Hi, I don't have knowledge about the "c" (16c84) series so I don't know how to answer your question...Entropic_3105 wrote:Hi,
Recently, I was surfin' the interweb and came across you webpage about using the pi as a pic programmer. It just so happens though that I have a load of pic microcontrollers that I have no means of programming. They are called Pic16c84. Would it be possible to program them using this method at all. I'm asking before I start and learn its a waste of time.
Thanks,
Patrick
If it is the same electrical programming model as the 16F84, then you can probably make it work for the 16c84... take a look at the datasheet to see if they have the same algorithm...
Hope it help...
Valter
