loudhush
Remote Connecting to Windows 10 IoT
Sat May 16, 2015 6:22 am
I can't seem to remote connect to my Raspberry PI2. I have Windows 10 installed on the PI2 so I can read the machines IP address and current time etc.
As I understand it, the next step is to remote into Windows 10 with PowerShell in Administrator mode.
I'm trying to follow this guide
http://ms-iot.github.io/content/win10/s ... rShell.htm
Unfortunately when run this step
 Set-Item WSMan:\localhost\Client\TrustedHosts -Value 192.168.100.104
I get the error
Set-Item : Access is denied.
At line:1 char:11
+   Set-Item <<<<  WSMan:\localhost\Client\TrustedHosts -Value 192.168.100.104
    + CategoryInfo          : NotSpecified: (:) [Set-Item], InvalidOperationException
    + FullyQualifiedErrorId : System.InvalidOperationException,Microsoft.PowerShell.Commands.SetItemCommand
I'm quite stumped by this....I have googled and blindly followed a few suggestions I found with no success.
Do you have any suggestions for me to try?
SoggyB
Re: Remote Connecting to Windows 10 IoT
Sat May 16, 2015 3:51 pm
.. I have this same issue :/
loudhush
Sat May 16, 2015 11:30 pm
OK I solved my issue.
I did not have a password on my main machine.
I added a password, and all is good! :) Hope this helps someone else.
SoggyB
Sun May 17, 2015 12:17 am
Sorry, can you elaborate? Did you add a password to the powershell command?
loudhush
Sun May 17, 2015 2:52 am
The user account for the Windows 7 box did not have a password.
So I had to press Ctrl + Alt + Delete
Click on "Change Password"
Typed a password in twice
Then went back to PowerShell and everything just worked.
Let me know if this helped you out.
SoggyB
Sun May 17, 2015 1:20 pm
Nope, I already had a password for the account on my desktop. I tried rebooting, and locking/unlocking. No luck. This is a Win 7 desktop though :/
loudhush
Sun May 17, 2015 3:19 pm
Darn sorry man, I don't have any other suggestions.
I posted my problem to a group of friends, I had one person say they had the same issue but their problem was they needed to reference the Raspberry PI by IP address instead of machine name.
Other than that I have nothing for you. Good luck.
SoggyB
Sun May 17, 2015 3:50 pm
Ok... turned UAC off, rebooted. Now it works.
Thanks for your help.
SoggyB
Mon May 18, 2015 3:29 pm
... don't forget to turn UAC back on ;)
Ken76
Fri Oct 21, 2016 8:28 am
I can't connect to my Windows 10 IOT Rasbperry Pi 3 with the Powershell (Administrator Mode).
I have tried with theese lines
net start WinRM
Set-Item WSMan:\localhost\Client\TrustedHosts -Value 192.168.1.6
I don't even get any kind of error messages. And I have also the UAC disabled.
Can someone help me?
leonardo.daga
Thu Oct 27, 2016 7:22 am
And then you used this command, right?
Enter-PSSession -ComputerName 192.168.1.6 -Credential 192.168.1.6/Administrator
Return to “Windows 10 for IoT”
