The python script runs and displays the window, but I'm not getting the stream.
I'm sure the UV4l server is running, as it prompts me for a password, and I get the control panel, but the link http://myipaddress:8080/stream doesn't work; it gives an an empty window stating "image".
I also have Motion installed on the same PI using the camera, so have to stop it first.
I can get the stream working if i kill the UV4l process and run the command:
os.system("sudo uv4l --auto-video_nr --width 800 --height 600 --rotation 180 --framerate 2 --driver raspicam --encoding mjpeg --server-option '--admin-password=pw' --server-option '--user-password=pw'")
The script:
#!/usr/bin/env python
import numpy as np
import cv2
import os
os.system('sudo /etc/init.d/motion stop') #to stop any conflict of motion using camera module
os.system ('sudo pkill uv4l')
runtime_frame_count = 0
vid = cv2.VideoCapture(0)
vid.set(3,800)
vid.set(4,600)
while True:
ret, img = vid.read()
runtime_frame_count = runtime_frame_count + 1
print (runtime_frame_count)
cv2.imshow("input",img)
key = cv2.waitKey(10)
if (key == 27) or (runtime_frame_count == 100):
break
cv2.destroyAllWindows()
cv2.VideoCapture(0).release()
<notice> [core] Trying driver 'raspicam' from built-in drivers...
<warning> [core] Driver 'raspicam' not found
<notice> [core] Trying driver 'raspicam' from external plug-in's...
<notice> [driver] Dual Raspicam Video4Linux2 Driver v1.9.26 built Feb 10 2015
<notice> [driver] Selected format: 800x600, encoding: mjpeg, JPEG Video Capture
<notice> [driver] Framerate max. 2 fps
<notice> [driver] ROI: 0, 0, 1, 1
<notice> [core] Device detected!
<warning> [core] Cannot create /dev/video0 because file already exists
<notice> [core] Registering device node /dev/video1
libv4l2: error setting pixformat: Device or resource busy
HIGHGUI ERROR: libv4l unable to ioctl S_FMT
