I've read this (entire) post, but i haven't undestood what is armhf. Is this a special set of instructions needed by compilers with FPU support?
Sorry for this "newbie" post.....
Look an aweful lot like this bug - http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=515979jerry.tk wrote:4. I took armhf efikamx netboot installer image and basically reassembled it using Raspbian udebs (and some debs as well). The installer starts working fine but fails later when installing base system files. See example log here: http://pastebin.com/sbpKtgbe
There are some unmet dependencies when debootstrapping system and I am not sure where to go from here.
Priority of libsigc++-1.2-dev package is "important", but the FTP archive
overrides this to "optional".
The result of this is that unless dak has made its magic, debootstrap will
try to install libsigc++-1.2-dev, and fail because libstdc++-dev is not
present.
Could you tell us which ones?jerry.tk wrote: 3. Compiling debian-installer on RasPi didn't work as of yesterday because of some missing udebs.
The libsigc++-1.2-dev issue should be fixed now. Please tell us if you still have problems.4. I took armhf efikamx netboot installer image and basically reassembled it using Raspbian udebs (and some debs as well). The installer starts working fine but fails later when installing base system files. See example log here: http://pastebin.com/sbpKtgbe
Sure! I have sent it in PM to Mike the other day but it was probably not so good idea since he was out in the big room with blue ceilingplugwash wrote:Could you tell us which ones?jerry.tk wrote: 3. Compiling debian-installer on RasPi didn't work as of yesterday because of some missing udebs.
Cool, thanks! I will test that today.The libsigc++-1.2-dev issue should be fixed now. Please tell us if you still have problems.4. I took armhf efikamx netboot installer image and basically reassembled it using Raspbian udebs (and some debs as well). The installer starts working fine but fails later when installing base system files. See example log here: http://pastebin.com/sbpKtgbe
We did find it eventually! Raspbian now has it's own forummpthompson wrote:If someone involved with the creation/management of the Raspberry Pi Forums comes across this message...
Thank you, thank you, thank you. We can now stretch out our legs a little.scep wrote:We did find it eventually! Raspbian now has it's own forum
Have you set "vm.min_free_kbytes = 8192" in /etc/sysctl.conf ?mkopack wrote:2) I did the install of all the supporting stuff as indicated on the http://www.raspbian.org/HexxehImages page. I then installed midori. When trying to load a page, at random times, the entire system will completely lock up - no response, no mouse, no keyboard, no nothing. I've let it sit there for 10 minutes hoping it was just a pause caused by processing but nope. Had to power cycle.
I got that as well - adding 'vm.min_free_kbytes = 8192' to /etc/sysctl.conf and rebooting seemed to fix that.grumpyoldgit wrote:I'm just looking at your third issue. My screen has gone completely mad. Scrolling at an amazing speed and cannot read a thing. It is definitely the same pattern repeating itself. I was at tasksel install standard. I had had the silver bar on a blue screen installing software for a long time then the screen went haywire. I will do the command again to see what happens.
Unfortunately, I don't have Raspberry Pi hardware yet to look into these issues, but with CargoCult's help I should be getting my hands one within the next two days. In the meantime I hope others that already have hardware can help give you suggestions to overcome these issues.mkopack wrote:Ideas???
mpthompson wrote:Unfortunately, I don't have Raspberry Pi hardware yet to look into these issues, but with CargoCult's help I should be getting my hands one within the next two days. In the meantime I hope others that already have hardware can help give you suggestions to overcome these issues.mkopack wrote:Ideas???
Often, when trying to track down these problems it's best to log in with ssh from a client such as Putty where you can capture and copy the fault information as it scrolls by. A look at the errors messages will help go a long ways to figuring out what makes the Pi so unhappy when installing new packages.
I see. I'll see what I can find out about diverting system console information to an ssh connection to aid in diagnosing these types of issues. It can be very frustrating to see such information scroll by too fast to figure out what the heck it's doing. Perhaps someone knows this offhand.mkopack wrote:Actually, the last time it happened before I gave up last night, was while I was trying to do the Apt-get install to install the packages needed for installing ROS. I was doing that via SSH into the RPi and the output came up on the RPi's console (which I had up on my other monitor) NOT on the SSH connection, so I couldn't have captured it.
Attempting to restart resulted in tasksel: apptitude failed (255)grumpyoldgit wrote:I'm just looking at your third issue. My screen has gone completely mad. Scrolling at an amazing speed and cannot read a thing. It is definitely the same pattern repeating itself. I was at tasksel install standard. I had had the silver bar on a blue screen installing software for a long time then the screen went haywire. I will do the command again to see what happens.
cp: cannot create regular file ' /opt/vc/sbin/vcfiled': text file is busy
