Having got this working, I now want to connect from outside the LAN. I made the 'remote' parameter in my client.conf file my external IP address (i.e. the one I get by googling "My IP address") and forwarded port 1194 to my pi's IP address.
I've got a Huawei 533 router, and my ISP is TalkTalk (I don't know if that's relevant). In the parameters for the port forwarding, I input the following settings:
Interface: nas_0_38 (I could either choose this or ttyUSB)
Protocol: TCP/UDP
External start port: 1194
External end port: 1194
Internal host: [Pi's local IP address]
Internal port: 1194
Mapping name: openvpn.
I followed the guide on http://www.portforward.com.
Upon trying to connect with the new configuration, i.e. via the external IP address, the connection attempt failed. I do wonder if it's because I'm trying to do it from on the same LAN as the server, but that seems unlikely to me.
Here is the error message:
Fri Aug 21 00:42:47 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Aug 21 00:42:47 2015 TLS Error: TLS handshake failed
Fri Aug 21 00:42:47 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Aug 21 00:42:47 2015 Restart pause, 2 second(s)
I'm reluctant to mess around with my firewall, at least without help, mainly because I don't know what I'm doing and I don't know how important a firewall actually is.
My questions are basically:
1) Is the reason I can't connect because port 1194 is closed?
2) Is there a way to open it without messing around with the firewall?
3) If not, in what way do I need to change the firewall and how can I do it safely?
Thanks for helping a complete noob with networking!
