alvaro36horas
Error:Could not open file `/dev/i2c-1': No such file or dire
Tue Jul 07, 2015 11:06 am
I have recentry bought a Raspberry pi 2 model B with NOOBS and when I run the command "sudo i2cdetect -y 1" this is the response I get:
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1' : No such file or directory.
I have tried almost everything I have seen in other forums with this problem but it seems it does not work for me:
https://learn.adafruit.com/adafruits-ra ... guring-i2c
http://skpang.co.uk/blog/archives/575
Your help will be really welcome,
thank you very much
joan
Re: Error:Could not open file `/dev/i2c-1': No such file or
Tue Jul 07, 2015 11:08 am
See http://www.raspberrypi.org/forums/viewt ... 28&t=97314
Summary
Add one or more of the following to your /boot/config.txt and reboot.
I2C
Add dtparam=i2c1=on (or dtparam=i2c0=on on old models)
SPI
Add dtparam=spi=on
I2S
Add dtparam=i2s=on
lirc-rpi
Add dtoverlay=lirc-rpi
Add module parameters to the end of the dtoverlay line,
e.g. dtoverlay=lirc-rpi,gpio_in_pin=16,gpio_in_pull=high
w1-gpio
If you require the external pullup
dtoverlay=w1-gpio-pullup,gpiopin=x,pullup=y
otherwise
(where x and y are gpios).
Audio card
Add one of the following
dtoverlay=hifiberry-dac
dtoverlay=hifiberry-dacplus
dtoverlay=hifiberry-digi
dtoverlay=iqaudio-dac
dtoverlay=iqaudio-dacplus
heartbeat LED
dtparam=act_led_trigger=heartbeat
alvaro36horas
Tue Jul 07, 2015 12:30 pm
Thank you Joan by I have already done that.
This is the content of /boot/config.txt:
dtparam=i2c1=on
dtparam=i2c=on
dtparam=i2c_arm=on
dtparam=i2c_vc
device_tree_param=i2c=on1=on
dtparam=spi=on
Thank you for your help anyway
joan
Tue Jul 07, 2015 12:38 pm
Ok. The command
lsmod|grep i2c
should show the I2C module (i2c_bcm2708).
lsmod|grep i2c
i2c_bcm2708             5006  0
You need to manually insert another module
sudo modprobe i2c-dev
Then
lsmod|grep i2c
i2c_dev                 6047  0
i2c_bcm2708             5006  0
To insert the module automatically add the following line to the file /etc/modules.
i2c-dev
alvaro36horas
Tue Jul 07, 2015 1:35 pm
Thank Joan but,
Yes I have already done that and I still have the same problem (Error:Could not open file `/dev/i2c-1': No such file or directory)
After running lsmod|grep i2c, I have:
i2c_dev 6027 0
i2c_bcm2708 4990 0
Thanks a lot anyway,
Any idea apart from that?
alvaro36horas
Thank Joan but,
i2c_dev 6027 0
i2c_bcm2708 4990 0
joan
Tue Jul 07, 2015 1:39 pm
As far as I am aware the only other reason it would fail would be if you include the i2c_bcm2708 module in /etc/modules as well as enabling I2C in device tree.
I'd also try removing some of the repeat I2C entries in your /boot/config.txt, perhaps just leaving dtparam=i2c0=on and dtparam=i2c1=on.
alvaro36horas
Tue Jul 07, 2015 2:23 pm
Thanks Joan but,
I have only put these two lines in the /boot/config.txt and again the same problem.
joan
Tue Jul 07, 2015 2:35 pm
Device tree needs a recent (>3.18) kernel.
uname -a
It's hard to think of anything else which can go wrong. Are you using raspbian?
alvaro36horas
Tue Jul 07, 2015 2:50 pm
uname -a gives:
Linux raspberry0 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 arm7l GNU/Linux
cat /etc/issue gives:
Raspbian GNU/Linux 7 \n \l
REALLY, THANK A LOT FOR ALL YOUR FAST HELP
joan
Tue Jul 07, 2015 3:19 pm
I'm out of ideas.
I've just checked my Pi2.
It has one I2C entry in /boot/config.txt
 grep i2c /boot/config.txt
dtparam=i2c_arm=on
I don't have anything in /etc/modules as I modprobe i2c-dev manually when I want to use I2C.
It should just work.
alvaro36horas
Tue Jul 07, 2015 3:52 pm
Thank you Joan,
I don't really know what to do. I have another raspberry 2 model B. I think I will try with this second one
Thank you very much for your help anyway
Tue Jul 07, 2015 4:02 pm
If you're using NOOBS then hold the [SHIFT] key during boot so you can use the NOOBS recovery system to edit your config.txt.
alvaro36horas
Thu Jul 09, 2015 9:50 am
Thank Dougie,
that is starting again from scratch,
ok I did it and I am starting again,
I will see if it solves the problem,
I will post the result,
Álvaro
alvaro36horas
Thu Jul 09, 2015 10:07 am
Ah!, I forget it,
This is what someone said in another forum:
"I've spent a lot time in the module loading maze. You can edit /etc/modules, like adafruit link above or you can use the device tree enabled raspi-config and setup in /boot/config.txt. I found the DT has good debug notes here: https://www.raspberrypi.org/documentati ... ce-tree.md
cat /proc/modules shows loaded modules."
Adafruit link is this (I've already tried this):
And I see that in the other link
(https://www.raspberrypi.org/documentati ... ce-tree.md) seems to be quite tough, but if there is no choice I'll try this way.
Thanks all
AndreaK
Re: Error:Could not open file `/dev/i2c-1': No such file or dire
Tue Mar 24, 2020 7:19 pm
I'm new here.
I tried to set my raspberry pi 3 to work with an ADS module (ADS1015) and I found the same error discussed in this article. I know this is 5 years old but did someone find a way to fix it?
Thank you.
