Would it be possible to virtualize RISCOS? By that, I mean give it a core and a few hundred MB of RAM on a Raspberry Pi 2, and let it do its thing to a display under Linux?
(as you can tell, I know little of the technical requirements here …)
No, Linux like Raspbian on an arm7, as in the Raspberry Pi 2. Not emulation.kusti8 wrote:Linux as in x86?
With Qemu KVM, you can run RISC OS for BeagleBoard without modification!DavidS wrote:Possible? Probably, though the amount of work needed to do so would be huge at the least, and it would slow down RISC OS.
What do you need linux for so much that you would make this sacrifice?
