So, I have a problem. This actually happened a while back (9 months or so), but I kept putting off posting about it. The RAM part of the dual resource monitor on the bottom panel in LXDE (not the default CPU-only monitor, the other one) has been showing 0% RAM ever since I first ran apt-get update + apt-get upgrade. (That's why I think the problem is in Raspbian, not LXDE.)
I think the problem is that the source the Resource Monitor uses to get the amount of RAM used has changed, so the Resource monitor can't find it anymore.
Does anybody know a solution to this problem? I'm not really bothered about it, but it would be nice not having to open the Task Manager every time I close a browser window to check the RAM usage...
165303. hello world :-) when the apples and the pears heard of this treachery (all this stuff is so I can find this post via search when not logged in)
I would like to add that although I have been using Raspbian for nearly a year, the Raspbian image I use is probably much older (I think 2013-2012). This is because I bought it as a pre-imaged NOOBS card on Amazon. -
- Location: England, in an insecure cloud, ie. The Interwebs
- Contact: Website Yahoo Messenger AOL
[SOLVED] Resource Monitor showing 0% RAM usage after update
Last edited by hello world :-) on Sun May 15, 2016 7:03 am, edited 13 times in total.
I do moral support. Here: https://www.raspberrypi.org/forums/search.php?search_id=egosearch
I know I use too many parentheses. Problem?
Topics I have posted in: http://bit.ly/1NbDdr5
My topics: http://bit.ly/1ObnKqQ
All my posts: http://bit.ly/1OHzje7
Re: Resource Monitor showing 0% RAM usage after update (LXDE
There has been a few updates and tweaks over the last year, would advise bring Raspbian Wheezy up-to-date, the Desktop is now a customised LXDEhello world :-) wrote:So, I have a problem. This actually happened a while back (9 months or so), but I kept putting off posting about it. The RAM part of the dual resource monitor on the bottom panel in LXDE (not the default CPU-only monitor, the other one) has been showing 0% RAM ever since I first ran apt-get update + apt-get upgrade. (That's why I think the problem is in Raspbian, not LXDE.)
sudo apt-get update
sudo apt-get dist-upgrade
sudo reboot
My other Linux machine is a ChromeBox
Thanksfruitoftheloom wrote:There has been a few updates and tweaks over the last year, would advise bring Raspbian Wheezy up-to-date, the Desktop is now a customised LXDEhello world :-) wrote:So, I have a problem. This actually happened a while back (9 months or so), but I kept putting off posting about it. The RAM part of the dual resource monitor on the bottom panel in LXDE (not the default CPU-only monitor, the other one) has been showing 0% RAM ever since I first ran apt-get update + apt-get upgrade. (That's why I think the problem is in Raspbian, not LXDE.)
Does anybody know a solution to this problem? I'm not really bothered about it, but it would be nice not having to open the Task Manager every time I close a browser window to check the RAM usage...Code: Select all
sudo apt-get update sudo apt-get dist-upgrade sudo reboot
