enterprise11
Re: HOWTO: Install Kodi on Raspbian
Tue Mar 03, 2015 6:12 pm
Ok, this is my first post and I am a newbee on raspberry... :?:
I've done everything as posted in the tutorial to install kodi as standalone-version on raspbian 2.
Everything works fine, I can do all the settings, I can add addons, I can browse my movies etc from a harddisc, I see the preview pictures etc. etc. BUT: I can't watch a movie. Everytime I start one, it runs very (!, about 10x speed) and I have a black screen (or the menue - because everything is working fine except watching movies...)
I installed OSMC on another micro-sdhc and there are no problems. I have kodi on an android-pc, too, and it works fine... I checked the settings and didn't find anything strange.
So, what's wrong with my installation???
Best regards
Gregor
gkreidl
Wed Mar 04, 2015 6:53 am
enterprise11 wrote:Ok, this is my first post and I am a newbee on raspberry... :?:
Best regards
Gregor
Not enough GPU menory, perhaps. Add or modify in /boot/config.txt
gpu_mem=160
and reboot.
Minimal Kiosk Browser (kweb)
enterprise11
Thu Mar 05, 2015 10:45 am
So I did, but nothing changed. After that I set the gpu_mem=512.
Same result... I'm a little bit confused.
gkreidl
Thu Mar 05, 2015 11:17 am
enterprise11 wrote:So I did, but nothing changed. After that I set the gpu_mem=512.
So am I! It has been working for lots of people so far.
I've installed it on two RPi 2 (and formerly on a a B) and both are really running fine (except for the closing bug which will hopefully be fixed soon).
So there must be something special in your case.
KilroyRock
Thu Mar 05, 2015 3:14 pm
you have your mpeg2 codec license? it would help for a lot of black screen stuff, due to the encoding. inexpensive.
http://www.raspberrypi.com/mpeg-2-license-key/
enterprise11
Thu Mar 05, 2015 3:22 pm
No, I don't have. But it's all h264 stuff I want to play. As I said above, all works fine with OSMC on a separate card, but I would like to have the version "best of both worlds" ;-)
Update: After second reboot, I can see sometimes rotating colourful cubes instead of a black screen or my movie...
marotillo
Fri Mar 06, 2015 9:11 pm
Best regards
Gregor
This is my first post here. Excuse my poor English, it is not my primary language
I decided to post because I have exactly the same problem:
- Everything seems to works fine except when playing a movie.
- Movie progression bar goes faster but a black screen is shown.
- Some online channels plays the sound, but not the images. Instead of images, rotating cubes are shown
- I have OSMC installed in another SD card and everything works fine using the same Raspberry 2 B
gkreidl
Fri Mar 06, 2015 10:54 pm
marotillo wrote: Hello,
Did you see any error messages during installation?
Are you on NOOBS or did you install Raspbian image directly?
How large is your video memory?
marotillo
Sat Mar 07, 2015 10:21 am
Hi again,
I'm happy to say that it's working now!
The problem was the video memory. I did not add the line
gpu_mem=160
in /boot/config.txt because I was not interested in playing HD videos, but it seems to be mandatory to play SD videos too.
Just for complete the information:
No, I didn't. The installation was ok.
Raspian image directly: 2015-02-16-raspbian-wheezy.img
That was the clue. Now it is 160 and works!
Thank you very much for your help!
enterprise11
Sat Mar 07, 2015 3:02 pm
Congratulations!
I'm still not happy with Kodi...
Where exactly did you add the line?
My last lines now look this way:
# NOOBS Auto-generated Settings:
hdmi_force_hotplug=1
config_hdmi_boost=4
overscan_left=24
overscan_right=24
overscan_top=16
overscan_bottom=16
disable_overscan=0
#gpu_mem=512
gpu_mem I tested with different numbers (160, 512, 544 etc.)
Any further suggestions?
Thanks and regards
gkreidl
Sat Mar 07, 2015 4:52 pm
enterprise11 wrote:
#gpu_mem=512
Thanks and regards
Remove the '#' in front, otherwise it has no effect.
enterprise11
Sat Mar 07, 2015 5:49 pm
The # was the problem! Now everything is working fine!!!
Thanks a lot!!!!
cpcbegin
Wed Mar 11, 2015 6:15 am
I install Kodi on Raspbian on a Raspberry pi 2 but I've got a different problem with keyboard and mobile as remote controller.
Using my keyboard for search something, for example:
- If I press a number key some times I get the number, a letter, the following letter and again the number, like an old mobile.
- If I press a different key trigger an action instead show the key.
If I try to use my android mobile with apps like Yatse or XBMC remote control the mobile can't connect with raspberri.
(I can control Kodi only with mouse)
I try this with OpenElec and all runs fine, but I need Kodi under Raspbian because I need a complete web browser and a complete OS.
Thanks in advance.
Trucos y recetas para raspberry pi:
http://malagaoriginal.blogspot.com.es/search/label/raspberry%20pi
gkreidl
Wed Mar 11, 2015 8:39 am
cpcbegin wrote:I install Kodi on Raspbian on a Raspberry pi 2 but I've got a different problem with keyboard and mobile as remote controller.
Thanks in advance.
I've just noticed the same with keyboard text input. No idea yet, what could be done about it. (I've never used Kodi before).
For remote control via smartphone you might try to install some of the event tools from the repository. Install synaptic, search for kodi and you'll find them.
DirkS
Wed Mar 11, 2015 10:36 am
cpcbegin wrote:If I try to use my android mobile with apps like Yatse or XBMC remote control the mobile can't connect with raspberri.
I have no problems controlling Kodi on Raspbian with Yatse.
Make sure Kodi's webserver is activated (Settings / System / Webserver).
Re keyboard. I use a wireless mini keyboard and it works fine. Can't find any relevant settings in Kodi though.
cpcbegin
Sat Mar 14, 2015 3:16 am
Kodi's webserver is activated as you describe, mobile remove controls runs in kodi openelec but not in kodi raspbian :(
Re keyboard. Can you type letters using the real keyboard? again I can do this with openelec but not in raspbian.
Arrow keys runs ok on both scenarios and numbers runs like an old 'non-smart' phone. (I press one, I get a number, I press twice I get a letter, I press again I get next letter, I press again more I get the same number).
cpcbegin
Solved problems with keyboard and smartphone as remote
Tue Mar 17, 2015 8:57 pm
Problem #1: keyboard numbers runs like an old mobile and alphabetical keys don't run property:
Solution: Add to /etc/init.d/rc.local this line:
chmod 0777 /dev/tty0
Problem #2: apps to convert smartphones in remote control don't run:
Solution:
Yatse: changer port from 80 to 8080
XBMC Remote: press update
DirkS
Re: Solved problems with keyboard and smartphone as remote
Tue Mar 24, 2015 4:39 pm
cpcbegin wrote:Problem #1: keyboard numbers runs like an old mobile and alphabetical keys don't run property:
This probably means that user 'kodi' is not in group 'input'
sudo usermod -a -G input kodi
Thanks to forum member 'spendoza' for noticing this...
ekimyar
Thu Mar 26, 2015 10:33 pm
Has anyone been able to apt-get the Unstable packages from deb http://archive.mene.za.net/raspbian wheezy contrib unstable?
I cannot get apt-get to see that kodi offers an unstable package option. It just returns this error:
Release 'unstable' for 'kodi' was not found
I've altered my /etc/apt/source.list file to add the unstable repository, and I added the /etc/apt/preferences file for pinning.... not sure what to do next.
Tom_A
Fri Mar 27, 2015 7:14 am
Latest update has broken the black screen on exit fix I just got working properly. I don't regularly exit Kodi and am mostly running off Raspbian so I can have services running in the background, but it would be nice to not have to reboot to properly exit back to lightdm. I've had the best luck launching Kodi from the login screen.
gkreidl
Fri Mar 27, 2015 7:33 am
Tom_A wrote:Latest update has broken the black screen on exit fix I just got working properly. I don't regularly exit Kodi and am mostly running off Raspbian so I can have services running in the background, but it would be nice to not have to reboot to properly exit back to lightdm. I've had the best luck launching Kodi from the login screen.
Latest update of what?
Tom_A
Fri Mar 27, 2015 7:59 am
I did an apt-get upgrade recently and Kodi had an update. Was hoping that it might fix the black screen problem without the need for the scripts, however it broke the script fix. I've tried turning off the scripts to see if that helped. The three lines that it was recommended to comment out have changed a bit. I tried commenting them out again, but that did not help.
gkreidl
Fri Mar 27, 2015 8:12 am
Latest kodi version is dated Feb, 9th. It seems you haven't updated for quite some time.
Tom_A
Fri Mar 27, 2015 3:56 pm
gkreidl wrote:Latest kodi version is dated Feb, 9th. It seems you haven't updated for quite some time.
I don't think this was a regular update to Kodi. Raspbmc I know has updates and changes occasionally that are not part of the normal Kodi and usually specific to raspberry pi issues. I checked for updates later than Feb 9th to make sure everything was ready to move to the Raspberry Pi B2, but still got another update to Kodi a few days ago over apt-get. You could try doing an apt-get yourself to check for this, but I'd recommend canceling if it does show an update to Kodi if you don't want to break the script functionality.
It was recommended to comment out the last three lines of a file to help fix the issue, however the end of the same file looks like this now:
VT="$(fgconsole)"
if [ "$VT" ]; then
  sudo chvt 7
  sudo chvt "$VT"
fi
gkreidl
Fri Mar 27, 2015 4:12 pm
I ran apt-get yesterday and got no new update. Can you please post the output of
apt-cache showpkg kodi
Return to “Raspbian”
