tuvok
Kodi 15.1 on Raspbian "stretch"
Sat Sep 26, 2015 3:04 pm
Hello, can anybody help?
/usr/lib/kodi/kodi-xrandr: Failed to get size of gamma for output default
libEGL warning: DRI2: failed to authenticate
Segmentation fault (core dumped)
Crash report available at /home/pi/kodi_crashlog-20150925_135641.log
cat kodi_crashlog-20150925_135641.log
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fr 25. Sep 13:56:41 CEST 2015
Kodi Options:
Arch: armv6l
Kernel: Linux 4.1.7+ #817 PREEMPT Sat Sep 19 15:25:36 BST 2015
Release: Raspbian GNU/Linux
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/pi/core (2015-09-25 13:56:38.763614858 +0200)
[New LWP 1171]
[New LWP 1179]
[New LWP 1181]
[New LWP 1182]
[New LWP 1183]
[New LWP 1184]
[New LWP 1186]
[New LWP 1185]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 strlen () at ../ports/sysdeps/arm/armv6/strlen.S:26
[Current thread is 1 (Thread 0xb0626000 (LWP 1171))]
Thread 8 (Thread 0xa98ff2f0 (LWP 1185)):
#0 __GI_strstr (haystack_start=0xabc860cc "/devices/virtual/bdi/8:0", needle_start=0xb5ac82e8 "/block/md") at strstr.c:64
#1 0xb5abfaec in ?? () from /lib/arm-linux-gnueabihf/libudev.so.1
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 7 (Thread 0xa90ff2f0 (LWP 1186)):
#0 0xb67dbb48 in __pthread_cond_timedwait (cond=0xa90feb88, mutex=0xa90febc0, abstime=0xa90fead4) at pthread_cond_timedwait.c:199
#1 0x00c758f8 in XbmcThreads::CEventGroup::wait(unsigned int) ()
#2 0x009b2df4 in CRemoteControl::Process() ()
#3 0x00c774d4 in CThread::Action() ()
#4 0x00c777b8 in CThread::staticThread(void*) ()
#5 0xb67d6ea4 in start_thread (arg=0xa90ff2f0) at pthread_create.c:311
Backtrace stopped: Cannot access memory at address 0x3032312e
Thread 6 (Thread 0xaa1ff2f0 (LWP 1184)):
#0 0xb67dbb48 in __pthread_cond_timedwait (cond=0x15a6c30, mutex=0x15a6c68, abstime=0xaa1fec4c) at pthread_cond_timedwait.c:199
#1 0x00c031a8 in PERIPHERALS::CPeripheralBus::Process() ()
#2 0x00c774d4 in CThread::Action() ()
#3 0x00c777b8 in CThread::staticThread(void*) ()
#4 0xb67d6ea4 in start_thread (arg=0xaa1ff2f0) at pthread_create.c:311
#5 0xb445b178 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 5 (Thread 0xaa9ff2f0 (LWP 1183)):
#0 0xb67dbb48 in __pthread_cond_timedwait (cond=0x1479530, mutex=0x1479508, abstime=0xaa9feca4) at pthread_cond_timedwait.c:199
#1 0xab392de0 in CEC::CCECClient::Process() () from /usr/lib/arm-linux-gnueabihf/libcec.so.3
#2 0xab396a10 in PLATFORM::CThread::ThreadHandler(void*) () from /usr/lib/arm-linux-gnueabihf/libcec.so.3
#3 0xb67d6ea4 in start_thread (arg=0xaa9ff2f0) at pthread_create.c:311
Backtrace stopped: Cannot access memory at address 0x16
Thread 4 (Thread 0xab1ff2f0 (LWP 1182)):
#0 0xb4453b2c in ioctl () at ../sysdeps/unix/syscall-template.S:81
#1 0xb5d71138 in ?? () from /usr/lib/arm-linux-gnueabihf/libasound.so.2
Thread 3 (Thread 0xabbff2f0 (LWP 1181)):
#0 0xb67dbb48 in __pthread_cond_timedwait (cond=0x14217d8, mutex=0x1421810, abstime=0xabbfec4c) at pthread_cond_timedwait.c:199
#1 0x004f1934 in ActiveAE::CActiveAE::Process() ()
#4 0xb67d6ea4 in start_thread (arg=0xabbff2f0) at pthread_create.c:311
Thread 2 (Thread 0xac5582f0 (LWP 1179)):
#0 0xb4451780 in poll () at ../sysdeps/unix/syscall-template.S:81
#1 0x009cc004 in CFDEventMonitor::Process() ()
#4 0xb67d6ea4 in start_thread (arg=0xac5582f0) at pthread_create.c:311
Thread 1 (Thread 0xb0626000 (LWP 1171)):
#1 0x00905eb4 in CRenderSystemGLES::InitRenderSystem() ()
#2 0x0085e3a4 in CApplication::InitWindow() ()
#3 0x00861630 in CApplication::CreateGUI() ()
#4 0x00904828 in XBMC_Run ()
#5 0x0027c428 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
13:56:34 T:2959237120 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:56:34 T:2959237120 NOTICE: -----------------------------------------------------------------------
13:56:34 T:2959237120 NOTICE: Starting Kodi from Debian (15.1 Git: (unknown)). Platform: Linux ARM 32-bit
13:56:34 T:2959237120 NOTICE: Using Debug Kodi from Debian x32 build
13:56:34 T:2959237120 NOTICE: Kodi from Debian compiled from 15.1+dfsg1-3 by GCC 5.2.1 for Linux ARM 32-bit version 3.16.7 (200711)
13:56:34 T:2959237120 NOTICE: Running on Raspbian GNU/Linux stretch/sid testing, kernel: Linux ARM 32-bit version 4.1.7+
13:56:34 T:2959237120 NOTICE: FFmpeg version: 2.7.2-2+b1
13:56:34 T:2959237120 NOTICE: Host CPU: ARMv6-compatible processor rev 7 (v6l), 1 core available
13:56:34 T:2959237120 NOTICE: ARM Features: Neon disabled
13:56:34 T:2959237120 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
13:56:34 T:2959237120 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
13:56:34 T:2959237120 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
13:56:34 T:2959237120 NOTICE: special://home/ is mapped to: /home/pi/.kodi
13:56:34 T:2959237120 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
13:56:34 T:2959237120 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
13:56:34 T:2959237120 NOTICE: Local hostname: raspberrypi
13:56:34 T:2959237120 NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
13:56:34 T:2959237120 DEBUG: UPower: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
13:56:34 T:2959237120 DEBUG: DeviceKit.Power: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
13:56:34 T:2959237120 INFO: Selected Logind/UPower as PowerSyscall
13:56:34 T:2959237120 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
13:56:34 T:2959237120 INFO: LogindUPowerSyscall - UPower not found, battery information will not be available
13:56:34 T:2959237120 DEBUG: LogindUPowerSyscall - inhibit lock taken, fd 11
13:56:34 T:2959237120 NOTICE: load settings...
13:56:34 T:2959237120 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
13:56:34 T:2959237120 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/linux.xml
13:56:34 T:2959237120 ERROR: PulseAudio: Failed to connect context
13:56:34 T:2959237120 NOTICE: PulseAudio might not be running. Context was not created.
13:56:34 T:2891285232 NOTICE: Thread FDEventMonitor start, auto delete: false
13:56:34 T:2959237120 INFO: CAESinkALSA - Unable to open device "surround71" for playback
13:56:34 T:2959237120 INFO: CAESinkALSA - Unable to open device "surround51" for playback
13:56:34 T:2959237120 INFO: CAESinkALSA - Unable to open device "surround40" for playback
13:56:35 T:2959237120 NOTICE: Found 1 Lists of Devices
13:56:35 T:2959237120 NOTICE: Enumerated ALSA devices:
13:56:35 T:2959237120 NOTICE: Device 1
13:56:35 T:2959237120 NOTICE: m_deviceName : @
13:56:35 T:2959237120 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
13:56:35 T:2959237120 NOTICE: m_displayNameExtra:
13:56:35 T:2959237120 NOTICE: m_deviceType : AE_DEVTYPE_PCM
13:56:35 T:2959237120 NOTICE: m_channels : FL,FR
13:56:35 T:2959237120 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
13:56:35 T:2959237120 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
13:56:35 T:2959237120 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
13:56:35 T:2959237120 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
13:56:35 T:2959237120 NOTICE: Default DVD Player: dvdplayer
13:56:35 T:2959237120 NOTICE: Default Video Player: dvdplayer
13:56:35 T:2959237120 NOTICE: Default Audio Player: paplayer
13:56:35 T:2959237120 NOTICE: Disabled debug logging due to GUI setting. Level 0.
13:56:35 T:2959237120 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
13:56:35 T:2959237120 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:56:35 T:2959237120 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
13:56:35 T:2959237120 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
13:56:35 T:2959237120 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
13:56:35 T:2959237120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
13:56:35 T:2959237120 NOTICE: Loaded playercorefactory configuration
13:56:35 T:2959237120 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:56:35 T:2959237120 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:56:35 T:2959237120 INFO: creating subdirectories
13:56:35 T:2959237120 INFO: userdata folder: special://masterprofile/
13:56:35 T:2959237120 INFO: recording folder:
13:56:35 T:2959237120 INFO: screenshots folder:
13:56:35 T:2881483504 NOTICE: Thread ActiveAE start, auto delete: false
13:56:35 T:2870997744 NOTICE: Thread AESink start, auto delete: false
13:56:35 T:2870997744 INFO: CActiveAESink::OpenSink - initialize sink
13:56:35 T:2870997744 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:@
13:56:35 T:2870997744 INFO: CAESinkALSA::Initialize - Attempting to open device "@"
13:56:35 T:2870997744 INFO: CAESinkALSA::Initialize - Opened device "sysdefault"
13:56:35 T:2870997744 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
13:56:35 T:2870997744 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
13:56:35 T:2870997744 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2205, bufferSize 8820
13:56:35 T:2870997744 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2204, bufferSize 8820
13:56:35 T:2870997744 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
13:56:35 T:2870997744 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
13:56:35 T:2870997744 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR
13:56:35 T:2870997744 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: none)
13:56:35 T:2870997744 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
13:56:35 T:2870997744 DEBUG: Output Device : Default (bcm2835 ALSA bcm2835 ALSA)
13:56:35 T:2870997744 DEBUG: Sample Rate : 44100
13:56:35 T:2870997744 DEBUG: Sample Format : AE_FMT_S16NE
13:56:35 T:2870997744 DEBUG: Channel Count : 2
13:56:35 T:2870997744 DEBUG: Channel Layout: FL,FR
13:56:35 T:2870997744 DEBUG: Frames : 2204
13:56:35 T:2870997744 DEBUG: Frame Samples : 4408
13:56:35 T:2870997744 DEBUG: Frame Size : 4
13:56:35 T:2959237120 NOTICE: Running database version Addons19
13:56:35 T:2959237120 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-arm.so)
13:56:35 T:2959237120 DEBUG: Loading: /usr/lib/kodi/system/libcpluff-arm.so
13:56:35 T:2959237120 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/kodi/addons: No such file or directory'
13:56:35 T:2959237120 NOTICE: ADDONS: Using repository repository.xbmc.org
13:56:35 T:2959237120 DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
13:56:35 T:2959237120 DEBUG: LoadMappings - loaded node "CEC Adapter"
13:56:35 T:2959237120 DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
13:56:35 T:2959237120 DEBUG: LoadMappings - loaded node "iMON HID device"
13:56:35 T:2959237120 DEBUG: CPeripheralBusUSB - initialised udev monitor
13:56:35 T:2959237120 DEBUG: SECTION:LoadDLL(libcec.so.3)
13:56:35 T:2959237120 DEBUG: Loading: libcec.so.3
13:56:36 T:2854220528 NOTICE: Thread PeripBusCEC start, auto delete: false
13:56:37 T:2844783344 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
13:56:37 T:2836394736 NOTICE: Thread RemoteControl start, auto delete: false
13:56:37 T:2836394736 INFO: LIRC Process: using: /dev/lircd
13:56:37 T:2836394736 INFO: LIRC Connect: connect failed: No such file or directory
13:56:37 T:2836394736 INFO: CRemoteControl::Process - failed to connect to LIRC, will keep retrying every 5 seconds
13:56:37 T:2959237120 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
13:56:37 T:2959237120 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
13:56:37 T:2959237120 DEBUG: Selected UDisks as storage provider
13:56:37 T:2959237120 DEBUG: UDisks: DaemonVersion 1
13:56:37 T:2959237120 DEBUG: UDisks: Querying available devices
13:56:37 T:2959237120 INFO: UDisks: Added /media/pi/OPENELEC
13:56:38 T:2959237120 INFO: Available videomodes (xrandr):
13:56:38 T:2959237120 INFO: Output 'default' has 1 modes
13:56:38 T:2959237120 INFO: ID:0xe8 Name:1360x768 Refresh:0.000000 Width:1360 Height:768
13:56:38 T:2959237120 INFO: Pixel Ratio: 1.000000
13:56:38 T:2959237120 NOTICE: Checking resolution 16
13:56:38 T:2959237120 ERROR: Failed to choose a config 12288
13:56:38 T:2959237120 ERROR: Failed to query native visual id
13:56:38 T:2959237120 ERROR: Failed to find matching visual
13:56:38 T:2959237120 INFO: GLES: Maximum texture width: 2048
13:56:38 T:2959237120 DEBUG: EGL_EXTENSIONS: EGL_MESA_configless_context EGL_KHR_get_all_proc_addresses EGL_KHR_surfaceless_context
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
tuvok
Re: Kodi 15.1 on Raspbian "stretch"
Tue Sep 29, 2015 5:53 pm
have anybody a Idea what i can do?
dom
Tue Sep 29, 2015 8:35 pm
The upstream debian build of kodi will be a generic build with no raspberry pi support. E.g. it will try to use X and desktop OpenGL (rather than OpenGL ES). It won't work.
You need a build built for raspberry pi (and that won't come from debian or raspbian).
The raspberrypi repo has a build, but it is only currently kodi 14. There are some custom kodi 15 builds around.
tuvok
Wed Sep 30, 2015 11:35 am
Hello. and thanks for the answer.. so why is this on my raspbian?
apt-cache policy kodi
kodi:
Installiert: 15.1+dfsg1-3
Installationskandidat: 15.1+dfsg1-3
Versionstabelle:
*** 15.1+dfsg1-3 0
500 http://mirrordirector.raspbian.org/raspbian/ stretch/main armhf Packages
100 /var/lib/dpkg/status
gives custom builds for kodi 15.1 for the raspberry Pi 1 B+
ohjays
Tue Oct 20, 2015 7:12 pm
I recently switched mirror to testing from jessie, and am experiencing the exact same problem, i made the switch to get access to kodi ( recent ).
abioneperhobby
Mon Mar 28, 2016 8:58 pm
i have the same problem installing kodi starting from lubuntu on a raspberry pi 3.
i also tried to give 256 of gpu memory as described there viewtopic.php?f=66&t=139723 but nothing changed.
can i ask for advice here or i should move on ubuntu forum?
thanks.
Return to “Raspbian”
