maurice1
MCP23017, how to: 8 inputs and 8 outputs
Thu Sep 17, 2015 8:38 am
I wanted to get 8 inputs on Bank A to control 8 Relays on bank B
I am using 5.6 metres of catV cable without problems
Thanks to: DougieLawson, Davidjlittle, ericcnc, techpaul, rpmines, nathanchantrell for their inspiration
For this to work you need to make a folder mcp23017 under your pi folder and put
https://github.com/nathanchantrell/Pyth ... cp23017.py in it .
import smbus
import sys
import os
import time
DEVICE = 0x20
bankA = 0x12
bankB = 0x13
delay = 1
bus = smbus.SMBus(1)
bus.write_byte_data(DEVICE,bankB,0xff) # set B7-B0 as output pins high
def int_to_binary_bool(num):
        return [bool(int(i)) for i in "{0:08b}".format(num)]
while True:
	bus.write_byte_data(DEVICE,0x00,0xff) # set A7-A0 as input pins
	bus.write_byte_data(DEVICE,0x01,0x00) # set B7-B0 as output pins
	bus.write_byte_data(DEVICE,0x0C,0xff) #Int pullup resistor on bankA
	input = bus.read_byte_data(DEVICE,bankA)
	MY1 = int_to_binary_bool(input)
	print
	A0 = MY1[0]
	print "A0", A0
	A1 = MY1[1]
	print "A1", A1
	A2 = MY1[2]
	print "A2", A2
	A3 = MY1[3]
	print "A3", A3
	A4 = MY1[4]
	print "A4", A4
	A5 = MY1[5]
	print "A5", A5
	A6 = MY1[6]
	print "A6", A6
	A7 = MY1[7]
	print "A7", A7
	if A0 is False:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 0 -s low") #BankB0 low
	if A0 is True:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 0 -s high")#BankB0 high
	if A1 is False:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 1 -s low")
	if A1 is True:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 1 -s high")
	if A2 is False:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 2 -s low")
	if A2 is True:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 2 -s high")
	if A3 is False:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 3 -s low")
	if A3 is True:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 3 -s high")
	if A4 is False:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 4 -s low")
	if A4 is True:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 4 -s high")
	if A5 is False:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 5 -s low")
	if A5 is True:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 5 -s high")
	if False in MY1:        #pump
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 6 -s low")
	if False not in MY1:
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 6 -s high")
	if False in MY1:        #Boiler
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 7 -s low")   #BankB7 low
		os.system("/home/pi/mcp23017/mcp23017.py -b b -o 7 -s high")  #BankB7 high
	time.sleep(delay)
If thermostat A0 goes low, it will switch relays B0, B6 and B7 on.
I am sure this code could be written better but I am just learning.
I hope it saves someone some time
Massi
Re: MCP23017, how to: 8 inputs and 8 outputs
Thu Sep 17, 2015 10:00 am
damn, this is so ugly :(
a python script running another python script through a system call :(
why didn't you use one of the dozilion of classes to manage mcp23017?
scotty101
Thu Sep 17, 2015 10:37 am
Agreed! This should not be used as a good example of how to connect python to a MCP23017.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
Massi
Thu Sep 17, 2015 11:39 am
even the logic is not that good:
- you are setting up the chip at every loop (a big waste of i2c calls)
- you can miss some input with that sleep (what if the input is shorter than 1 second?).
i haven't even understood the last part of the program..
Definitely I'd have used 1) a class to manage all 2) the interrupt pin of the MCP to avoid a lot of useless i2c calls
maurice1
Thu Sep 17, 2015 12:57 pm
Thankyou scotty101 and Massi for your replies.
As I mentioned "I am sure this code could be written better but I am just learning.", so I wasn't going for pretty code just one that works.
@ Massi"what if the input is shorter than 1 second?",
"If thermostat A0 goes low" is unlightly to change with in the 1 second as room temperature doesn't change that quick.
Perhaps as both of you find this code so "UGLY" , each of you would be kind enough to write pretty code that:
A1 going Low, energises B1 solonoid,+B6 pump,+B7 Boiler
A2 going Low, energises B2 solonoid,+B6 pump,+B7 Boiler
etc....
and that the code is easily readable....
Thu Sep 17, 2015 9:48 pm
I'd do that with an array of desired states that you pass to a function to set those states (by OR'ing the value with the current GPIOB register) or resets the states (by AND'ing with 0xFF - the bit that needs to be reset).
Here's a piece of code to get you started with that logic
#!/usr/bin/python
# (C) 2015 Copyright Dougie Lawson, All rights reserved
# Version 0.5
import smbus
ADDR = 0x20
IODIRA = 0x00
IODIRB = 0x01
GPIOA = 0x12
GPIOB = 0x13
OLATA = 0x14
OLATB = 0x15
bus=smbus.SMBus(1)
bus.write_byte_data(ADDR,IODIRA,0x00)
bus.write_byte_data(ADDR,IODIRB,0x00)
global valueA
global valueB
valueA=0
valueB=0
def pinOff(bank, pin):
#  print (bank,  pin, "== ON")
  global valueA
  global valueB
  bit = pin - 1
  if bank == 'top':
    valueB = valueB | (1 << bit)
    bus.write_byte_data(ADDR, OLATB, valueB)
  else:
    valueA = valueA | (1 << bit)
    bus.write_byte_data(ADDR, OLATA, valueA)
def pinOn(bank, pin):
#  print (bank, pin, "== OFF")
  global valueA
  global valueB
  bit = pin - 1
  if (bank == 'top'):
    valueB = valueB & (0xff - (1 << bit))
  else:
    valueA = valueA & (0xff - (1 << bit))
def pinStatus(bank, pin):
  global valueA
  global valueB
  bit = pin - 1
  if (bank == 'top'):
    state = ((valueB&(1<<bit))!=0)
  else:
    state = ((valueA&(1<<bit))!=0)
  return state
def pinAllOff():
#  print "All off called"
  global valueA
  global valueB
  valueA = 0xFF
  valueB = 0xFF
Note: it's currently set-up for "active low" because the relay board I was using had inverters on all eight channels.
