bluenote
Re: Dynamode USB Wifi Dongle issues
Sat May 16, 2015 11:16 pm
MrEngman wrote:
anno41 wrote:hi.
can anyone help me? i tried for hours to install this wifi usb dongle. i have ralink 148F:7601 and try to get it working on a raspberry pi model B plus.
lsusb command :
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 04fc:0003 Sunplus Technology Co., Ltd CM1092 / Wintech CM-5098 Optical Mouse
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 006: ID 1241:1203 Belkin
Bus 001 Device 007: ID 148f:7601 Ralink Technology, Corp.
Bus 001 Device 008: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
uname - a command gives
Linux raspberrypi 3.18.13+ #784 PREEMPT Sat May 9 15:49:42 BST 2015 armv6l GNU/Linux
i did the following commands :
wget https://dl.dropboxusercontent.com/u/802 ... 782.tar.gz
tar xzf mt7601-3.18.12-782.tar.gz
./install.sh
it gave no errors. i did a reboot but the wifi adapter is not working. can anyone help?
Try this instead
wget https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.13-784.tar.gz
tar xzf mt7601-3.18.13-784.tar.gz
./install.sh
Notice the similarity between your uname -a command output and the filename you need to use.
MrEngman
Hey MrEngman
I searched through the thread and couldn't find a version for RPI 2 uname Linux raspberrypi 3.18.13-v7+ #784 SMP PREEMPT Sat May 9 15:57:36 BST 2015 armv7l GNU/Linux. I wasn't able to find an index on dropbox for the files you have posted. Do you think you could compile for this version?
thanks
Edit: I found your post on how to find your Dropbox version files and I got the one I needed. Thank you :)
MrEngman
Sat May 16, 2015 11:41 pm
bluenote wrote: Hey MrEngman
thanks
Glad you figured it out. I use a standard format for my driver files so you should now be able to keep your driver up to date if you update your code.
MrEngman
daming99
Sun May 17, 2015 6:37 am
mvadu wrote:Okay, this is for people who would like to compile this driver on their own! I was facing some issues in compiling a cleaned up version of the firmware maintained at https://github.com/porjo/mt7601, and finally found the working set of instructions with help of few nice folks.
Note that updating gcc involves its own set of steps, as described in this guide
1. mkdir src
2. cd src
3. git clone --depth 1 https://github.com/raspberrypi/firmware
4. git clone --depth 1 https://github.com/raspberrypi/linux
5. cat firmware/extra/uname_string
      Linux version 3.18.10+ ([email protected]) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #775 PREEMPT Thu Apr 2 18:10:12 BST 2015 in my case
6. sudo nano linux/Makefile
7. Update EXTRAVERSION =  last thee digits of uname -r (use uname -r | cut -c9-12 to get it)
9. Update gcc
8. sudo mkdir /boot/backup
9. sudo cp /boot/* /boot/backup/
10. sudo cp -r firmware/modules /lib
11. sudo cp -r src/firmware/boot /
12. sudo cp firmware/extra/Module7.symvers linux/Module.symvers
13. sync
14. sudo reboot
15. cd src/
16. sudo ln -s /home/pi/src/linux /lib/modules/$(uname -r)/build
17. cd linux
18. sudo gunzip -c /proc/config.gz > .config
19. sudo make oldconfig
20. sudo make modules_prepare
21. mkdir ~/git
22. cd ~/git
23. git clone https://github.com/porjo/mt7601
24. cd src
25. sudo make
26. sudo insmod /home/pi/git/mt7601/src/os/linux/mt7601Usta.ko
27. lsmod | grep 7601
hello, it seems that you compile the drivers by yourself, ho ho, fun stuff, can you share me how you do that? I am someone who is struggling with compiling this drivers on my own way, very appreciate!
ian2000611
Tue May 19, 2015 3:11 pm
Thank you so much, have been trying to compile for days!
managed to get past insmod, all the way to wpa_supplicant daemon failed to start. I assume that I had a bad copy of the mt7601 driver source. Would you mind linking to the source you used and any patches that were required?
I would like to be able to build my own when a new release comes out.
MrEngman
Tue May 19, 2015 3:55 pm
ian2000611 wrote:Thank you so much, have been trying to compile for days!
This is the source that I am using.
MrEngman
ian2000611
Tue May 19, 2015 5:01 pm
Thanks so much, that did the trick I now have a self compiled driver, and have compiled one for 3.18.13-v7+
gzu
Tue May 26, 2015 12:28 pm
Hi
I've just installed osmc on my new Raspberry Pi 2 B and can't get the wifi to work.
The kernel naming looks different on the RC3 and I can't see a download with a name like it listed in this thread
From memory uname -a starts "3.18.13-1-osmc #1 "
Any suggestions.....
ian2000611
Tue May 26, 2015 4:12 pm
I would get the source for osmc, and the driver and just compile them.
I did this on Raspbian and it worked.
Finding the correct version of the source/firmware for osmc may be the hard part, but may not, check Google for that one.
You will probably have to upgrade gcc/g++ to 4.8.4, from Jessie rather than wheezy. See /etc/apt/sources.list
The driver source is available at github.com/porjo/mt7601.git
Transparantx
Mon Jun 01, 2015 11:01 pm
Hi, could you make me a install for the driver 8192eu?
Linux raspberrypi 3.18.14-v7+ #793 SMP PREEMPT Sat May 30 14:04:35 BST 2015 armv7l GNU/Linux
MrEngman
Tue Jun 02, 2015 6:53 am
Transparantx wrote:Hi, could you make me a install for the driver 8192eu?
Try this
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-3.18.14-v7-793.tar.gz
tar xzf 8192eu-3.18.14-v7-793.tar.gz
./install.sh
MrEngman
JasperBrown
Tue Jun 02, 2015 10:34 pm
This works...
Quote:
"I suggest you get a temporary internet connection, ethernet, tethered or whatever is available. Then do:
sudo apt-get install linux-headers-generic build-essential git
sudo apt-get install git
git clone https://github.com/porjo/mt7601.git
cd mt7601/src
make
sudo make install
sudo mkdir -p /etc/Wireless/RT2870STA/
sudo cp RT2870STA.dat /etc/Wireless/RT2870STA/
sudo modprobe mt7601Usta
Your wireless should now be working.
You have compiled the driver for your current kernel version only. When Update Manager installs a later linux-image, after the required reboot, you must re-compile:
cd mt7601/src
make clean
make
sudo make install
Please retain the files and these instructions for that time. Glad it's working!"
http://askubuntu.com/questions/457061/r ... stallation
It would be nice to have a Shell Script doning this job...
MrEngman
Wed Jun 03, 2015 12:29 am
JasperBrown wrote:This works...
cd mt7601/src
make
sudo make install
cd mt7601/src
make clean
make
sudo make install
Really?
No it does not on my Pi. Fails on the very first line.
MrEngman
Transparantx
Wed Jun 03, 2015 8:11 am
Try this
./install.sh
MrEngman
That worked , Thank you !
I've got another question: do you know how I can set 2 WiFi dongles one to listen and one to send out signal. I've followed the adafruit guide to make a WiFi access point, but I want it to work with 2 WiFi dongle.
Also it seems when I start the access point and I try to connect from my phone it keeps stuck on verifying and then the network shutdown or it connects for couple of second and then the network shutdowns. Do you have any experience with this.
I'm sorry if I shouldn't be asking it here, but I really want your help. I've googled and tried but still network keeps shutting down or stuck on verifying.
I'm sorry for my bad English, I hope you can understand what my problem is
btiu
Thu Jun 04, 2015 4:00 pm
Hi guys! I just recently bought my first rpi, the rpi A+ I have this cheap ra2870 Mt7601 wifi adapter too. I am on raspbian wheezy 3.18.11+ #781 so I was able to download and ./install.sh the file from your dropbox MrEngman! The adapter was plugged in, I installed, rebooted, then I was able to connect to my router! I was installing chromium but after 3 minutes the wifi signal would
change to an ethernet icon and the download would stop. I reboot to see if wifi will come back, but now the adapter isn't even recognized by lsusb and the modules didnt load like the first time; so I replugged it and the ethernet icon came on, not the wifi.
The worst part, now when I reboot with the adapter plugged, I get kernel panics all the time. Also when I start without the adapter, then plug the adapter when the gui has loaded, the rpi freezes too.
I don't wanna buy 4 dollar adapters no more; haha :)) help please!! I use a 4 port powered hub connected to a powerbank with 2.1A output, screen is hdmi on a 40"tv. The rpi is backfed, 1 port goes to mouse, another to keyboard, and third to wifi adapter. 4th unused.
Btw I will upload my dmesg and iwconfig and ipconfig, lsusb and lsmod during and after the 3 minute thing.
MrEngman
Thu Jun 04, 2015 5:55 pm
btiu wrote:Hi guys! I just recently bought my first rpi, the rpi A+ I have this cheap ra2870 Mt7601 wifi adapter too. I am on raspbian wheezy 3.18.11+ #781 so I was able to download and ./install.sh the file from your dropbox MrEngman! The adapter was plugged in, I installed, rebooted, then I was able to connect to my router! I was installing chromium but after 3 minutes the wifi signal would
Sounds like it may be a power supply issue and perhaps your SD card image could now be corrupted. I assume you are powering your Pi via the USB hub which is probably not a good idea but perhaps someone else could confirm if this is OK or not.
MrEngman
btiu
Fri Jun 05, 2015 12:21 am
MrEngman wrote: Sounds like it may be a power supply issue and perhaps your SD card image could now be corrupted. I assume you are powering your Pi via the USB hub which is probably not a good idea but perhaps someone else could confirm if this is OK or not.
MrEngman
I will try reflashing raspbian. Before this, my raspi already had history of power being pulled out without proper shutdown methods. I will try getting a replacement too.
Additional info on the ethernet icon thingy I got before: it shows it has connection to some "11n-AP" which doesnt exist in my home, When I turn my wifi router off, it still shows connected to that ESSID.
Update: Yeah, I got a different wifi dongle with the same price from the shop, and this one works plug-and-play. Thanks for all the help Mr Engman!
ShaunHellend
Tue Jun 09, 2015 4:05 pm
I'm using version 3.18.11 on the Pi-2, and I've used the wifi driver given but when I try and connect to my chosen network it gives me an internal IP address of 192.168.**.*** rather than an external. All settings are correct. Any body help?
Also before the update I could access the wifi gui in the top right hand corner, but now it just says dhcpdc not running.
MrEngman
Tue Jun 09, 2015 5:42 pm
ShaunHellend wrote:I'm using version 3.18.11 on the Pi-2, and I've used the wifi driver given but when I try and connect to my chosen network it gives me an internal IP address of 192.168.**.*** rather than an external. All settings are correct. Any body help?
"before the update"? - did you do an update or just install the wifi. How did you install the wifi? If the wifi has been correctly installed and the setting are correct then your wifi should be working.
How do you connect to the internet, via a modem/router or some other way. The wifi normally gets the IP from the router and this will most usually be 192.168.xx.xx unless you set a static address. Or do you expect to connect to some other address.
Can you please post the output of commands
uname -a
lsusb
lsmod
ifconfig -a
cat /etc/network/interfaces
sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
MrEngman
vannimb
Thu Jun 11, 2015 9:00 pm
Hi All,
where can i find the link for the 3.18.11+ #781 version?
i tried the drivers mentioned previously for the 3.18.11 but probably they do not work correctly.
if i install the mentioned driver and i restart the network interfaces i get the following errors when the pi tries to bring up wlan0
ioctl[SIOCSIWPMKSA]: Network is down
ioctl[SIOCSIWMODE]: Network is down
ioctl[SIOCGIWMODE]: Network is down
ioctl[SIOCSIWAP]: Network is down
ioctl[SIOCSIWESSID]: Network is down
ioctl[SIOCSIWENCODEEXT]: Network is down
RTNETLINK answers: File exists
Failed to bring up wlan0.
but the card still responds to the ping, even after restarting the pi the card still works.
Many thanks
MrEngman
Thu Jun 11, 2015 9:18 pm
vannimb wrote:Hi All,
(i tried the drivers mentioned previously for the 3.18.11 but they did not work)
Many thanks
What is the output of commands uname -a and lsusb to check your kernel version and wifi dongle to ensure you get the right driver version.
For Dynamode and equivalent wifi modules the download and install commands for 3.18.11+ #781 is
wget https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.11-781.tar.gz
tar xzf mt7601-3.18.11-781.tar.gz
./install.sh
For Pi 2b kernel will be 3.18.11-v7+ #781 and the driver download and install commands are
wget https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.11-v7-781.tar.gz
tar xzf mt7601-3.18.11-v7-781.tar.gz
./install.sh
MrEngman
vannimb
Thu Jun 11, 2015 9:30 pm
Thanks for the quick reply.
the version i have is raspberry B+:
3.18.11+ #781
the adapter is:
on a second unit i installed the latest driver as you suggested in your previous post, just run the latest upgrades on the os and when i plug the stick now i get kernel panic messages.
what can i do to fix this?
Many thanks
vannimb
Thu Jun 11, 2015 9:45 pm
please do not waste your time i just upgraded to 3.18.14+
Linux RASPBERRY-B1 3.18.14+ #794 PREEMPT Sun Jun 7 12:02:04 BST 2015 armv6l GNU/Linux
where can i find the driver for this version? (i see only the driver for V7)
Many thanks
MrEngman
Thu Jun 11, 2015 10:16 pm
vannimb wrote:please do not waste your time i just upgraded to 3.18.14+
Many thanks
Try this
wget https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.14-794.tar.gz
tar xzf mt7601-3.18.14-794.tar.gz
./install.sh
For future reference the driver filename is a standard format using kernel version (without "+") and build number (without the "#") which you can determine using command uname -a.
MrEngman
vannimb
Thu Jun 11, 2015 10:26 pm
thanks a lot Mr Engman
i installed the driver but when i reboot the unit the pi is responding to the ping for a while and then i lose it.
Richiesta scaduta.
Richiesta scaduta.
Richiesta scaduta.
Risposta da 192.168.0.12: Host di destinazione non raggiungibile.
Risposta da 192.168.0.202: byte=32 durata=2000ms TTL=64
Risposta da 192.168.0.202: byte=32 durata<1ms TTL=64
Risposta da 192.168.0.202: byte=32 durata=1ms TTL=64
Risposta da 192.168.0.15: Host di destinazione non raggiungibile.
if i restart the networking service i get the following error message
done.
but then it replies to the ping.
what could fix this issue?
many thanks
MrEngman
Thu Jun 11, 2015 11:05 pm
Hi vannimb,
Can you post the output from commands
ifconfig
to check your wifi configuration.
You could try command
sudo ifup --force wlan0
or as an alternative commands
sudo ifdown wlan0
sudo ifup wlan0
to see if that will bring up your wifi.
MrEngman
