Bonjour,
merci pour les infos, mais ca ne marche toujours pas, Voici les logs de la console, qu'en pensez-vous?
[email protected]:~# lsmod | grep tun
tun 19734 0
[email protected]:~# modprobe tun
[email protected]:~# find /lib/modules/ -iname 'tun.ko'
/lib/modules/3.18.11-v7+/kernel/drivers/net/tun.ko
/lib/modules/3.18.11+/kernel/drivers/net/tun.ko
[email protected]:~# insmod /lib/modules/3.18.11-v7+/kernel/drivers/net/tun.ko
Error: could not insert module /lib/modules/3.18.11-v7+/kernel/drivers/net/tun.ko: File exists
[email protected]:~# insmod /lib/modules/3.18.11+/kernel/drivers/net/tun.ko
Error: could not insert module /lib/modules/3.18.11+/kernel/drivers/net/tun.ko: Invalid module format
[email protected]:~# ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:22:ca:a6
inet addr:192.168.0.100 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:443 errors:0 dropped:0 overruns:0 frame:0
TX packets:264 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:37680 (36.7 KiB) TX bytes:36108 (35.2 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1104 (1.0 KiB) TX bytes:1104 (1.0 KiB)
Tun0 ne monte toujours pas...
voici le log d'Openvpn si ca peut vous aider à resoudre mon probléme:
Thu Jul 9 06:27:19 2015 us=663372 Current Parameter Settings:
Thu Jul 9 06:27:19 2015 us=663820 config = '/etc/openvpn/client.conf'
Thu Jul 9 06:27:19 2015 us=663930 mode = 0
Thu Jul 9 06:27:19 2015 us=664015 persist_config = DISABLED
Thu Jul 9 06:27:19 2015 us=664098 persist_mode = 1
Thu Jul 9 06:27:19 2015 us=664182 show_ciphers = DISABLED
Thu Jul 9 06:27:19 2015 us=664265 show_digests = DISABLED
Thu Jul 9 06:27:19 2015 us=664345 show_engines = DISABLED
Thu Jul 9 06:27:19 2015 us=664425 genkey = DISABLED
Thu Jul 9 06:27:19 2015 us=664506 key_pass_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=664587 show_tls_ciphers = DISABLED
Thu Jul 9 06:27:19 2015 us=664667 Connection profiles [default]:
Thu Jul 9 06:27:19 2015 us=664751 proto = udp
Thu Jul 9 06:27:19 2015 us=664832 local = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=664914 local_port = 0
Thu Jul 9 06:27:19 2015 us=664995 remote = '176.31.32.106'
Thu Jul 9 06:27:19 2015 us=665076 remote_port = 5353
Thu Jul 9 06:27:19 2015 us=665157 remote_float = DISABLED
Thu Jul 9 06:27:19 2015 us=665238 bind_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=665318 bind_local = DISABLED
Thu Jul 9 06:27:19 2015 us=665400 connect_retry_seconds = 5
Thu Jul 9 06:27:19 2015 us=665481 connect_timeout = 10
Thu Jul 9 06:27:19 2015 us=665562 connect_retry_max = 0
Thu Jul 9 06:27:19 2015 us=665644 socks_proxy_server = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=665728 socks_proxy_port = 0
Thu Jul 9 06:27:19 2015 us=665808 socks_proxy_retry = DISABLED
Thu Jul 9 06:27:19 2015 us=665889 Connection profiles END
Thu Jul 9 06:27:19 2015 us=665969 remote_random = DISABLED
Thu Jul 9 06:27:19 2015 us=666049 ipchange = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=666130 dev = '/dev/net/tun'
Thu Jul 9 06:27:19 2015 us=666211 dev_type = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=666291 dev_node = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=666372 lladdr = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=666452 topology = 1
Thu Jul 9 06:27:19 2015 us=666532 tun_ipv6 = DISABLED
Thu Jul 9 06:27:19 2015 us=666613 ifconfig_local = '10.9.0.2'
Thu Jul 9 06:27:19 2015 us=666694 ifconfig_remote_netmask = '10.9.0.1'
Thu Jul 9 06:27:19 2015 us=666776 ifconfig_noexec = DISABLED
Thu Jul 9 06:27:19 2015 us=666904 ifconfig_nowarn = DISABLED
Thu Jul 9 06:27:19 2015 us=667016 ifconfig_ipv6_local = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=667100 ifconfig_ipv6_netbits = 0
Thu Jul 9 06:27:19 2015 us=667181 ifconfig_ipv6_remote = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=667261 shaper = 0
Thu Jul 9 06:27:19 2015 us=667343 tun_mtu = 1500
Thu Jul 9 06:27:19 2015 us=667423 tun_mtu_defined = ENABLED
Thu Jul 9 06:27:19 2015 us=667503 link_mtu = 1500
Thu Jul 9 06:27:19 2015 us=667584 link_mtu_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=667665 tun_mtu_extra = 0
Thu Jul 9 06:27:19 2015 us=667746 tun_mtu_extra_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=667826 fragment = 0
Thu Jul 9 06:27:19 2015 us=667907 mtu_discover_type = -1
Thu Jul 9 06:27:19 2015 us=667987 mtu_test = 0
Thu Jul 9 06:27:19 2015 us=668067 mlock = DISABLED
Thu Jul 9 06:27:19 2015 us=668148 keepalive_ping = 0
Thu Jul 9 06:27:19 2015 us=668228 keepalive_timeout = 0
Thu Jul 9 06:27:19 2015 us=668309 inactivity_timeout = 0
Thu Jul 9 06:27:19 2015 us=668390 ping_send_timeout = 0
Thu Jul 9 06:27:19 2015 us=668471 ping_rec_timeout = 0
Thu Jul 9 06:27:19 2015 us=668551 ping_rec_timeout_action = 0
Thu Jul 9 06:27:19 2015 us=668632 ping_timer_remote = DISABLED
Thu Jul 9 06:27:19 2015 us=668714 remap_sigusr1 = 0
Thu Jul 9 06:27:19 2015 us=668823 explicit_exit_notification = 0
Thu Jul 9 06:27:19 2015 us=668908 persist_tun = ENABLED
Thu Jul 9 06:27:19 2015 us=668989 persist_local_ip = DISABLED
Thu Jul 9 06:27:19 2015 us=669071 persist_remote_ip = DISABLED
Thu Jul 9 06:27:19 2015 us=669152 persist_key = ENABLED
Thu Jul 9 06:27:19 2015 us=669258 mssfix = 1450
Thu Jul 9 06:27:19 2015 us=669340 passtos = DISABLED
Thu Jul 9 06:27:19 2015 us=669422 resolve_retry_seconds = 1000000000
Thu Jul 9 06:27:19 2015 us=669558 username = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=669643 groupname = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=669726 chroot_dir = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=669806 cd_dir = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=669888 writepid = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=669968 up_script = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=670048 down_script = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=670128 down_pre = DISABLED
Thu Jul 9 06:27:19 2015 us=670208 up_restart = DISABLED
Thu Jul 9 06:27:19 2015 us=670290 up_delay = DISABLED
Thu Jul 9 06:27:19 2015 us=670370 daemon = DISABLED
Thu Jul 9 06:27:19 2015 us=670451 inetd = 0
Thu Jul 9 06:27:19 2015 us=670530 log = ENABLED
Thu Jul 9 06:27:19 2015 us=670611 suppress_timestamps = DISABLED
Thu Jul 9 06:27:19 2015 us=670693 nice = 0
Thu Jul 9 06:27:19 2015 us=670775 verbosity = 9
Thu Jul 9 06:27:19 2015 us=670882 mute = 0
Thu Jul 9 06:27:19 2015 us=670964 gremlin = 0
Thu Jul 9 06:27:19 2015 us=671045 status_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=671126 status_file_version = 1
Thu Jul 9 06:27:19 2015 us=671228 status_file_update_freq = 60
Thu Jul 9 06:27:19 2015 us=671310 occ = ENABLED
Thu Jul 9 06:27:19 2015 us=671391 rcvbuf = 65536
Thu Jul 9 06:27:19 2015 us=671472 sndbuf = 65536
Thu Jul 9 06:27:19 2015 us=671552 sockflags = 0
Thu Jul 9 06:27:19 2015 us=671632 fast_io = DISABLED
Thu Jul 9 06:27:19 2015 us=671713 lzo = 7
Thu Jul 9 06:27:19 2015 us=671792 route_script = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=671874 route_default_gateway = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=671955 route_default_metric = 0
Thu Jul 9 06:27:19 2015 us=672036 route_noexec = DISABLED
Thu Jul 9 06:27:19 2015 us=672118 route_delay = 0
Thu Jul 9 06:27:19 2015 us=672200 route_delay_window = 30
Thu Jul 9 06:27:19 2015 us=672281 route_delay_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=672362 route_nopull = DISABLED
Thu Jul 9 06:27:19 2015 us=672443 route_gateway_via_dhcp = DISABLED
Thu Jul 9 06:27:19 2015 us=672526 max_routes = 100
Thu Jul 9 06:27:19 2015 us=672609 allow_pull_fqdn = DISABLED
Thu Jul 9 06:27:19 2015 us=672694 management_addr = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=672776 management_port = 0
Thu Jul 9 06:27:19 2015 us=672923 management_user_pass = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=673011 management_log_history_cache = 250
Thu Jul 9 06:27:19 2015 us=673095 management_echo_buffer_size = 100
Thu Jul 9 06:27:19 2015 us=673177 management_write_peer_info_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=673260 management_client_user = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=673343 management_client_group = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=673425 management_flags = 0
Thu Jul 9 06:27:19 2015 us=673506 shared_secret_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=673589 key_direction = 0
Thu Jul 9 06:27:19 2015 us=673670 ciphername_defined = ENABLED
Thu Jul 9 06:27:19 2015 us=673752 ciphername = 'BF-CBC'
Thu Jul 9 06:27:19 2015 us=673833 authname_defined = ENABLED
Thu Jul 9 06:27:19 2015 us=673915 authname = 'SHA1'
Thu Jul 9 06:27:19 2015 us=673996 prng_hash = 'SHA1'
Thu Jul 9 06:27:19 2015 us=674077 prng_nonce_secret_len = 16
Thu Jul 9 06:27:19 2015 us=674159 keysize = 0
Thu Jul 9 06:27:19 2015 us=674240 engine = DISABLED
Thu Jul 9 06:27:19 2015 us=674322 replay = ENABLED
Thu Jul 9 06:27:19 2015 us=674404 mute_replay_warnings = ENABLED
Thu Jul 9 06:27:19 2015 us=674487 replay_window = 64
Thu Jul 9 06:27:19 2015 us=674569 replay_time = 15
Thu Jul 9 06:27:19 2015 us=674651 packet_id_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=674733 use_iv = ENABLED
Thu Jul 9 06:27:19 2015 us=674839 test_crypto = DISABLED
Thu Jul 9 06:27:19 2015 us=674944 tls_server = DISABLED
Thu Jul 9 06:27:19 2015 us=675029 tls_client = ENABLED
Thu Jul 9 06:27:19 2015 us=675111 key_method = 2
Thu Jul 9 06:27:19 2015 us=675193 ca_file = '/etc/openvpn/ca.crt'
Thu Jul 9 06:27:19 2015 us=675274 ca_path = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=675403 dh_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=675491 cert_file = '/etc/openvpn/client.crt'
Thu Jul 9 06:27:19 2015 us=675575 priv_key_file = '/etc/openvpn/client.key'
Thu Jul 9 06:27:19 2015 us=675657 pkcs12_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=675739 cipher_list = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=675820 tls_verify = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=675902 tls_export_cert = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=675985 tls_remote = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=676067 crl_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=676149 ns_cert_type = 64
Thu Jul 9 06:27:19 2015 us=676231 remote_cert_ku
= 0
Thu Jul 9 06:27:19 2015 us=676314 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676397 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676479 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676560 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676642 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676723 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676829 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676913 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=676996 remote_cert_ku = 0
Thu Jul 9 06:27:19 2015 us=677079 remote_cert_ku[i] = 0
Thu Jul 9 06:27:19 2015 us=677161 remote_cert_ku[i] = 0
Thu Jul 9 06:27:19 2015 us=677266 remote_cert_ku[i] = 0
Thu Jul 9 06:27:19 2015 us=677349 remote_cert_ku[i] = 0
Thu Jul 9 06:27:19 2015 us=677431 remote_cert_ku[i] = 0
Thu Jul 9 06:27:19 2015 us=677513 remote_cert_ku[i] = 0
Thu Jul 9 06:27:19 2015 us=677593 remote_cert_eku = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=677676 tls_timeout = 2
Thu Jul 9 06:27:19 2015 us=677758 renegotiate_bytes = 0
Thu Jul 9 06:27:19 2015 us=677839 renegotiate_packets = 0
Thu Jul 9 06:27:19 2015 us=677920 renegotiate_seconds = 3600
Thu Jul 9 06:27:19 2015 us=678002 handshake_window = 60
Thu Jul 9 06:27:19 2015 us=678084 transition_window = 3600
Thu Jul 9 06:27:19 2015 us=678164 single_session = DISABLED
Thu Jul 9 06:27:19 2015 us=678244 push_peer_info = DISABLED
Thu Jul 9 06:27:19 2015 us=678324 tls_exit = DISABLED
Thu Jul 9 06:27:19 2015 us=678405 tls_auth_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=678503 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=678592 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=678675 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=678757 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=678839 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=678921 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679003 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679084 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679167 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679248 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679329 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679411 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679493 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679575 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679656 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679738 pkcs11_protected_authentication = DISABLED
Thu Jul 9 06:27:19 2015 us=679824 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=679908 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=679991 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680075 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680158 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680242 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680324 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680407 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680533 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680621 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680705 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680788 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680871 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=680953 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=681036 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=681120 pkcs11_private_mode = 00000000
Thu Jul 9 06:27:19 2015 us=681201 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681282 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681364 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681446 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681527 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681607 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681688 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681769 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681850 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=681931 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=682012 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=682092 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=682174 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=682255 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=682336 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=682418 pkcs11_cert_private = DISABLED
Thu Jul 9 06:27:19 2015 us=682500 pkcs11_pin_cache_period = -1
Thu Jul 9 06:27:19 2015 us=682581 pkcs11_id = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=682662 pkcs11_id_management = DISABLED
Thu Jul 9 06:27:19 2015 us=682876 server_network = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683020 server_netmask = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683117 server_network_ipv6 = ::
Thu Jul 9 06:27:19 2015 us=683201 server_netbits_ipv6 = 0
Thu Jul 9 06:27:19 2015 us=683292 server_bridge_ip = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683395 server_bridge_netmask = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683490 server_bridge_pool_start = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683581 server_bridge_pool_end = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683664 ifconfig_pool_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=683754 ifconfig_pool_start = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683845 ifconfig_pool_end = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=683935 ifconfig_pool_netmask = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=684019 ifconfig_pool_persist_filename = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=684102 ifconfig_pool_persist_refresh_freq = 600
Thu Jul 9 06:27:19 2015 us=684184 ifconfig_ipv6_pool_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=684271 ifconfig_ipv6_pool_base = ::
Thu Jul 9 06:27:19 2015 us=684355 ifconfig_ipv6_pool_netbits = 0
Thu Jul 9 06:27:19 2015 us=684438 n_bcast_buf = 256
Thu Jul 9 06:27:19 2015 us=684519 tcp_queue_limit = 64
Thu Jul 9 06:27:19 2015 us=684601 real_hash_size = 256
Thu Jul 9 06:27:19 2015 us=684682 virtual_hash_size = 256
Thu Jul 9 06:27:19 2015 us=684764 client_connect_script = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=684884 learn_address_script = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=684969 client_disconnect_script = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=685052 client_config_dir = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=685134 ccd_exclusive = DISABLED
Thu Jul 9 06:27:19 2015 us=685240 tmp_dir = '/tmp'
Thu Jul 9 06:27:19 2015 us=685324 push_ifconfig_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=685415 push_ifconfig_local = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=685507 push_ifconfig_remote_netmask = 0.0.0.0
Thu Jul 9 06:27:19 2015 us=685590 push_ifconfig_ipv6_defined = DISABLED
Thu Jul 9 06:27:19 2015 us=685679 push_ifconfig_ipv6_local = ::/0
Thu Jul 9 06:27:19 2015 us=685767 push_ifconfig_ipv6_remote = ::
Thu Jul 9 06:27:19 2015 us=685849 enable_c2c = DISABLED
Thu Jul 9 06:27:19 2015 us=685976 duplicate_cn = DISABLED
Thu Jul 9 06:27:19 2015 us=686063 cf_max = 0
Thu Jul 9 06:27:19 2015 us=686145 cf_per = 0
Thu Jul 9 06:27:19 2015 us=686228 max_clients = 1024
Thu Jul 9 06:27:19 2015 us=686310 max_routes_per_client = 256
Thu Jul 9 06:27:19 2015 us=686392 auth_user_pass_verify_script = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=686475 auth_user_pass_verify_script_via_file = DISABLED
Thu Jul 9 06:27:19 2015 us=686557 ssl_flags = 0
Thu Jul 9 06:27:19 2015 us=686638 port_share_host = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=686721 port_share_port = 0
Thu Jul 9 06:27:19 2015 us=686824 client = ENABLED
Thu Jul 9 06:27:19 2015 us=686909 pull = ENABLED
Thu Jul 9 06:27:19 2015 us=686991 auth_user_pass_file = '[UNDEF]'
Thu Jul 9 06:27:19 2015 us=687083 OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec 1 2014
Thu Jul 9 06:27:19 2015 us=687426 PKCS#11: pkcs11_initialize - entered
Thu Jul 9 06:27:19 2015 us=687808 PKCS#11: pkcs11_initialize - return 0-'CKR_OK'
Thu Jul 9 06:27:19 2015 us=687937 WARNING: using --pull/--client and --ifconfig together is probably not what you want
Thu Jul 9 06:27:19 2015 us=688021 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Thu Jul 9 06:27:19 2015 us=688129 PO_INIT maxevents=4 flags=0x00000002
Thu Jul 9 06:27:19 2015 us=691860 WARNING: file '/etc/openvpn/client.key' is group or others accessible
Thu Jul 9 06:27:19 2015 us=695412 PRNG init md=SHA1 size=36
Thu Jul 9 06:27:19 2015 us=695704 LZO compression initialized
Thu Jul 9 06:27:19 2015 us=695811 MTU DYNAMIC mtu=0, flags=1, 0 -> 138
Thu Jul 9 06:27:19 2015 us=695892 TLS: tls_session_init: entry
Thu Jul 9 06:27:19 2015 us=695991 PID packet_id_init seq_backtrack=64 time_backtrack=15
Thu Jul 9 06:27:19 2015 us=696231 PID packet_id_init seq_backtrack=64 time_backtrack=15
Thu Jul 9 06:27:19 2015 us=696348 TLS: tls_session_init: new session object, sid=81435c4f 2a0e2bde
Thu Jul 9 06:27:19 2015 us=696427 TLS: tls_session_init: entry
Thu Jul 9 06:27:19 2015 us=696520 PID packet_id_init seq_backtrack=64 time_backtrack=15
Thu Jul 9 06:27:19 2015 us=696723 PID packet_id_init seq_backtrack=64 time_backtrack=15
Thu Jul 9 06:27:19 2015 us=696835 TLS: tls_session_init: new session object, sid=70776976 2d3272e0
Thu Jul 9 06:27:19 2015 us=696933 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Thu Jul 9 06:27:19 2015 us=697056 MTU DYNAMIC mtu=1450, flags=2, 1542 -> 1450
Thu Jul 9 06:27:19 2015 us=697213 Socket Buffers: R=[163840->131072] S=[163840->131072]
Thu Jul 9 06:27:19 2015 us=697337 RESOLVE_REMOTE flags=0x0101 phase=1 rrs=0 sig=-1 status=1
Thu Jul 9 06:27:19 2015 us=697443 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Thu Jul 9 06:27:19 2015 us=697542 Error: problem with tun vs. tap setting
Thu Jul 9 06:27:19 2015 us=697645 Exiting
