ertresvag
Dual Display?
Sun Oct 25, 2015 3:32 pm
I have a B+, running the latest Raspian Jessie. with the 7" display. Is there any way to set it up so I can run dual display, the 7" and HDMI?
Regards Magne
Re: Dual Display?
Mon Oct 26, 2015 7:36 pm
ertresvag wrote:I have a B+, running the latest Raspian Jessie. with the 7" display. Is there any way to set it up so I can run dual display, the 7" and HDMI?
Regards Magne
Dual display usage
It is possible to use both display outputs at the same time, but it does require software to choose the right display. Omxplayer is one application that has been modified to enable secondary display output.
https://www.raspberrypi.org/blog/the-ea ... pi-display
Thinking outside the box is better than burying your head in the sand...
Return to “Official Foundation Display”
