Vaquerizo
CTS & RTS serial question RPI2
Mon Jun 01, 2015 10:29 am
Hi all!
I need to enable CTS0 and RTS0 on RPI2 for to use with a complete serial protocol like RS232.
I know that they are on pin 36 and pin 11:
http://pi.gadgetoid.com/pinout/pin36_gpio16
http://pi.gadgetoid.com/pinout/pin11_gpio17
How can I activate alt3 on C code?
Regards.
joan
Re: CTS & RTS serial question RPI2
Mon Jun 01, 2015 11:03 am
Either use a library of if you prefer not then use code like Minimal gpio access.
Vaquerizo
Mon Jun 01, 2015 11:58 am
I am using Wiring Pi library, but I dont see where can I to active CTS0 RTS0 on pins 36 and 11. Do you know how can I active this fuctions on wiring pi?.
Regards.
Vaquerizo
Mon Jun 01, 2015 12:09 pm
Gordon said me first to do this:
 gpio -g mode 11 alt3
 gpio -g mode 36 alt3
And then re-write the Linux driver to understand the signals.
But I don't know what he refer "re-write the Linux driver".
Regards
Vaquerizo
Mon Jun 01, 2015 2:21 pm
oh.
I did it and now rpi2 doesn't run:
EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
Regards.
Vaquerizo
Mon Jun 01, 2015 2:36 pm
If I run rpi2 without hdmi:
End kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,6)
EXT4-fs error (device mmcblk0p6) in ext4 _reserve_inode_write:4758:Journal has aborted
EXT4-fs error (device mmcblk0p6): mpage_map_and_submit_extent:2127: comm kworker/u8:1: Failed to mark inode 156343 dirty
Regards.
joan
Mon Jun 01, 2015 4:37 pm
If you are not using a compute module you should not be writing to gpio 36. That may be used by the SD card subsystem (which would explain why your SD card seems to have corrupted).
Vaquerizo
Tue Jun 02, 2015 9:08 am
@joan, what can I do to use CTS and RTS on GPIO??
Regards.
Tue Jun 02, 2015 10:35 am
Vaquerizo wrote:@joan, what can I do to use CTS and RTS on GPIO??
You are on the right track, just getting muddled up between physical pin numbers and GPIO numbers.
Use Pin 11 for RTS. That pin is connected to GPIO 17. So to set it you use
gpio -g mode 17 alt3
Use Pin 36 for CTS. That pin is connected to GPIO 16. So to set that one you use
gpio -g mode 16 alt3
Vaquerizo
Tue Jun 02, 2015 10:38 am
???? it's a Raspberry Pi 2. Not RPI1.
Tue Jun 02, 2015 10:40 am
Vaquerizo wrote:???? it's a Raspberry Pi 2. Not RPI1.
Yes. What is the problem?
The commands I gave are for Pi2 or Pi B+.
Vaquerizo
Tue Jun 02, 2015 10:44 am
Vaquerizo
Tue Jun 02, 2015 10:49 am
AAAAh I understand you.
Ok Ok. Thanks so much!
And.. other question: where can I see the physical pin numbers and - GPIO numbers information?
Regards and thanks!!
Tue Jun 02, 2015 10:52 am
Vaquerizo wrote:AAAAh I understand you.
You seem to have found a very good link to a pin number reference anyway http://pi.gadgetoid.com/pinout :)
Thank you, I'll remember to bookmark that link this time :)
Vaquerizo
Tue Jun 02, 2015 11:03 am
Aahaha I understand now.
Thanks!
Vaquerizo
Tue Jun 02, 2015 12:02 pm
I tested and run!!! :)
fort
Thu Apr 28, 2016 11:04 am
hi
a have module UART-RS485 (ttyAMA0) connected to Raspberry Pi 2 (with raspbian).
I have also USB-RS485 (ttyUSB0) also connected. I connect them using A-B Line. Then i try transmit data between them.
my cmdline.txt:
[email protected]:~/rpirtscts $ cat /proc/cmdline
dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x857e7dae smsc95xx.macaddr=B8:27:EB:7E:7D:AE bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
To enable CTS/RTS i did this:
[email protected]:~/rpirtscts $ gpio readall
 +-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |   2 |   8 |   SDA.1 |   IN | 1 |  3 || 4  |   |      | 5V      |     |     |
 |   3 |   9 |   SCL.1 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
 |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 1 | ALT0 | TxD     | 15  | 14  |
 |     |     |      0v |      |   |  9 || 10 | 1 | ALT0 | RxD     | 16  | 15  |
 |  17 |   0 | GPIO. 0 | ALT3 | 0 | 11 || 12 | 0 | IN   | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |   IN | 0 | 13 || 14 |   |      | 0v      |     |     |
 |  22 |   3 | GPIO. 3 |   IN | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
 |     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO. 5 | 5   | 24  |
 |  10 |  12 |    MOSI |   IN | 0 | 19 || 20 |   |      | 0v      |     |     |
 |   9 |  13 |    MISO |   IN | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
 |  11 |  14 |    SCLK |   IN | 0 | 23 || 24 | 1 | IN   | CE0     | 10  | 8   |
 |     |     |      0v |      |   | 25 || 26 | 1 | IN   | CE1     | 11  | 7   |
 |   0 |  30 |   SDA.0 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.0   | 31  | 1   |
 |   5 |  21 | GPIO.21 |   IN | 1 | 29 || 30 |   |      | 0v      |     |     |
 |   6 |  22 | GPIO.22 |   IN | 1 | 31 || 32 | 0 | IN   | GPIO.26 | 26  | 12  |
 |  13 |  23 | GPIO.23 |   IN | 0 | 33 || 34 |   |      | 0v      |     |     |
 |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 1 | ALT3 | GPIO.27 | 27  | 16  |
 |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
 |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
The connect UART-RS485 module: DI to TX (pin 8), RO to RX (pin 10), DE to CTS (pin 36), RE to RTS (pin 11)/
Then i strart in window 1:
screen /dev/ttyUSB0
and in second window
screen /dev/ttyAMA0
Now, when send data from ttyUSB0 to ttyAMA0 it's ok: i typing data in window 1 and see it in window 2. In window 1 thus i don't see what i type.
When i typing in window 2 (send data from ttyAMA0 to ttyUSB0), i see that i type in both windows. I suppose i recieve echo. It is not right. I do not want recieve this. I need that in that it work like in first case.
Can fix this?
May be i connect UART-USB to GPIO wrong?
Do i need clearly point (and how) use RTS/CTS with ttyAMA0 when open them?
