Mine does exactly this and I'd just arrived here to seek an answer too. I'd followed the tutorial and got to the point of it working but udhcpd fails on reboot. Start it manually afterwards and it works just fine. Log extract below -pokrivnik wrote:If you enter "sudo service udhcpd start" It works OK
If you enter "sudo update-rc.d udhcpd enable" does not start after reboot.
May 21 20:39:51 raspberrypi udhcpd[2219]: udhcpd (v1.20.2) started
May 21 20:39:51 raspberrypi udhcpd[2219]: max_leases=235 is too big, setting to 11
May 21 20:39:51 raspberrypi udhcpd[2219]: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
May 21 20:39:51 raspberrypi udhcpd[2219]: is interface wlan0 up and configured?: Cannot assign requested address
May 21 20:39:51 raspberrypi dhcpcd[1977]: wlan0: carrier acquired
May 21 20:39:51 raspberrypi dhcpcd[1977]: all: IPv6 kernel autoconf disabled
May 21 20:39:51 raspberrypi dhcpcd[1977]: wlan0: IAID 60:05:02:af
May 21 20:39:52 raspberrypi ifplugd(wlan0)[1650]: Link beat detected.
May 21 20:39:52 raspberrypi ifplugd(wlan0)[1650]: Executing '/etc/ifplugd/ifplugd.action wlan0 up'.
May 21 20:39:52 raspberrypi ifplugd(wlan0)[1650]: client: /sbin/ifup: interface wlan0 already configured
May 21 20:39:52 raspberrypi ifplugd(wlan0)[1650]: Program executed successfully.
Am I supposed to have udhcpd *and* dhcpcd? I seem to have both. Working backwards up the thread...
