deighty8
Pidora on PI2 Model B
Sat Mar 14, 2015 3:49 am
Hello,.
I'm new user on raspberry. I try to install some image from noobs to pidora. every image can installed but the pidora cannot installed. The device cannot booting still black screen on my monitor. I was using linux or windows installer still not work. The image i'm using Pidora-2015-R3.img. Is the image compatible for the Pi2 Model B+ ?. and how to installing the image :(
Thankyou.
Re: Pidora on PI2 Model B
Sat Mar 14, 2015 10:52 am
deighty8 wrote:Hello,.
Thankyou.
Pidora has not been ported to the RPi2, you can use Fedora several posts in the Pidora / Fedora section of the Forum
http://www.raspberrypi.org/forums/viewforum.php?f=51
Retired disgracefully.....
B.Goode
Sat Mar 14, 2015 11:08 am
deighty8 wrote:The image i'm using Pidora-2015-R3.img. Is the image compatible for the Pi2 Model B+ ?.
On the Raspberry Pi Foundation Downloads page http://www.raspberrypi.org/downloads/ the version of Pidora offered for download is Pidora-2014-R3.img
If you click on the More info + link, it says "Pi Version supported: Pi 1 only"
(It's not clear whether you have a different image from elsewhere with a different filename.)
deighty8
Mon Mar 16, 2015 7:36 am
Thankyou.
Thankyou fruitoftheloom for the link
Return to “Pidora / Fedora”
