beaudamore
Windows 10E internal web server not responding
Wed Jul 01, 2015 1:36 am
I have recently installed Win10E onto my RP2.
It boots fine, gets an IP, and responds to pings.
I can also successfully PowerShell into it and set it's name, password and reboot it all via command line.
However, if I browse to it's IP I get nothing, browser times out.
It's web server isn't running so I can't use its WebUI...
OS version is 10.0.10152.0
(Also, in the UI, the Power button is grayed out.... strange)
Thanks for any input.
BernardG
Re: Windows 10E internal web server not responding
Wed Jul 01, 2015 10:54 am
hello all!
I have the same issue. I can connect and send commands via PowerShell, but the web server send a timeout.
Is there anything to be done to enable it? From what I have read here and there, it's supposed to be working right out of the box, is not it?
Thanks for any clues....
Wed Jul 01, 2015 10:55 am
beaudamore wrote:I have recently installed Win10E onto my RP2.
What is Win10E ? did you mean Windows 10 IoT Core ?
Regards the Power Button grayed out see: viewtopic.php?f=105&t=114268
This post any help with access ? viewtopic.php?f=105&t=114440#p782438
Retired disgracefully.....
......to an uncomplicated life !
BernardG
Wed Jul 01, 2015 10:58 am
Problem solved! Did not know it, but I got the very last build, on which the web app is at 8080. So doing 192.xxx.xxx.xxx:8080 is needed to get to the web server. Works like a charm!
GerritV
Wed Jul 01, 2015 11:14 am
The port number in the June release is now 8080, not the default 80.
beaudamore
Wed Jul 01, 2015 3:37 pm
Yes, I meant Windows 10 Embedded (IoT core) and thanks for the info, I'll try it when I get home tonight.
Wed Jul 01, 2015 9:26 pm
Why do you insist in calling it Embedded, it is just Windows 10 IoT Core :roll:
haroldpulcher
Thu Jul 02, 2015 4:14 am
I am curious as well. I have been following the dev of Windows 10 core IoT for a long time.
This is the first that I have heard it called Windows Embedded.
There was a windows embedded product in the past, but Windows 10 core IoT is not that.
It is more closely related to the windows server core than any of the embedded stuff.
Return to “Windows 10 for IoT”
