meltwater
Re: import RPi.GPIO as GPIO RuntimeError
Fri Feb 20, 2015 10:02 pm
Just to report that RPi.GPIO 0.5.11 works with the higher pin numbers. I take it that it will make its way into the repository at some stage.
Thanks for the great work on this!
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
DirkS
Fri Feb 20, 2015 10:13 pm
meltwater wrote:Just to report that RPi.GPIO 0.5.11 works with the higher pin numbers. I take it that it will make its way into the repository at some stage.
It's been there for a couple of days now...
meltwater
Fri Feb 20, 2015 11:37 pm
That's good news...chances are it went live, just after I last checked! :)
______________
Houtkamp
Fri Mar 06, 2015 6:59 pm
Has anyone figured out a way to use GPIO yet, or is it still messed up?
It would be great to be able to use this feature...
Bill
DirkS
Fri Mar 06, 2015 7:20 pm
Houtkamp wrote:Has anyone figured out a way to use GPIO yet, or is it still messed up?
Bill
Which feature?
AFAIK updated RPi.GPIO has been fixed *and* in the repo for about 2 weeks now.
If you still have problems you should report them athttp://sourceforge.net/p/raspberry-gpio-python/tickets/
Fri Mar 06, 2015 7:49 pm
sudo apt-get update && sudo apt-get upgrade
Will get the latest RPi.GPIO library.
netelbcn
Sun Mar 08, 2015 9:13 pm
I'm trying to import the RPi.GPIO library, and I have the same error message however I hsve the RPi.GPIO-0.5.11.egg version.
Could you help to me in order to solve this issue?
Thanks!
texy
Sun Mar 08, 2015 9:29 pm
netelbcn wrote:Hi,
Thanks!
....see Dougie's post above.
Texy
netelbcn
Mon Mar 09, 2015 9:34 am
texy, I did these steps:
DougieLawson wrote:sudo apt-get update && sudo apt-get upgrade
And I have now the 0.5.11 versión of the RPi.GPIO library, but I still have the same error (after reboot)
Thanks!
texy
Mon Mar 09, 2015 9:40 am
netelbcn wrote:texy, I did these steps:
Thanks!
Please can you post the error message.
Texy
Mon Mar 09, 2015 9:48 am
Uninstall the version that dpkg/apt-get knows about.
sudo apt-get purge python{,3}-rpi.gpio
Scan your filesystem for all copies of RPi.GPIO
find /usr -name "*RPi*"
remove everything that you find
sudo apt-get install python{,3}-rpi.gpio
to put back a good version.
hayderOICO
Mon Mar 09, 2015 12:17 pm
Thanks!
I believe you may still have the old versions lurking about in your usr/local/lib/python* find and delete them!
netelbcn
Tue Mar 10, 2015 11:12 am
DougieLawson wrote:Uninstall the version that dpkg/apt-get knows about.
I followed these steps, and now it works fine!
Thanks a lot!!
Liam Senior
Fri Jun 05, 2015 6:42 am
Hi all, i have a Pi2 and i am still getting the
RuntimeError: This module can only be run on a Raspberry Pi!
error despite following the fix mentioned above. Help?
-many thanks
texy
Fri Jun 05, 2015 11:59 am
Liam Senior wrote:Hi all, i have a Pi2 and i am still getting the
-many thanks
Which os are you using, and how old is it?
Texy
Fri Jun 05, 2015 4:59 pm
What do you get from
#!/usr/bin/python
import RPi.GPIO
print RPi.GPIO.VERSION
Liam Senior
Sat Jun 06, 2015 6:11 am
OS is raspbian (05-05), RPi.GPIO is 0.5.11, I have python.dev installed if that makes a difference
-many thanks
Sat Jun 06, 2015 9:22 am
You've got an old version of RPi.GPIO hiding in the bowels of your filesystem.
find . -name "*RPi.GPIO*" | xargs sudo rm
Liam Senior
Mon Jun 08, 2015 2:37 am
DougieLawson wrote:You've got an old version of RPi.GPIO hiding in the bowels of your filesystem.
Tried it several times with no luck, program still not running
-many thanks
joan
Mon Jun 08, 2015 7:37 am
Is device tree enabled?
grep device /boot/config.txt
Liam Senior
Tue Jun 09, 2015 6:06 am
joan wrote:Is device tree enabled?
Tried with both enabled and disabled, no luck
-many thanks
Tue Jun 09, 2015 7:28 am
-many thanks
Are you looking at the right config.txt? If using NOOBS boot the system while holding the [SHIFT] key to get the NOOBS recovery system running, it has a config editor.
joan
Tue Jun 09, 2015 7:34 am
Liam Senior wrote: ...
It does not resolve your issue but you need to enable device tree for recent versions of RPi.GPIO. It is broken on non device tree systems.
Return to “Python”
