Raspbmc public beta announced.
Discussion on the developers forum here.
Depends which xbmc build you were using. I've only used raspbmc's test build on the debian image which was a lot more responsive than the equivalent openelec build a few days ago. This is as responsive as that one if not more with the added bonus of streaming plugins working now and being quite responsive themselves especially the one for the bbc iplayer which was very slow on the openelec builds when scraping the web site.abishur wrote:How does it stand up to using xbmc on the debian image?
Oh, I consider the openELEC to be a different entity from straight XBMC (or raspbmc now for that matterwelshblob wrote:Depends which xbmc build you were using. I've only used raspbmc's test build on the debian image which was a lot more responsive than the equivalent openelec build a few days ago. This is as responsive as that one if not more with the added bonus of streaming plugins working now and being quite responsive themselves especially the one for the bbc iplayer which was very slow on the openelec builds when scraping the web site.abishur wrote:How does it stand up to using xbmc on the debian image?
Rob
openelec and raspbmc are similar in that they are very much distros for xbmc although implemented in different ways with differing strategies. The challenge is to work out whether issues are distro or xbmc related or just fundamental limitations of the device. Hence why I'm comparing them. The good news is though is that from what I've seen over the past week xbmc is a very good fit for the pi and I intend to be buying more when I can.abishur wrote:Oh, I consider the openELEC to be a different entity from straight XBMC (or raspbmc now for that matterwelshblob wrote:Depends which xbmc build you were using. I've only used raspbmc's test build on the debian image which was a lot more responsive than the equivalent openelec build a few days ago. This is as responsive as that one if not more with the added bonus of streaming plugins working now and being quite responsive themselves especially the one for the bbc iplayer which was very slow on the openelec builds when scraping the web site.abishur wrote:How does it stand up to using xbmc on the debian image?
Rob)
Make sure you have "analogue(OMX)" enabled as audio output device (as well as analogue setting at top of screen).RussIT wrote:is there anything i need to do to enble the analog audio output? At the moment I have output set to analog but have no sound just video on all the files i have tried.
Wouldn't it be better to install from the repository? List of repositories here, the one you want is Hitchers Repo:sam nazarko wrote:To install iPlayer, SSH in:
wget http://xbmc-iplayerv2.googlecode.com/fi ... 2.4.14.zip
Go to XBMC, navigate to:
settings > system > addons > install from ZIP
select /home/pi/iPlayer-v2.4.14.zip
Give it a minute and you will get a notification that it is installed.
Performance on iPlayer seems acceptable.
wget http://dl.dropbox.com/u/19745842/Repo/xbmc.repo.hitcher/xbmc.repo.hitcher-3.0.1.zip
I finally got this to boot on a Transcend 4GB Class 10 SD card using just the Raspbmc supplied firmware - it probably took over 30 minutes for the XBMC GUI to finally appear.LastSilmaril wrote:SD card issues preventing this from booting completely on 2 diff cards. tried switching to stock start.elf, then stock kernel, then both - nothing (0x900), so I guess I'll have to wait to try this...
