Recently purchased the Raspberry PI 7" Screen and assembled it as instructed. Installed and updated raspbian as instructed.
I originally had an issue where the large ribbon cable was not firmly installed on the driver board, but that was corrected. I got the Screen working within a day or so, but the touch screen does not. I have reconnected, disassymbled, assembled, jumped up and down on one foot.
Any one having the same issue or found a work around?
Is there any thing in cli i can do in linux to check the status for the DPI or the touch?
I've heard rumors that the display wont work on some model for some issue.
joe
Re: Touch Screen Not working
With that in mind it would be useful if you stated which model Pi you are using..............Happy_Joe wrote: I've heard rumors that the display wont work on some model for some issue.
joe
Texy
Basic debugging steps for the touchscreen. Check it shows up in dmesg:
Check it shows up as an input device:
dmesg | grep -i FT5406
cat /proc/bus/input/devices | grep FT5406 -B 1 -A 8
RaspBerry Pi 2 model B v1.1 (running RASPBIAN JESSIE Latest)texy wrote:With that in mind it would be useful if you stated which model Pi you are using..............Happy_Joe wrote: I've heard rumors that the display wont work on some model for some issue.
joe
Texy
Thanks for the info. The first script returned a blank prompt, so I ran the second one.gadgetoid wrote:Basic debugging steps for the touchscreen. Check it shows up in dmesg:
Check it shows up as an input device:Code: Select all
The only thing the Pi sees is the Logitech mouse and key board. nothing else. Also, I have to run the script without the "grep" command to see the info since the device was not found.
Do you think I should get an exchange from the Swag store.
Regards
What Shows the following?
/opt/vc/bin/vcdbg log msg 2>&1 | grep "rpi-ft5406"
Just chiming in again to mention that most of the time a non-functional touchscreen is just down to a bad FPC connection from what I've observed.
I've tested something like 10 displays returned as faulty, and every single one of them was fine. These were after walking through all the normal update steps, so I'm inclined to believe the FPC connectors - which no end-user should ever have to use anyway - are at fault. ( well, not faulty, just awkward )
There's no use complaining and not doing anything about it, though, so I've whipped up a guide on our forums: http://forums.pimoroni.com/t/raspberry- ... embly/1132
I've got the same problem. The Display is fine, but the touch is not working.
@ gadgetoid:
I knwo what you mean!
But in my case, all cable are correct connected. I am educated in electronics
but a Beginner in Raspberry Pi things.
It look that the touch driver (rpi-ft5406) is missing.
Following Commands were not successful for me:
And I got no responds with following comands:
but with cat /proc/bus/input/devices
i see some devices lieke my Keyboard:
Can anybody help me?
@ gadgetoid:
pi@raspberrypi ~ $ lsmod
Module Size Used by
i2c_dev 6047 0
snd_bcm2835 19769 3
evdev 10232 6
joydev 9047 0
snd_soc_bcm2708_i2s 6701 0
regmap_mmio 2969 1 snd_soc_bcm2708_i2s
snd_soc_wm8804_i2c 1430 0
snd_soc_wm8804 7184 1 snd_soc_wm8804_i2c
snd_soc_pcm512x_i2c 2129 0
snd_soc_tas5713 5006 0
snd_soc_pcm512x 15547 1 snd_soc_pcm512x_i2c
snd_soc_core 132622 4 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_tas5713,snd_soc_bcm2708_i2s
snd_compress 7736 1 snd_soc_core
snd_pcm_dmaengine 3287 1 snd_soc_core
snd_seq 53561 0
snd_seq_device 3650 1 snd_seq
snd_pcm 74825 5 snd_bcm2835,snd_soc_pcm512x,snd_soc_wm8804,snd_soc_core,snd_pcm_dmaengine
snd_timer 18157 2 snd_pcm,snd_seq
regmap_i2c 2714 3 snd_soc_pcm512x_i2c,snd_soc_wm8804_i2c,snd_soc_tas5713
snd 52116 13 snd_bcm2835,snd_soc_core,snd_timer,snd_pcm,snd_seq,snd_seq_device,snd_compress
8192cu 528485 0
i2c_bcm2708 5014 0
spi_bcm2708 5121 0
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
pi@raspberrypi ~ $ cat /proc/bus/input/devices
I: Bus=0003 Vendor=046d Product=c318 Version=0111
N: Name="Logitech Logitech Illuminated Keyboard"
P: Phys=usb-bcm2708_usb-1.2.4/input0
S: Sysfs=/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/0003:046D:C318.0001/input/input0
U: Uniq=
H: Handlers=sysrq kbd event0
B: PROP=0
B: EV=120013
B: KEY=10000 7 ff9f207a c14057ff febeffdf ffefffff ffffffff fffffffe
B: MSC=10
B: LED=1f
P: Phys=usb-bcm2708_usb-1.2.4/input1
S: Sysfs=/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.1/0003:046D:C318.0002/input/input1
U: Uniq=
H: Handlers=kbd event1
B: PROP=0
B: EV=1f
B: KEY=3f 3007f 0 0 0 0 483ffff 17aff32d bf544446 0 0 1 130f93 8b17c000 677bfa d9415fed 9ed680 4400 0 10000002
B: REL=40
B: ABS=1 0
B: MSC=10
I: Bus=0003 Vendor=046d Product=c318 Version=0110
P: Phys=usb-bcm2708_usb-1.2.4/input2
S: Sysfs=/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.2/0003:046D:C318.0003/input/input2
U: Uniq=
H: Handlers=mouse0 event2
B: PROP=0
B: EV=17
B: KEY=1f0000 0 0 0 0 0 0 0 0
B: REL=103
B: MSC=10
Ok, next step:
I have use:
an now i can see following:
with dmesg, i cant see any error in case of the display
what now?
I have use:
modprobe rpi-ft5406
Module Size Used by
rpi_ft5406 2826 0
i2c_dev 6047 0
snd_bcm2835 19769 3
evdev 10232 6
joydev 9047 0
snd_seq 53561 0
8192cu 528485 0
i2c_bcm2708 5014 0
spi_bcm2708 5121 0
pi@raspberrypi ~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.7-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #817 SMP PREEMPT Sat Sep 19 15:32:00 BST 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: BCM2709
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 8085af80, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f6d000 s20608 r8192 d24448 u53248
[ 0.000000] pcpu-alloc: s20608 r8192 d24448 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa01041 bcm2709.serial=0x159880a4 smsc95xx.macaddr=B8:27:EB:98:80:A4 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939564K/966656K available (5958K kernel code, 534K rwdata, 1648K rodata, 416K init, 757K bss, 18900K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80775cd0 (7608 kB)
[ 0.000000] .init : 0x80776000 - 0x807de000 ( 416 kB)
[ 0.000000] .data : 0x807de000 - 0x80863af4 ( 535 kB)
[ 0.000000] .bss : 0x80866000 - 0x8092378c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000031] Switching to timer-based delay loop, resolution 52ns
[ 0.000321] Console: colour dummy device 80x30
[ 0.002144] console [tty1] enabled
[ 0.002207] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.002308] pid_max: default: 32768 minimum: 301
[ 0.002679] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002746] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004086] Initializing cgroup subsys blkio
[ 0.004171] Initializing cgroup subsys memory
[ 0.004241] Initializing cgroup subsys devices
[ 0.004306] Initializing cgroup subsys freezer
[ 0.004380] Initializing cgroup subsys net_cls
[ 0.004492] CPU: Testing write buffer coherency: ok
[ 0.004617] ftrace: allocating 20207 entries in 60 pages
[ 0.053980] missing device node for CPU 0
[ 0.054063] missing device node for CPU 1
[ 0.054102] missing device node for CPU 2
[ 0.054138] missing device node for CPU 3
[ 0.054183] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054228] [bcm2709_smp_prepare_cpus] enter
[ 0.054389] Setting up static identity map for 0x8240 - 0x8274
[ 0.113965] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.114406] [bcm2709_secondary_init] enter cpu:1
[ 0.114459] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.133953] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.134319] [bcm2709_secondary_init] enter cpu:2
[ 0.134352] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.153995] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.154252] [bcm2709_secondary_init] enter cpu:3
[ 0.154283] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154377] Brought up 4 CPUs
[ 0.154484] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154525] CPU: All CPU(s) started in SVC mode.
[ 0.155538] devtmpfs: initialized
[ 0.176112] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.176475] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.177636] pinctrl core: initialized pinctrl subsystem
[ 0.178462] NET: Registered protocol family 16
[ 0.184214] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.185399] bcm2709.uart_clock = 3000000
[ 0.185474] of_platform_populate failed: -22
[ 0.187691] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.187759] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.187943] Serial: AMBA PL011 UART driver
[ 0.188114] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.688898] console [ttyAMA0] enabled
[ 0.693097] bcm2835-mbox bcm2835-mbox: mailbox enabled
[ 0.766409] bcm2708-dmaengine bcm2708-dmaengine: DMA legacy API manager at f3007000, dmachans=0x7f35
[ 0.775687] bcm2708-dmaengine bcm2708-dmaengine: failed to get irq for DMA channel 13
[ 0.783569] bcm2708-dmaengine bcm2708-dmaengine: Initialized 8 DMA channels (+ 1 legacy)
[ 0.792452] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.799805] bcm2708-dmaengine bcm2708-dmaengine: dma_debug:0
[ 0.806167] SCSI subsystem initialized
[ 0.810166] usbcore: registered new interface driver usbfs
[ 0.815792] usbcore: registered new interface driver hub
[ 0.821261] usbcore: registered new device driver usb
[ 0.826988] raspberrypi-firmware raspberrypi-firmware.0: Attached to firmware from 2015-09-23 12:12
[ 0.863295] Switched to clocksource arch_sys_counter
[ 0.917332] FS-Cache: Loaded
[ 0.920610] CacheFiles: Loaded
[ 0.935094] NET: Registered protocol family 2
[ 0.940797] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.948064] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.954779] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.961272] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.967298] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.974057] NET: Registered protocol family 1
[ 0.978870] RPC: Registered named UNIX socket transport module.
[ 0.984910] RPC: Registered udp transport module.
[ 0.989637] RPC: Registered tcp transport module.
[ 0.994382] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.001852] bcm2708_gpio: bcm2708_gpio_probe 80802a68
[ 1.008839] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.031012] VFS: Disk quotas dquot_6.6.0
[ 1.035412] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.044960] FS-Cache: Netfs 'nfs' registered for caching
[ 1.051506] NFS: Registering the id_resolver key type
[ 1.056678] Key type id_resolver registered
[ 1.060884] Key type id_legacy registered
[ 1.067858] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.075542] io scheduler noop registered
[ 1.079505] io scheduler deadline registered (default)
[ 1.085095] io scheduler cfq registered
[ 1.090611] BCM2708FB: allocated DMA memory fac00000
[ 1.095668] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.108443] Console: switching to colour frame buffer device 100x30
[ 1.121359] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 1.130775] vc-cma: Videocore CMA driver
[ 1.136622] vc-cma: vc_cma_base = 0x00000000
[ 1.143181] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.150406] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.157837] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.183585] brd: module loaded
[ 1.197377] loop: module loaded
[ 1.203381] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.213999] Loading iSCSI transport class v2.0-870.
[ 1.221717] usbcore: registered new interface driver smsc95xx
[ 1.229491] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.437550] Core Release: 2.80a
[ 1.442547] Setting default values for core params
[ 1.449272] Finished setting default values for core params
[ 1.657148] Using Buffer DMA mode
[ 1.662352] Periodic Transfer Interrupt Enhancement - disabled
[ 1.670105] Multiprocessor Interrupt Enhancement - disabled
[ 1.677562] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.683799] Dedicated Tx FIFOs mode
[ 1.689439] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 1.703271] FIQ FSM acceleration enabled for :
[ 1.703271] Non-periodic Split Transactions
[ 1.703271] Periodic Split Transactions
[ 1.703271] High-Speed Isochronous Endpoints
[ 1.727946] dwc_otg: Microframe scheduler enabled
[ 1.728016] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80401108
[ 1.728025] WARN::hcd_init_fiq:413: FIQ ASM at 0x80401464 length 36
[ 1.728036] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89a000
[ 1.728057] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.728122] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.728162] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.728208] Init: Port Power? op_state=1
[ 1.728212] Init: Power Port (0)
[ 1.728505] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.728516] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.728525] usb usb1: Product: DWC OTG Controller
[ 1.728534] usb usb1: Manufacturer: Linux 4.1.7-v7+ dwc_otg_hcd
[ 1.728543] usb usb1: SerialNumber: bcm2708_usb
[ 1.729496] hub 1-0:1.0: USB hub found
[ 1.729554] hub 1-0:1.0: 1 port detected
[ 1.730037] dwc_otg: FIQ enabled
[ 1.730041] dwc_otg: NAK holdoff enabled
[ 1.730045] dwc_otg: FIQ split-transaction FSM enabled
[ 1.730077] Module dwc_common_port init
[ 1.737219] usbcore: registered new interface driver usb-storage
[ 1.737486] mousedev: PS/2 mouse device common for all mice
[ 1.769474] bcm2835-cpufreq: min=600000 max=900000
[ 1.777134] sdhci: Secure Digital Host Controller Interface driver
[ 1.777137] sdhci: Copyright(c) Pierre Ossman
[ 1.777441] mmc-bcm2835 mmc-bcm2835.0: mmc_debug:0 mmc_debug2:0
[ 1.777450] mmc-bcm2835 mmc-bcm2835.0: DMA channels allocated
[ 1.813440] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.813851] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.814025] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.814282] usbcore: registered new interface driver usbhid
[ 1.814285] usbhid: USB HID core driver
[ 1.814607] Initializing XFRM netlink socket
[ 1.814644] NET: Registered protocol family 17
[ 1.814829] Key type dns_resolver registered
[ 1.815289] Registering SWP/SWPB emulation handler
[ 1.816270] registered taskstats version 1
[ 1.816543] vc-sm: Videocore shared memory driver
[ 1.816555] [vc_sm_connected_init]: start
[ 1.827279] [vc_sm_connected_init]: end - returning 0
[ 1.923438] Indeed it is in host mode hprt0 = 00021501
[ 1.988375] Waiting for root device /dev/mmcblk0p2...
[ 1.994619] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.998097] mmc0: new high speed SDHC card at address aaaa
[ 1.998750] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[ 2.020082] mmcblk0: p1 p2
[ 2.093341] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.101820] Indeed it is in host mode hprt0 = 00001101
[ 2.155859] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.173397] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.182252] devtmpfs: mounted
[ 2.187874] Freeing unused kernel memory: 416K (80776000 - 807de000)
[ 2.323786] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.332562] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.343014] hub 1-1:1.0: USB hub found
[ 2.348967] hub 1-1:1.0: 5 ports detected
[ 2.633415] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.753897] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.763007] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.776579] smsc95xx v1.0.4
[ 2.847829] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:98:80:a4
[ 2.943366] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.054101] usb 1-1.2: New USB device found, idVendor=0409, idProduct=005a
[ 3.064109] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.074900] hub 1-1.2:1.0: USB hub found
[ 3.081524] hub 1-1.2:1.0: 4 ports detected
[ 3.183451] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.305216] usb 1-1.3: New USB device found, idVendor=7392, idProduct=7811
[ 3.314865] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.324695] usb 1-1.3: Product: 802.11n WLAN Adapter
[ 3.332257] usb 1-1.3: Manufacturer: Realtek
[ 3.340016] usb 1-1.3: SerialNumber: 00e04c000001
[ 3.383809] udevd[175]: starting version 175
[ 3.393448] usb 1-1.2.4: new low-speed USB device number 6 using dwc_otg
[ 3.601440] usb 1-1.2.4: New USB device found, idVendor=046d, idProduct=c318
[ 3.613501] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.623591] usb 1-1.2.4: Product: Logitech Illuminated Keyboard
[ 3.632014] usb 1-1.2.4: Manufacturer: Logitech
[ 3.682802] input: Logitech Logitech Illuminated Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/0003:046D:C318.0001/input/input0
[ 3.753859] hid-generic 0003:046D:C318.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech Logitech Illuminated Keyboard] on usb-bcm2708_usb-1.2.4/input0
[ 3.806516] input: Logitech Logitech Illuminated Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.1/0003:046D:C318.0002/input/input1
[ 3.891150] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 3.894154] hid-generic 0003:046D:C318.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Logitech Logitech Illuminated Keyboard] on usb-bcm2708_usb-1.2.4/input1
[ 3.948806] input: Logitech Logitech Illuminated Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.2/0003:046D:C318.0003/input/input2
[ 3.971937] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x3f204000 (irq 80)
[ 3.974225] hid-generic 0003:046D:C318.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech Logitech Illuminated Keyboard] on usb-bcm2708_usb-1.2.4/input2
[ 4.003409] bcm2708_i2c_init_pinmode(1,2)
[ 4.036406] bcm2708_i2c_init_pinmode(1,3)
[ 4.102149] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 4.347173] random: nonblocking pool is initialized
[ 4.486381] pcm512x 1-004d: Failed to reset device: -5
[ 4.506143] pcm512x: probe of 1-004d failed with error -5
[ 4.536521] wm8804 1-003b: Failed to read device ID: -5
[ 4.548792] wm8804: probe of 1-003b failed with error -5
[ 4.558712] pcm512x 1-004c: Failed to reset device: -5
[ 4.567753] pcm512x: probe of 1-004c failed with error -5
[ 4.632470] usbcore: registered new interface driver rtl8192cu
[ 7.098457] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.467283] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 8.004212] i2c /dev entries driver
[ 12.507473] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 19.662608] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
[ 20.669298] rtc-ds1307 1-0068: rtc core: registered ds1307 as rtc0
[ 20.669347] rtc-ds1307 1-0068: 56 bytes nvram
[ 20.669426] i2c i2c-1: new_device: Instantiated device ds1307 at 0x68
[ 23.021777] uart-pl011 dev:f1: no DMA platform data
[ 32.158881] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 32.227102] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 80.610611] rtc-ds1307 1-0068: rtc core: registered ds1307 as rtc0
[ 80.610659] rtc-ds1307 1-0068: 56 bytes nvram
[ 80.619219] i2c i2c-1: Failed to register i2c client ds1307 at 0x68 (-16)
[ 80.734210] rtc-ds1307 1-0068: rtc core: registered ds1307 as rtc0
[ 80.734246] rtc-ds1307 1-0068: 56 bytes nvram
[ 80.740499] i2c i2c-1: Failed to register i2c client ds1307 at 0x68 (-16)
After 18 hours of tedious research and experiments I have recovered evidence.
I have changed the Debian Image!
NOT WORKING!!!
My first OS Installation was:
Raspbian Wheezy
Based on Debian Wheezy
Version: May 2015
Release date: 2015-05-05
Kernel version: 3.18
https://downloads.raspberrypi.org/raspb ... wheezy.zip
to:
WORKING !!!
NOOBS
Offline and network install
Version: 1.4.2
Release date: 2015-09-24
https://downloads.raspberrypi.org/NOOBS_latest
https://www.raspberrypi.org/downloads/noobs/
Both Linux version are the same:
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 4.1.7-v7+
I can't belive it. I installed NOOB Raspian system, without update, without upgrade or other things and the touch works.
Thanks for steal my time!
NOT WORKING!!!
Raspbian Wheezy
Version: May 2015
to:
WORKING !!!
NOOBS
Version: 1.4.2
Not exactly the same. You can see from the u ame output that you are running a 4.1 kernel version while wheezy is 3.8 in the image, so I expect that you are using Jessie which worked.
I have followed your steps! But no good news for http://www.waveshare.com/10.1inch-Capac ... -LCD-D.htm! Any suggestion is really appreciated!
Embedded System, Robotics Engineer
Totally off-topic as it's not the same display and this thread is almost a year old. I see you have now started your own new thread.Dewsworld wrote:I have followed your steps! But no good news for http://www.waveshare.com/10.1inch-Capac ... -LCD-D.htm! Any suggestion is really appreciated!
Thankyou.
What do I do if I get it working and then after a couple of days I get a black screen when I try to boot it again? I've tried hooking it up to a monitor and then it works and I update and upgrade in the terminal, however it still doesn't work. Then if I reimage the SD card it works fine. I don't like doing with my screen because then it makes me have to spend time trying to get all the packages I want reinstalled. I have a raspberry pi 7" touchscreen and I've been using a raspberry pi B+ 1 and a raspberry pi 2. So if you can tell me how to get it to work and not have to redo everything every time that would be great.
- DougieLawson
- Contact: Website Twitter
1. Check the ribbon cable between the RPi and the display blue side to the outside edge of the RPi, blue side down on the display.
2. Pull off the blue and yellow jumpers, they aren't needed with A+, B+, 2B, 2+ or 3B.
3. Make sure the display has power (black jumper on pin#6, red jumper on pin#2 or pin#4 on your RPi)
I have a touch screen too and it was working just fine with my RPi3. Yesterday i formatted the SD Card with the new release of NOOBS and... Touch screen not working, WiFi not working (does not recognize my password, only works with a free access), the OS list can't be displayed... Is this happening with anyone else or just me?
How can i fix it?
(without going back to NOOBS 1.9)
Thanx
How can i fix it?
Thanx
- DougieLawson
Try again. It looks like you've messed up getting NOOBS onto the (reformatted) SDCard, because it works for everyone else.erika_souza wrote:I have a touch screen too and it was working just fine with my RPi3. Yesterday i formatted the SD Card with the new release of NOOBS and... Touch screen not working, WiFi not working (does not recognize my password, only works with a free access), the OS list can't be displayed... Is this happening with anyone else or just me?
How can i fix it?
Thanx
