi1 armhf minimal libc subset for use with initramfs
ii libkmod2:armhf 18-3 armhf libkmod shared library
ii libkrb5-3:armhf 1.12.1+dfsg-19+deb armhf MIT Kerberos runtime libraries
ii libkrb5support0:armhf 1.12.1+dfsg-19+deb armhf MIT Kerberos runtime libraries - Support library
ii libldap-2.4-2:armhf 2.4.40+dfsg-1 armhf OpenLDAP libraries
ii liblocale-gettext-perl 1.05-8+b1 armhf module using libc functions for internationalization in P
ii liblog-message-perl 0.8-1 all powerful and flexible message logging mechanism
ii liblog-message-simple-perl 0.10-2 all simplified interface to Log::Message
ii liblogging-stdlog0:armhf 1.0.4-1 armhf easy to use and lightweight logging library
ii liblognorm1:armhf 1.0.1-3 armhf Log normalizing library
ii libluajit-5.1-common 2.0.3+dfsg-3 all Just in time compiler for Lua - common files
ii liblwres90 1:9.9.5.dfsg-9+deb armhf Lightweight Resolver Library used by BIND
ii liblzma5:armhf 5.1.1alpha+2012061 armhf XZ-format compression library
ii libmagic1:armhf 1:5.22+15-2 armhf File type determination library using "magic" numbers
ii libmodule-build-perl 0.421000-2 all framework for building and installing Perl modules
ii libmodule-pluggable-perl 5.1-1 all module for giving modules the ability to have plugins
ii libmodule-signature-perl 0.73-1+deb8u2 all module to manipulate CPAN SIGNATURE files
ii libmount1:armhf 2.25.2-6 armhf device mounting library
ii libmpc3:armhf 1.0.2-1 armhf multiple precision complex floating-point library
ii libmpfr4:armhf 3.1.2-2 armhf multiple precision floating-point computation
ii libmro-compat-perl 0.12-1 all mro::* interface compatibility for Perls < 5.9.5
ii libncurses5:armhf 5.9+20140913-1 armhf shared libraries for terminal handling
ii libncurses5-dev:armhf 5.9+20140913-1 armhf developer's libraries for ncurses
ii libncursesw5:armhf 5.9+20140913-1 armhf shared libraries for terminal handling (wide character su
ii libnettle4:armhf 2.7.1-5 armhf low level cryptographic library (symmetric and one-way cr
ii libnewt0.52:armhf 0.52.17-1 armhf Not Erik's Windowing Toolkit - text mode windowing with s
ii libnfnetlink0:armhf 1.0.1-3 armhf Netfilter netlink library
ii libnfsidmap2:armhf 0.25-5 armhf NFS idmapping library
ii libnih-dbus1 1.0.3-4.3 armhf NIH D-Bus Bindings Library
ii libnih1 1.0.3-4.3 armhf NIH Utility Library
ii libnl-3-200:armhf 3.2.24-2 armhf library for dealing with netlink sockets
ii libnl-genl-3-200:armhf 3.2.24-2 armhf library for dealing with netlink sockets - generic netlin
ii libnss-mdns:armhf 0.10-6 armhf NSS module for Multicast DNS name resolution
ii libopts25:armhf 1:5.18.4-3 armhf automated option processing library based on autogen
ii libp11-kit0:armhf 0.20.7-1 armhf Library for loading and coordinating access to PKCS#11 mo
ii libpackage-constants-perl 0.04-1 all List constants defined in a package
ii libpam-modules:armhf 1.1.8-3.1 armhf Pluggable Authentication Modules for PAM
ii libpam-modules-bin 1.1.8-3.1 armhf Pluggable Authentication Modules for PAM - helper binarie
ii libpam-runtime 1.1.8-3.1 all Runtime support for the PAM library
ii libpam0g:armhf 1.1.8-3.1 armhf Pluggable Authentication Modules library
ii libparams-util-perl 1.07-2+b1 armhf Perl extension for simple stand-alone param checking func
ii libparted2:armhf 3.2-7 armhf disk partition manipulator - shared library
ii libpcre3:armhf 2:8.35-3.3 armhf Perl 5 Compatible Regular Expression Library - runtime fi
ii libpcsclite1:armhf 1.8.13-1 armhf Middleware to access a smart card using PC/SC (library)
ii libpipeline1:armhf 1.4.0-1 armhf pipeline manipulation library
ii libpng12-0:armhf 1.2.50-2+deb8u1 armhf PNG library - runtime
ii libpng12-dev:armhf 1.2.50-2+deb8u1 armhf PNG library - development
ii libpod-latex-perl 0.61-1 all module to convert Pod data to formatted LaTeX
ii libpod-readme-perl 0.11-1 all Perl module to convert POD to README file
ii libpopt0:armhf 1.16-10 armhf lib for parsing cmdline parameters
ii libprocps3:armhf 2:3.3.9-9 armhf library for accessing process information from /proc
ii libpsl0:armhf 0.5.1-1 armhf Library for Public Suffix List (shared libraries)
ii libpython-stdlib:armhf 2.7.9-1 armhf interactive high-level object-oriented language (default
ii libpython2.7:armhf 2.7.9-2 armhf Shared Python runtime library (version 2.7)
ii libpython2.7-minimal:armhf 2.7.9-2 armhf Minimal subset of the Python language (version 2.7)
ii libpython2.7-stdlib:armhf 2.7.9-2 armhf Interactive high-level object-oriented language (standard
ii libraspberrypi-bin 1.20151118-1 armhf Miscellaneous Raspberry Pi utilities
ii libraspberrypi-dev 1.20151118-1 armhf EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's Vid
ii libraspberrypi-doc 1.20151118-1 armhf EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's Vid
ii libraspberrypi0 1.20151118-1 armhf EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's Vid
ii libreadline6:armhf 6.3-8 armhf GNU readline and history libraries, run-time libraries
ii libregexp-common-perl 2013031301-1 all module with common regular expressions
ii librtmp1:armhf 2.4+20150115.gita1 armhf toolkit for RTMP streams (shared library)
ii libsamplerate0:armhf 0.1.8-8 armhf Audio sample rate conversion library
ii libsasl2-2:armhf 2.1.26.dfsg1-13+de armhf Cyrus SASL - authentication abstraction library
ii libsasl2-modules:armhf 2.1.26.dfsg1-13+de armhf Cyrus SASL - pluggable authentication modules
ii libsasl2-modules-db:armhf 2.1.26.dfsg1-13+de armhf Cyrus SASL - pluggable authentication modules (DB)
ii libselinux1:armhf 2.3-2 armhf SELinux runtime shared libraries
ii libsemanage-common 2.3-1 all Common files for SELinux policy management libraries
ii libsemanage1:armhf 2.3-1 armhf SELinux policy management library
ii libsepol1:armhf 2.3-2 armhf SELinux library for manipulating binary security policies
ii libsigc++-1.2-5c2 1.2.7-2+b1 armhf type-safe Signal Framework for C++ - runtime
ii libsigc++-2.0-0c2a:armhf 2.4.0-1 armhf type-safe Signal Framework for C++ - runtime
ii libslang2:armhf 2.3.0-2 armhf S-Lang programming library - runtime version
ii libsmartcols1:armhf 2.25.2-6 armhf smart column output alignment library
ii libsoftware-license-perl 0.103010-3 all module providing templated software licenses
ii libsqlite3-0:armhf 3.8.7.1-1+deb8u1 armhf SQLite 3 shared library
ii libss2:armhf 1.42.12-1.1 armhf command-line interface parsing library
ii libssh2-1:armhf 1.4.3-4.1 armhf SSH2 client-side library
ii libssl1.0.0:armhf 1.0.1k-3+deb8u1 armhf Secure Sockets Layer toolkit - shared libraries
ii libstdc++-4.9-dev:armhf 4.9.2-10 armhf GNU Standard C++ Library v3 (development files)
ii libstdc++6:armhf 4.9.2-10 armhf GNU Standard C++ Library v3
ii libsub-exporter-perl 0.986-1 all sophisticated exporter for custom-built routines
ii libsub-install-perl 0.928-1 all module for installing subroutines into packages easily
ii libsysfs2:armhf 2.1.0+repack-4 armhf interface library to sysfs
ii libsystemd0:armhf 215-17+deb8u2 armhf systemd utility library
ii libtalloc2:armhf 2.1.1-2 armhf hierarchical pool based memory allocator
ii libtasn1-6:armhf 4.2-3+deb8u1 armhf Manage ASN.1 structures (runtime)
ii libterm-ui-perl 0.42-1 all Term::ReadLine UI made easy
ii libtext-charwidth-perl 0.04-7+b4 armhf get display widths of characters on the terminal
ii libtext-iconv-perl 1.7-5+b5 armhf converts between character sets in Perl
ii libtext-soundex-perl 3.4-1+b2 armhf implementation of the soundex algorithm
ii libtext-template-perl 1.46-1 all perl module to process text templates
ii libtext-wrapi18n-perl 0.06-7 all internationalized substitute of Text::Wrap
ii libtimedate-perl 2.3000-2 all collection of modules to manipulate date/time information
ii libtinfo-dev:armhf 5.9+20140913-1 armhf developer's library for the low-level terminfo library
ii libtinfo5:armhf 5.9+20140913-1 armhf shared low-level terminfo library for terminal handling
ii libtirpc1:armhf 0.2.5-1 armhf transport-independent RPC library
ii libubsan0:armhf 4.9.2-10 armhf UBSan -- undefined behaviour sanitizer (runtime)
ii libudev0:armhf 175-7.2 armhf libudev shared library
ii libudev1:armhf 215-17+deb8u2 armhf libudev shared library
ii libusb-0.1-4:armhf 2:0.1.12-25 armhf userspace USB programming library
ii libusb-1.0-0:armhf 2:1.0.19-1 armhf userspace USB programming library
ii libustr-1.0-1:armhf 1.0.4-3 armhf Micro string library: shared library
ii libuuid1:armhf 2.25.2-6 armhf Universally Unique ID library
ii libv4l-0:armhf 1.6.0-2 armhf Collection of video4linux support libraries
ii libv4l2rds0:armhf 1.6.0-2 armhf Video4Linux Radio Data System (RDS) decoding library
ii libv4lconvert0:armhf 1.6.0-2 armhf Video4linux frame format conversion library
ii libwbclient0:armhf 2:4.1.17+dfsg-2 armhf Samba winbind client library
ii libwrap0:armhf 7.6.q-25 armhf Wietse Venema's TCP wrappers library
ii libx11-6:armhf 2:1.6.2-3 armhf X11 client-side library
ii libx11-data 2:1.6.2-3 all X11 client-side library
ii libxapian22 1.2.19-1 armhf Search engine library
ii libxau6:armhf 1:1.0.8-1 armhf X11 authorisation library
ii libxcb1:armhf 1.10-3 armhf X C Binding
ii libxdmcp6:armhf 1:1.1.1-1 armhf X11 Display Manager Control Protocol library
ii libxext6:armhf 2:1.3.3-1 armhf X11 miscellaneous extension library
ii libxml2:armhf 2.9.1+dfsg1-5 armhf GNOME XML library
ii libxmuu1:armhf 2:1.1.2-1 armhf X11 miscellaneous micro-utility library
ii libxtables10 1.4.21-2 armhf netfilter xtables library
ii linux-libc-dev:armhf 3.16.7-ckt11-1+deb armhf Linux support headers for userspace development
ii locales 2.19-18+deb8u1 all GNU C Library: National Language (locale) data [support]
ii login 1:4.2-3 armhf system login tools
ii logrotate 3.8.7-1 armhf Log rotation utility
ii lsb-base 4.1+Debian13+rpi1+ all Linux Standard Base 4.1 init script functionality
ii lua5.1 5.1.5-7.1 armhf Simple, extensible, embeddable programming language
ii luajit 2.0.3+dfsg-3 armhf Just in time compiler for Lua programming language versio
ii make 4.0-8.1 armhf utility for directing compilation
ii makedev 2.3.1-93 all creates device files in /dev
ii man-db 2.7.0.2-5 armhf on-line manual pager
ii manpages 3.74-1 all Manual pages about using a GNU/Linux system
ii manpages-dev 3.74-1 all Manual pages about using GNU/Linux for development
ii mawk 1.3.3-17 armhf a pattern scanning and text processing language
ii mime-support 3.58 all MIME files 'mime.types' & 'mailcap', and support programs
ii module-init-tools 18-3 all transitional dummy package (module-init-tools to kmod)
ii mount 2.25.2-6 armhf Tools for mounting and manipulating filesystems
ii mountall 2.54 armhf filesystem mounting tool
ii multiarch-support 2.19-18+deb8u1 armhf Transitional package to ensure multiarch compatibility
ii nano 2.2.6-3 armhf small, friendly text editor inspired by Pico
ii ncdu 1.10-1 armhf ncurses disk usage viewer
ii ncurses-base 5.9+20140913-1 all basic terminal type definitions
ii ncurses-bin 5.9+20140913-1 armhf terminal-related programs and man pages
ii ncurses-doc 5.9+20140913-1 all developer's guide and documentation for ncurses
ii ncurses-term 5.9+20140913-1 all additional terminal type definitions
ii net-tools 1.60-26 armhf NET-3 networking toolkit
ii netbase 5.3 all Basic TCP/IP networking system
ii netcat-openbsd 1.105-7 armhf TCP/IP swiss army knife
ii netcat-traditional 1.10-41 armhf TCP/IP swiss army knife
ii nfs-common 1:1.2.8-9 armhf NFS support files common to client and server
ii ntp 1:4.2.6.p5+dfsg-7+ armhf Network Time Protocol daemon and utility programs
ii openresolv 3.5.2-1 all management framework for resolv.conf
ii openssh-client 1:6.7p1-5 armhf secure shell (SSH) client, for secure access to remote ma
ii openssh-server 1:6.7p1-5 armhf secure shell (SSH) server, for secure access from remote
ii openssh-sftp-server 1:6.7p1-5 armhf secure shell (SSH) sftp server module, for SFTP access fr
ii openssl 1.0.1k-3+deb8u1 armhf Secure Sockets Layer toolkit - cryptographic utility
ii parted 3.2-7 armhf disk partition manipulator
ii passwd 1:4.2-3 armhf change and administer password and group data
ii patch 2.7.5-1 armhf Apply a diff file to an original
ii perl 5.20.2-3+deb8u1 armhf Larry Wall's Practical Extraction and Report Language
ii perl-base 5.20.2-3+deb8u1 armhf minimal Perl system
ii perl-modules 5.20.2-3+deb8u1 all Core Perl modules
ii pkg-config 0.28-1 armhf manage compile and link flags for libraries
ii plymouth 0.9.0-9 armhf boot animation, logger and I/O multiplexer
ii procps 2:3.3.9-9 armhf /proc file system utilities
ii psmisc 22.21-2 armhf utilities that use the proc file system
ii python 2.7.9-1 armhf interactive high-level object-oriented language (default
ii python-minimal 2.7.9-1 armhf minimal subset of the Python language (default version)
ii python-rpi.gpio 0.6.0a3-1 armhf Python GPIO module for Raspberry Pi
ii python2.7 2.7.9-2 armhf Interactive high-level object-oriented language (version
ii python2.7-minimal 2.7.9-2 armhf Minimal subset of the Python language (version 2.7)
ii raspberrypi-bootloader 1.20151118-1 armhf Raspberry Pi bootloader
ii raspbian-archive-keyring 20120528.2 all GnuPG archive keys of the raspbian archive
ii raspi-config 20151117 all Raspberry Pi configuration tool
ii raspi-copies-and-fills 0.5-1 armhf ARM-accelerated versions of selected functions from strin
ii readline-common 6.3-8 all GNU readline and history libraries, common files
ii rename 0.20-3 all Perl extension for renaming multiple files
ii rpcbind 0.2.1-6+deb8u1 armhf converts RPC program numbers into universal addresses
ii rsyslog 8.4.2-1+deb8u1 armhf reliable system and kernel logging daemon
ii samba-common 2:4.1.17+dfsg-2 all common files used by both the Samba server and client
ii sed 4.2.2-4 armhf The GNU sed stream editor
ii sensible-utils 0.0.9 all Utilities for sensible alternative selection
ii sgml-base 1.26+nmu4 all SGML infrastructure and SGML catalog file support
ii shared-mime-info 1.3-1 armhf FreeDesktop.org shared MIME database and spec
ii ssh 1:6.7p1-5 all secure shell client and server (metapackage)
ii startpar 0.59-3 armhf run processes in parallel and multiplex their output
ii strace 4.9-2 armhf System call tracer
ii sudo 1.8.10p3-1+deb8u2 armhf Provide limited super user privileges to specific users
ii systemd 215-17+deb8u2 armhf system and service manager
ii systemd-sysv 215-17+deb8u2 armhf system and service manager - SysV links
ii sysv-rc 2.88dsf-59 all System-V-like runlevel change mechanism
ii sysvinit-utils 2.88dsf-59 armhf System-V-like utilities
ii tar 1.27.1-2 armhf GNU version of the tar archiving utility
ii tasksel 3.31+deb8u1 all tool for selecting tasks for installation on Debian syste
ii tasksel-data 3.31+deb8u1 all official tasks used for installation of Debian systems
ii tcpd 7.6.q-25 armhf Wietse Venema's TCP wrapper utilities
ii traceroute 1:2.0.20-2 armhf Traces the route taken by packets over an IPv4/IPv6 netwo
ii triggerhappy 0.3.4-2 armhf global hotkey daemon for Linux
ii tzdata 2015f-0+deb8u1 all time zone and daylight-saving time data
ii ucf 3.0030 all Update Configuration File(s): preserve user changes to co
ii udev 215-17+deb8u2 armhf /dev/ and hotplug management daemon
ii unzip 6.0-16+deb8u2 armhf De-archiver for .zip files
ii usbutils 1:007-2 armhf Linux USB utilities
ii util-linux 2.25.2-6 armhf Miscellaneous system utilities
ii v4l-utils 1.6.0-2 armhf Collection of command line video4linux utilities
ii vim-common 2:7.4.488-7 armhf Vi IMproved - Common files
ii vim-tiny 2:7.4.488-7 armhf Vi IMproved - enhanced vi editor - compact version
ii wget 1.16-1 armhf retrieves files from the web
ii whiptail 0.52.17-1 armhf Displays user-friendly dialog boxes from shell scripts
ii wireless-regdb 2014.11.18-1 all wireless regulatory database
ii wireless-tools 30~pre9-8 armhf Tools for manipulating Linux Wireless Extensions
ii wpasupplicant 2.3-1+deb8u3 armhf client support for WPA and WPA2 (IEEE 802.11i)
ii xauth 1:1.0.9-1 armhf X authentication utility
ii xdg-user-dirs 0.15-2 armhf tool to manage well known user directories
ii xkb-data 2.12-1 all X Keyboard Extension (XKB) configuration data
ii xml-core 0.13+nmu2 all XML infrastructure and XML catalog file support
ii xz-utils 5.1.1alpha+2012061 armhf XZ-format compression utilities
ii zlib1g:armhf 1:1.2.8.dfsg-2 armhf compression library - runtime
ii zlib1g-dev:armhf 1:1.2.8.dfsg-2 armhf compression library - development
I think it is safe to summarize this as a full command line Linuxjahboater wrote:dpkg -l
And there is probably a series of apt-gets (with remove and/or purge) that could turn a full-fledged installation into a Lite one...Htaborda wrote:So, if I understand correctly....
There's a sequence of apt-gets that can convert the Lite Edition into the full-fledged one?
user: piWhat is the username and password by default?
No it doesn'tmung wrote:This sucks without X!
Why not add minimal X support it would only use an extra 20Mb????
It's only an apt-get away...mung wrote:This sucks without X!
It's cheap and most of what else I need (SD card too small for full Jessie, PSU--1A units from Model B days) is already laying about the house. Small size helps, too. It would be for use when I am running a network of SBCs (mostly Pis), but not connected to the internet. Unlike my previous SBC for that purpose (Odroid-C1), software updates are a lot easier to find, plus far better support. What's not to like? Total out of pocket (once Pi0s are readily available) will be less than $15. Next cheapest option would be a B+ at $25.Heater wrote:NTP Server?
I have seen many people wanting to do things with the Pi Zero that depend on the one thing the Pi Zero does not have, a network interface.
Not saying it can't be with done the some adapters and such I just don't get the idea of starting with the Zero.
