Krassegrand
Unblock vpn
Thu May 07, 2015 7:03 pm
Is it possible to install Unblock VPN on Rasbian?
I know how to do on Ubuntu but I can't find the icon for internet connection on my Rasbian.
Jörgen
Krassegrand
Re: Unblock vpn
Tue May 12, 2015 2:06 pm
Is it necessary to install openvpn to make unblockvpn work?
I have an account with unblock and in Ubuntu I have set up different nodes but I cant find how to do it in Raspbiaan.
I have found guides for setting up servers with openvpn but it seems a little more advanced than what I need.
Is there a way to set up the network like I have done in Ubuntu?
I have also found a lot of guides for WIFI but they don't seems to address my problem, am I right?
I would be ok (I think) to have the unblock vpn on at all time if it is not an option to choose it from the dask top.
Jörgen
Krassegrand
Re: Unblock vpn
Tue May 12, 2015 4:11 pm
Can I use this command to set a IP address that virtually places me in an other geographical place?
raspivid -t 999999 -o – | nc [insert the IP address of the client] 5001
That could be a solution in stead of unblockvpn.
Jörgen
Edit
And how do I revert to original settings?
Krassegrand
Re: Unblock vpn
Wed May 13, 2015 7:00 am
Could this be a solution?
Setting up a second IP address or Virtual IP address
If you need to set up a second ip address you need to edit the /etc/network/interfaces.
sudo vi /etc/network/interfaces
auto eth0:1
iface eth0:1 inet static
address 192.168.1.24
netmask 255.255.255.0
network 192.168.1.1
broadcast 192.168.1.255
gateway 192.168.1.1
For these new settings to take effect you need to restart networking services using the following command
sudo /etc/init.d/networking restart
Jörgen
PS
I have no idea what this does.
Does it go back to original setting after restart?
djme4u
Re: Unblock vpn
Wed May 13, 2015 8:04 am
RSS is the same VP
http://www.ijcsse.org
Krassegrand
Re: Unblock vpn
Wed May 13, 2015 11:36 am
Krassegrand
Re: Unblock vpn
Wed May 27, 2015 6:21 pm
I decide to install openvpn and use my account at unblockvpn.
That is working!
Now I would like to have an icon on the desktop to double click to start my VPN.
I can do like this
[email protected] ~ $ cd unblockvpn
[email protected] ~/unblockvpn $ sudo openvpn --config eu11_united_kingdom.ovpn
That starts the VPN.
and pwd gives
[email protected] ~/unblockvpn $ pwd
/home/pi/unblockvpn
from the folder with eu11_united_kingdom.ovpn
That makes me believe that the full command to be used from anywhere is
/home/pi/unblockvpn/sudo openvpn --config eu11_united_kingdom.ovpn
What am I doing wrong?
[email protected] ~/unblockvpn $ /home/pi/unblockvpn/sudo openvpn --config eu11_united_kingdom.ovpn
bash: /home/pi/unblockvpn/sudo: No such file or directory
Jörgen
kusti8
Re: Unblock vpn
Wed May 27, 2015 7:30 pm
You need to do:
sudo /home/pi/unblockvpn/openvpn --config eu11_united_kingdom.ovpn
Because bash thinks that a program named sudo is there that accepts arguments.
Krassegrand
Re: Unblock vpn
Thu May 28, 2015 6:03 am
Thank You!
I will try that when I get home!
Jörgen
Krassegrand
Re: Unblock vpn
Thu May 28, 2015 3:50 pm
[email protected] ~ $ sudo /home/pi/unblockvpn/openvpn --config eu11_united_kingdom.ovpn
sudo: /home/pi/unblockvpn/openvpn: command not found
Why does it not work?????
Jörgen
