jino
backup and restore apps
Sat Aug 01, 2015 6:36 pm
could you please suggest a tool to back up installed apps eg(libreoffice) to pen drive and restoring it later.
i have tried to download aptik,but failed.thanks ;)
Re: backup and restore apps
Sat Aug 01, 2015 6:43 pm
Do you mean to backup all of the installed files from all directories, or to backup the original install file, or backup any data?
The easiest thing to do is to take a copy of the .deb file that the package was installed from, as that is essentially just a backup of all the files needed, plus package information and some configuration scripts.
You can find the .deb files in /var/cache/apt/archives/ as long as you haven't done an "apt-get clean" to get rid of them.
klricks
Sat Aug 01, 2015 8:14 pm
jino wrote:Hi,
Being vigilant and persistent about making backups of files that you have created with your apps is essential. These files can easily be saved to a USB 'stick' or other network attached storage.
However IMO making backups of installed apps is pointless when it is so easy to uninstall, install or reinstall apps using the normal methods: apt-get commands or using a package manager program.
asandford
Sat Aug 01, 2015 11:09 pm
jino wrote:Hi,
I use the following to backup my PIs to my NAS:
sudo rsync -avz --delete --exclude /sys --exclude /tmp --exclude /proc --exclude /run / pis@omv.local:/PIs/`hostname`/
After the initial run, it's just an incremental and takes no time at all. This will preserves all your config files which reinstalling a package might not do.
jino
Sun Aug 02, 2015 9:46 am
rpdom wrote:Do you mean to backup all of the installed files from all directories, or to backup the original install file, or backup any data?
I want to backup install file for each application.When i go to the var/cache/apt/archives/ folder i can see the files but its all mixed up.It would be nice if i could see packages sorted by the application,so that i can know which one to restore,later.
jino
Sun Aug 02, 2015 9:50 am
klricks wrote:
jino wrote:Hi,
its true but if i do a backup i do not need to type in terminal for each app ,later when re installing ;)
jino
Sun Aug 02, 2015 9:53 am
asandford wrote:
jino wrote:Hi,
Hi ,
i think this backups the whole raspbian image.am i right?
i just need apps to back up/
jino
Sun Aug 02, 2015 9:54 am
update:can i use synaptic package manager for backup?
Sun Aug 02, 2015 10:03 am
jino wrote:
rpdom wrote:You can find the .deb files in /var/cache/apt/archives/ as long as you haven't done an "apt-get clean" to get rid of them.
I don't understand "all mixed up". They have the application in their name. To see the php install files, for example, I would
pi@raspi3 ~ $ cd /var/cache/apt/archives
pi@raspi3 /var/cache/apt/archives $ ls *php*.deb
php5-cli_5.6.9+dfsg-0+deb8u1_armhf.deb
php5-common_5.6.9+dfsg-0+deb8u1_armhf.deb
php5-mysql_5.6.9+dfsg-0+deb8u1_armhf.deb
php-mail_1.2.0-7_all.deb
jino
Sun Aug 02, 2015 6:27 pm
^^^ i mean,for example ,if i want to isolate libre office package files to restore it later, there are a bunch of files like
libreoffice-core_1%3a3.6.1-1+rpi1_armhf
libreoffice-common_1%3a3.6.1-1+rpi1_all
libreoffice-writer_1%3a3.6.1-1+rpi1_armhf
etc..so should i put all files strting with libre office in to a folder?
I dont know how it works , not like .exe files in windows :lol:
kusti8
Sun Aug 02, 2015 6:40 pm
Yes, all of those are packages, so the LibreOffice program is separated into multiple packages.
In the end, you're going to have to install them anyways.
Why not just list all the programs that are installed and apt-get install them again. Much simpler
Sun Aug 02, 2015 6:48 pm
kusti8 wrote:Why not just list all the programs that are installed and apt-get install them again. Much simpler
+1
Especially as all the libreoffice packages may depend on other packages needing to be installed as well.
jino
Mon Aug 03, 2015 7:58 pm
hmm..now it seems better to do apt get rather than installing packages one by one :D ..thanks all
asandford
Tue Aug 04, 2015 6:25 pm
jino wrote: Hi ,
The parameters that I have used do backup the whole image (only once, the next time it runs only the differences will be actioned) but you can alter them to suit your needs, for example just /home/pi for your stuff or /usr for non-core programs (ie files in /bin or /sbin)
jino
Wed Aug 05, 2015 7:07 am
asandford wrote:
jino wrote: Hi ,
hi thats good.So if i want to back up my home folder how do i do it.I understood the last part of the command - its to your NAS.so to back up the home folder to my pendrive ,will the command be like this? sda1 is pendrive
sudo rsync /pi/home -avz --delete --exclude /sys --exclude /tmp --exclude /proc --exclude /run / dev/sda1
JimmyN
Wed Aug 05, 2015 12:02 pm
If you're backing up your home directory there is no need to exclude /sys, /tmp, /proc, and /run as they don't exist in your home directory anyway. I use rsync to create two backups, one is /home only and the other is everything except /home. And if you have a lot of things to exclude, like when backing up the whole system it's easier to use an "exclude" file rather than a lengthy list of excludes in the rsync line.
Mine backs up to a USB flashdrive that is mounted at ~/Desktop/usbdrv. I have two directories on the flashdrive to contain the two backups, "home" and "all".
To back up /home I use this in crontab:
/usr/bin/rsync -a -- delete --exclude-from '/home/pi/exclude-home.txt' /home/pi /home/pi/Desktop/usbdrv/home/
It backs up everything in /home/pi to a USB flashdrive mounted at /Desktop/usbdrv. The "exclude-home.txt" file contains the following:
network-folder
.xsession-errors
/usbdrv/*
lost+found
I exclude the mount point /usbdrv/ where the backup is being written so it won't get into a circular reference and start backing up the backup. I also exclude "network-folder" which is a mounted share from a NAS, no need to back that up on the Pi.
To backup the entire system, except /home I use this in crontab:
/usr/bin/rsync -a --delete --exclude-from '/home/pi/exclude-full.txt' / /home/pi/Desktop/usbdrv/all/
And the "exclude-full.txt" contains the following:
/proc/*
/sys/*
/dev/*
/tmp/*
/run/*
/mnt/*
/media/*
/home/*
fake-hwclock.data
ntp.drift
auth.log
kern.log
lastlog
messages
syslog
wtmp
The "*" tells it to create the directory in the backup, but leave it empty. The first backup will take a while as all the files have to be copied to the backup. After that the daily backup only takes about 20~30 seconds to update, unless I've installed some new software and it has copy a lot of new files.
Wed Aug 05, 2015 2:10 pm
I tend to back up by file system, so when I use rsync I add the -x option, which stops it from backing up /sys, /dev, /proc and others like that. It means my exclude list is minimal.
I actually use the "dump" command to back up most of my systems. It may be old and a bit basic, but it handles incremental backups well and it generally works ok. It has saved me from a lot of bother a few times in the past, like on the couple of occasions when my laptop hard disk failed - new disk, restore from DVD, reset grub, back running in under an hour.
JimmyN
Wed Aug 05, 2015 2:55 pm
Dump is old, I think it's been around since the beginning of the epoch. :D
I still use dump on FreeBSD. It's running a ZFS filesystem so I take a snapshot first, then use dump to backup the snapshot.
For the Pi storage space is a bit more limited, and I don't want to backup log files and such, so I always have an exclude file for rsync anyway.
jino
Wed Aug 05, 2015 7:16 pm
thanks JimmyN for the detailed answer :D
LopezCanepa
Mon Apr 17, 2017 5:05 pm
Hi All,
After the last upgrade of Raspbian, my system failed with no apparent way of recover.
In this events reinstalling flashing the card is not to painful, but it takes some time.
Reinstalling all the software and services is easy as mentioned in this forum, it just takes some time and a list of what you have installed. I normally use four computers, with my Rasberry 3 as server and sync provider.
What is really painful and extremely time consuming (in my case over two days) is to reconfigure all the services, the mail notification of events and getting every thing to work again.
I will now make a copy of my card in a second card, just in case, but i can not stop the server to extract the card to update the changes. However, a better solution to start from scratch.
This is how goggling around i found Aptik, that looked promising, but apparently not available for Raspbian.
If any one would have a good solution to back up and restore all configuration files, please let me know.
Thanks and best regards to all,
Carlos.
Raspberry pi3, 4 ubuntu boxes for engineering work.
Mon Apr 17, 2017 5:44 pm
LopezCanepa wrote:Hi All,
Carlos.
PiClone (included in Raspbian Jessie with Pixel) can make a 'clone' to a SD Card in a USB Card Reader of a 'live' system:
https://github.com/raspberrypi-ui/piclo ... ter/README
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
LopezCanepa
Tue Apr 18, 2017 7:44 pm
That is excellent news, thank you!!
