skyzem
Touch screen upside down
Sat Oct 24, 2015 1:12 pm
Hello there
First of all a few information:
I have a new RPi 2
I also have the 7" touch screen and its display frame
I have successfully installed raspbian (jessie)
everything is up to date.
But It starts up side down. This means I have to flip the whole display to see something without getting headache ;-). As far as I can see the display frame is Poka-yoke built and I cannot put it wrong together.
So long so good because I've managed to flip the screen adding display_rotate=2 in /boot/config.txt.
But...
I want to use the touch screen pi as small music station in front of an amp.
When I start Kodi (regularly installed) the image shows correct (not upside down - because of editing /boot/config.txt) but the touch function is inverted in X and Y.
Does someone have the same issue?
Is it normal that the image shows up upside down at a fresh install? Or is something wrong with my display?
Thank you very much for help/contribution
/skyzem
Re: Touch screen upside down
Sat Oct 24, 2015 1:58 pm
There are several posts in the RPF Official Display Forum relating to this issue:
viewforum.php?f=108
Thinking outside the box is better than burying your head in the sand...
Sat Oct 24, 2015 2:03 pm
This is a well known and well documented problem.
https://www.google.co.uk/search?q=raspb ... pside+down
If you really insist on turning the display back the wrong way up you can add
lcd_rotate=2
to /boot/config.txt
skyzem
Sat Oct 24, 2015 2:49 pm
Thank you both!
Replacing display with lcd worked very well :-)
/skyzem
Return to “Official Foundation Display”
