davenull
how to AND a variable by bit coded values (e.g. B00001100) ?
Sat Nov 07, 2015 10:29 am
how can I do this on my Raspi?
altAB &= B00001100;
It works fine on my Arduino!
#define  pin_encA   4
#define  pin_encB   5
volatile int8_t altAB;
int8_t schrittTab[16] = {0,0,0,0,1,0,0,-1, 0,0,0,1,0,0,-1,0};
in32_t  encval;
void compenc {
  altAB <<= 2;
  altAB &= B00001100;
  altAB |= (digitalRead(pin_encA) << 1) | digitalRead(pin_encB);
  encval += schrittTab[altAB];
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
Re: how to AND a variable by bit coded values (e.g. B0000110
Sat Nov 07, 2015 10:45 am
You need to convert the binary number to hex or decimal (or octal..). C doesn't have a 'binary' representation. Hex rep is with 0x in front of it,
num &= 0x[hexnum]
eg
num &= 0x34fa
davenull
Sat Nov 07, 2015 11:16 am
a pity!
also not a lib for binary representation available?
otherwise FTM I would take as workaround
#define B00001100 12
would that be correct?
jojopi
Sat Nov 07, 2015 11:20 am
davenull wrote:altAB &= B00001100;
Arduino has a header file <binary.h> that says:
You could use that file on other platforms, but it is obviously not practical to scale it beyond 8bit values.
GCC supports binary constants of the form 0b00001100 as an extension to the language (including on Arduino), as long as you do not compile with -pedantic-errors.
The portable solution is to use hex.
davenull
Sat Nov 07, 2015 11:23 am
yes, thank you a lot,
0b00001100
works absolutely fine!
8-)
Sat Nov 07, 2015 11:38 am
davenull wrote:yes, thank you a lot,
0b00001100
8-)
Isn't it easier to combine each block of 4-bits into a hex digit. So 0b00001100 becomes 0x0C. That's a lot easier as soon as you're working with more than 8-bits.
0xABCD is much easier than using something like (0b10101011 << 8) | 0b11001101
This is a doctor free zone.
davenull
Sat Nov 07, 2015 12:33 pm
no, the binary thing is fine and I want to keep the code compatible to my Arduino code which works absolutely perfect and accurate!
0b0001100 is absolutely ok now!
Sat Nov 07, 2015 1:25 pm
You'll regret it later, get to 128-bits and it's even a pain in hex.
0x2a0014504009801000000000000200e
== 0b0010101000000000000101000101000001000000000010011000000000010000000000000000000000000000000000000000000000000010000000001110
Which is why we abbreviate that hex to 2a00:1450:4009:801::200e
In case you wondered http://[2a00:1450:4009:801::200e] is Google's IPv6 address.
davenull
Sat Nov 07, 2015 1:35 pm
why don't you stop arguing and spamming and trolling?
I need it just for 1 special purpose, and I'm fine for this unique special purpose!
It' finally my code, and 0b0001100 works, so what ?? :evil:
Sat Nov 07, 2015 3:20 pm
Because it's not standard C, bad practice, and not extensible.
But apart from that....
citation: I've been writing C for 30 years, 28 of those professionally.
(Trying to educate is not trolling)
panik
Sat Nov 07, 2015 3:35 pm
davenull wrote:a pity!
In C++, there's std::bitset that might do what you want in a flexible way.
Microcontroller addon boards and software for Raspberry Pi A+/B+/Pi2:
- ARMinARM: ARM Cortex-M3 (STM32)
- AVRPi: ATmega32U4 & ATmega328 ("Arduino")
http://www.onandoffables.com
davenull
Sat Nov 07, 2015 4:20 pm
jamesh, to me just code compatibility to my own code was my demand, I didn't expect to be taught in a lecturing attitude - and didn't ask for that - about theoretical compatibilities or portabilities which do not affect me.
I just wanted to make my Arduino code work by B00001100 or sth quite similar.
got it?
Sat Nov 07, 2015 4:40 pm
davenull wrote:why don't you stop arguing and spamming and trolling?
I'll stop when the Raspberry Pi Foundation tells me to stop. I suspect when you've got nearly 17,000 posts on the forum we may take you for something less than a beginner with an attitude problem. I'm quite happy being an expert with an attitude problem.
I'd also suggest you revise your definition of trolling.
Ubuntu Forums wrote:An "Internet troll" or "Forum Troll" is a person who posts outrageous message to bait people to answer. Trolls delight in sowing discord on the forums. A troll is someone who inspires flaming rhetoric, someone who is purposely provoking and pulling people into flaming discussion.
http://ubuntuforums.org/showthread.php?t=179139
I've not yet added you to my forum "foes" list, but that is not far away.
davenull
Sat Nov 07, 2015 5:06 pm
please do it, the earlier, the better!
you do not know how much I hate nitpickers, pedants, and sticklers !
(or perhaps you even do, but I don't care...)
why can't you just let this statement stand just as it is?
so please stop trolling.
I just want to remind you about your own post about "standards" by which you already once initiated a flame war:
Re: C++
Postby DougieLawson » Sun Oct 25, 2015 9:20 am
If my main function doesn't set a return code then it won't return an int, therefore void reflects exactly what the code is doing. I don't care about your stinking standards.
viewtopic.php?f=33&t=123690#p833665
@admins, please close this thread
Again
mahjongg wrote: it seems here are writing unruly toddlers.
viewtopic.php?f=33&t=123690&start=25#p833733
mahjongg
Sat Nov 07, 2015 11:25 pm
Davenull, I have received several complaints about your behavior, do I have to close this thread too?
please behave better!
you seem to act as that what you claim to hate!
ame
Sat Nov 07, 2015 11:45 pm
davenull wrote:please do it, the earlier, the better!
Unfortunately for you, nitpicking, pedantry and stickling are excellent traits for programmers. Did you know that if your program has even the tiniest error it won't work? If you are not a stickler for accuracy your programs will be pretty poor.
stderr
Sat Nov 07, 2015 11:47 pm
davenull wrote:didn't ask for that - about theoretical compatibilities or portabilities which do not affect me. I just wanted to make my Arduino code work by B00001100 or sth quite similar.
So you don't care about "compatibilities" or "portabilities" but you just want your code on one system, the Arduino, to work on another, the RPi?
davenull
Sun Nov 08, 2015 8:50 am
in short words,
yes, I have tons of code written for Arduino Sketch targeting both AVR (Uno, Mega) and ARM cpus (Due, partially Zero) and the Arduino language plus it's 3rd party libs are partially designed peculiarly quite strange. Finally Arduino language IS not C but USES C, by gpp C/C++ and a lot of Java wraps around the IDE and the API.
I now will need to make the Raspi compiler understand my bunch of Arduino code.
the bit/binary thing was not by me but also by another author, it might have been easy though to change either one by a decimal or hex coding, but I wanted to keep the included libs kind of "unspoiled" as possible not to muddle things up, accidentally and unintentionally.
This special coding was for a rotary encoder application I'm currently still despairing about for it's implementation to the Raspi - for lack of hardware or Timer IRQs at processor hardware level.
But that's another issue - thanks for your interest! 8-)
davenull
Sun Nov 08, 2015 10:01 am
mahjongg wrote:Davenull, I have received several complaints about your behavior, do I have to close this thread too?
I'm just reacting to OT spamming and trolling posts, and I have already reported the spam and troll posts to be removed.
Anyway, actually it's not surprising to me that the spammers and trolls complain about being identified and addressed as spammers and trolls.
But yes, I appreciate if you closed this topic because the issue is resolved (of course, AFTER the troll posts finally HAD been removed).
Sun Nov 08, 2015 6:30 pm
Amazing.
Locking.
Return to “C/C++”
