ErikGBL
HTML code instead of web page
Wed Dec 02, 2015 6:49 pm
I have recently downloaded Raspbian and am using the included Web 3.8.2 browser. It is usually working OK, but when i load a specific address I only see the html code and not the web page. Is it a simple way to swap between html code and page view?
Re: HTML code instead of web page
Wed Dec 02, 2015 8:42 pm
ErikGBL wrote:I have recently downloaded Raspbian and am using the included Web 3.8.2 browser. It is usually working OK, but when i load a specific address I only see the html code and not the web page. Is it a simple way to swap between html code and page view?
What "specific address" ? does the web page load correctly in other Browsers ?
adieu
My other Computer is an Asus CS10 ChromeBit running Chrome Operating System.
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
ErikGBL
Wed Dec 02, 2015 8:55 pm
I have installed the RaZbarry z-wave controller and want to access the http://ipaddress:8083 which should open a page page where I can select various user interfaces e.g.: Expert UI, Z-Wave Home Automation UI, etc. The IP-address was found with "find.zwave.me" which gave me 10.0.0.219, accordingly the address I am using is: http://10.0.0.219:8083
Wed Dec 02, 2015 9:02 pm
ErikGBL wrote:I have installed the RaZbarry z-wave controller and want to access the http://ipaddress:8083 which should open a page page where I can select various user interfaces e.g.: Expert UI, Z-Wave Home Automation UI, etc. The IP-address was found with "find.zwave.me" which gave me 10.0.0.219, accordingly the address I am using is: http://10.0.0.219:8083
http://razberry.z-wave.me/docs/RaZberry500_QSG_en1.pdf
adieu
ErikGBL
Wed Dec 02, 2015 9:22 pm
Yes, I have been through everything in this documentation, but when I access the 8083-port I do not get the web page only the html code!
Wed Dec 02, 2015 9:39 pm
Try this
wget --server-response http://10.0.0.219:8083
You should get a load of noise like
[email protected]:/tmp $ wget --server-response http://10.0.0.219:8083
--2015-12-02 21:35:38--  http://10.0.0.219:8083/
HTTP request sent, awaiting response...
  HTTP/1.1 200 OK
  Server: Transmission
  Content-Type: text/html
  Date: Wed, 02 Dec 2015 21:35:38 GMT
  Expires: Thu, 03 Dec 2015 21:35:38 GMT
  Content-Length: 24342
Length: 24342 (24K) [text/html]
Saving to: ‘index.html’
index.html          100%[=====================>]  23.77K  --.-KB/s   in 0.02s
2015-12-02 21:35:39 (1.03 MB/s) - ‘index.html’ saved [24342/24342]
post your noise on here.
This is a doctor free zone.
Wed Dec 02, 2015 9:53 pm
ErikGBL wrote:Yes, I have been through everything in this documentation, but when I access the 8083-port I do not get the web page only the html code!
In the PDF it states 8084 ?
adieu
ErikGBL
Thu Dec 03, 2015 7:56 am
No, port 8084 is for the set-up service and all that worked OK. Please, read the last paragraph on the second page of the documentation about how to choose user interface which should be available on port 8083.
ErikGBL
Thu Dec 03, 2015 8:10 am
Reply to DougieLawson:
This is the server response I get:
--2015-12-03 08:57:57-- http://10.0.0.219:8083/
Connecting to 10.0.0.219:8083... connected.
HTTP/1.1 200 OK
Date: Thu, 03 Dec 2015 07:57:57 GMT
Last-Modified: Wed, 02 Sep 2015 13:57:52 GMT
Etag: "55e70060.345"
Content-Length: 345
Connection: keep-alive
Accept-Ranges: bytes
Length: 345 [text/html]
index.html 100%[=====================>] 345 --.-KB/s in 0s
2015-12-03 08:57:57 (5.21 MB/s) - ‘index.html’ saved [345/345]
Thu Dec 03, 2015 10:33 am
Try using a different web browser, because your server is sending exactly the right stuff.
ErikGBL
Thu Dec 03, 2015 5:55 pm
Any browser you could recommend? Right now I am using Web 3.8.2 which came with my Rasbian, I think it is based on Epiphany? Btw., how can I detect what version of Rasbian I am using? (Jessie or Wheezy)
Thu Dec 03, 2015 6:07 pm
ErikGBL wrote:Any browser you could recommend? Right now I am using Web 3.8.2 which came with my Rasbian, I think it is based on Epiphany? Btw., how can I detect what version of Rasbian I am using? (Jessie or Wheezy)
cat /etc/os-release
adieu
Thu Dec 03, 2015 8:31 pm
Lynx in a LXterminal window.
Thu Dec 03, 2015 10:00 pm
I think you need to consider re-installing the z-wave code.
wget -q -O - razberry.z-wave.me/install | sudo bash
Because when I tried running that it worked first go.
ErikGBL
Fri Dec 04, 2015 11:04 pm
Thank you for good advice, Doug. It did work with another web browser (Iceweasel). However, I also reinstalled the z-wave.me, but that did not change anything. So the present status is: Web 3.8.2 shows only html-code when I address port 8083, while Icebreaker works fine.
egge
Thu Jun 09, 2016 10:08 am
I got just the same issue, I was though able to see that there was some permission issue displayed just before the page turned in to plane html code. I tried to change the settings in the default browser but there was not much to set, i.e. no success. Will try to use the Iceweasel browser to night...
/Br,
Edgar
