Grumpy Mike
How to exit minicom? [obsolete]
Thu Apr 24, 2014 8:40 am
I have minicom 2.6.1 running on the NOBOS Pi distribution.
I have it connected to a bluetooth modem attached to the serial port on the GPIO connector and I am talking to a terminal on my Mac. All works well and I can send text back an forth between the two.
However, minicom does not respond to CTRL-A Z for help nor CTRL-C nor Esc, so how do I quit this program without rebooting the machine?
Joe Schmoe
Re: How to exit minicom?
Thu Apr 24, 2014 8:43 am
Quite so. This is why you shouldn't use minicom. It has the worst user interface - ever!
Among other things, I could never figure out how to get out of it.
Literally, I've never seen a program that tried so hard to make its user interface horrible.
Use "screen" instead. (Seriously, this is not a typo - "screen" works fine as a "com program")
Or Seyon…
redhawk
Thu Apr 24, 2014 8:46 am
Is it not possible to open another virtual console (or remote ssh) and simply login, find the PID and kill it with -9 or -1 -1??
Richard S.
Richard-TX
Thu Apr 24, 2014 8:47 am
Minicom can be a problem if the env variable TERM is not set correctly.
hit enter. then cntl-A then q then enter to exit minicom.
There is also cu if you want bare bones.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
Thu Apr 24, 2014 8:52 am
minicom has the blindingly obvious ctrl a & x to exit.
Whoever created that should be drawn, hanged and quartered and their remains should be left for public inspection in the Tower of London.
Grumpy Mike
Thu Apr 24, 2014 8:56 am
Richard-TX wrote: hit enter. then cntl-A then q then enter to exit minicom.
Thanks this did the trick.
Also this works as well
redhawk
Thu Apr 24, 2014 8:58 am
The key binding may had been deliberate if for example you're accessing a remote shell and need to quit an application without quitting minicom.
Richard S.
Thu Apr 24, 2014 9:02 am
redhawk wrote:The key binding may had been deliberate if for example you're accessing a remote shell and need to quit an application without quitting minicom.
Richard S.
That makes sense, the death sentence can be stayed. It's no different from ctrl [ in telnet to get back to command mode.
joan
Thu Apr 24, 2014 9:40 am
Grumpy Mike wrote:I have minicom 2.6.1 running on the NOBOS Pi distribution.
For future reference
man minicom
gives the answer.
Generally for help on a command try man command
Joe Schmoe
Thu Apr 24, 2014 10:14 am
The advice stands, however, that minicom is a stupid program and one not intended to be used.
apple.pi
Fri Nov 14, 2014 8:20 am
To Exit from minicom: click Ctrl- A, Z then X.
Joe Schmoe
Fri Nov 14, 2014 9:16 am
apple.pi wrote:To Exit from minicom: click Ctrl- A, Z then X.
That might work, but the best advice - the best way to be not in minicom - is not to have run it at all.
inmild
Fri Jul 31, 2015 8:37 am
Try to use:
(Hold down) Ctrl + Shift + a (release then type) z
then big window appeared : Minicom Command Summary
type: q
small window appeared:
Leave without reset? <enter>
hope help others.
danger89
Tue Aug 25, 2015 7:21 pm
Just ctrl+a and then 'x' just works.
Joe Schmoe
Tue Aug 25, 2015 7:53 pm
It needs to be pointed out again that the best way to solve this problem (How do I ensure that I am not in minicom?) is:
# apt-get purge minicom
Viable alternatives include:
  1. Seyon (X GUI)
  2. screen (command line)
KLL
Wed Aug 26, 2015 12:43 am
Joe Schmoe wrote:Seyon
if you are as stupid as me and not get that running,
but still want a serial terminal in Desktop, try
sudo apt-get install cutecom
option:
nano /home/pi/Desktop/cutecom.desktop
[Desktop Entry]
Type=Application
Comment=RPI serial terminal
Name=cutecom
Exec=lxterminal -e 'cutecom'
Terminal=false
Categories=Utility
StartupNotify=true
the dropdown list for devices show only "ttyS.." but you can type in ttyACM0 .. and it will remember it.
looks like
i just install it and it looks as i expect it from a modern ( desktop) tool
but i can not say how good it really is
Return to “Beginners”
