mlepage
Multiple cameras?
Wed Apr 29, 2015 9:55 pm
I'm interested in connecting two or more cameras and wondering if this is possible.
I'm guessing no, I can't connect two camera modules simultaneously in the CSI slot.
But is there some way maybe to connect two cameras and switch between them serially, so I can take a shot from one then a shot from another in alternating fashion?
If not, what are my options? Cheap light USB cameras?
electronicsguy
Re: Multiple cameras?
Wed Apr 29, 2015 10:00 pm
mlepage wrote:I'm interested in connecting two or more cameras and wondering if this is possible.
Yes, and the simplest way would be to have two different RPis. Connect them thru GPIO to communicate when one is done.
blog: https://electronicsguy.wordpress.com
github: https://github.com/electronicsguy
Wed Apr 29, 2015 10:28 pm
electronicsguy wrote:Connect them thru GPIO to communicate when one is done.
Connecting them by WiFi to a shared access point or ethernet cable to a shared switch is 10^6 times easier.
mlepage
Thu Apr 30, 2015 2:21 pm
Two pi is an option I guess.
So no way to do it with one pi?
ghans
Thu Apr 30, 2015 2:42 pm
The compute module supports two cameras with [email protected]
max.
But using the compute module without the expensive devkit
or an already finshed board is nearly impossible.
ghans
RaTTuS
Contact: Twitter YouTube
Thu Apr 30, 2015 2:49 pm
https://hackaday.io/project/2847-ivport ... ultiplexer
but it will be much easier to use 2 RPI ?
you can use a model A+ adn use serial coms between the 2
or use a CM
which has 2 camera interfaces
a dev kit can be had
http://uk.rs-online.com/web/p/processor ... s/8134164/ <- reasonable cheap now
Covfefe
gordon77
Thu Apr 30, 2015 4:03 pm
You can use 3 usb cameras and switch between them
viewtopic.php?f=43&t=96657&p=694893#p694893
Jednorozec
Fri May 01, 2015 10:11 am
RaTTuS wrote: a dev kit can be had
Not reasonable, not cheap, but not as bad as it was. Half that price would still be expensive! :(
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
pluggy
Fri May 01, 2015 12:47 pm
Its quite easy to do 2 USB cameras on 1 pi.
http://pluggy.duckdns.com
scroll down to the bottom.
Its 1 pi (a b+) running 2 Microsoft VX-800 cameras it takes a still from each once a minute, but they are individually addressable so it could done a lot more frequently.
The VX-800 although long since defunct is readliy available refurbished on ebay.
seregus
Wed May 20, 2015 1:56 pm
Actually the solution you looking for exists.
Simply use Ivmech:
http://www.ivmech.com/magaza/en/ivmech- ... lexer-p-90
physicaccio
Sat Jul 18, 2015 9:44 am
Hello all!
I'm planning a surveillance system for my home.
I would like to connect at least 4 cameras over cat 6 cables to rpi 2. But how many cameras can rpi2 handle? (I read some discussions about it but I don't get the point... Be patient, please!)
I don't want to record 24/7 but I just want to take clear, high quality pictures (as much as rpi2 can) when motion is detected.
So, only one rpi 2 is fine for my job, is it? Or how many do I need?
Thanks in advance for the replies. Regards!
ThomasS
Sat Jul 18, 2015 10:06 am
physicaccio wrote:Hello all!
Looking at this thread you can have one camera module per Pi but several USB cameras. An alternative is separate Pi each with a camera module sending photos to the server Pi to be processed.
ThomasS
StangPi
Wed Feb 24, 2016 9:30 pm
I am working on a project using the RPi and my car. I want to use 2 cameras, and have them send independent feeds to 2 separate screens...most likely a TFT or some other screen.
Any help would be greatly appreciated
RaTTuS
Thu Feb 25, 2016 7:31 am
StangPi wrote:I am working on a project using the RPi and my car. I want to use 2 cameras, and have them send independent feeds to 2 separate screens...most likely a TFT or some other screen.
have 2 RPI
Covfefe
StangPi
Thu Feb 25, 2016 3:48 pm
have 2 RPI
What would be the best way to go about combining 2 RPi? I will also be 3D Printing an enclosure for this once i have the necessary components.
P.S.-I am a n00b when it comes to using the RPi. Currently in school for Computer engineering so this project completion would help me greatly on so many levels. Any advice on use of the RPi would also be very helpful.
Return to “Advanced users”
