Fri Apr 27, 2012 3:17 pm
I think the Windoze people (and, in a somewhat different way, also the Mac people) have done a "better" job of stigmatizing the command prompt than the Linux people. In many circles (and I'm guessing that of the OP and also his sock puppet who is posting now, now that the OP has been banned), it is consider immoral (and bordering on illegal) to use the command prompt in Windoze. When you do it, they look at you funny.
This doesn't happen in Linux. Even if you are (were) "grandma and grandpa", if you do drop down to a command prompt (e.g., a "Terminal" window on the "desktop"), people won't start whispering about you. That's a good thing, but it bugs the p*ss out folks like the OP (and his sock puppet(s)).
And, then, of course, there's the old "You had to do *what* with the seat..."
UNIX Airways
Everyone brings one piece of the plane along when they come
to the airport. They all go out on the runway and put the
plane together piece by piece, arguing non-stop about what
kind of plane they are supposed to be building.
Air DOS
Everybody pushes the airplane until it glides, then they jump
on and let the plane coast until it hits the ground again.
Then they push again, jump on again, and so on ...
Mac Airlines
All the stewards, captains, baggage handlers, and ticket agents
look and act exactly the same. Every time you ask questions
about details, you are gently but firmly told that you don't
need to know, don't want to know, and everything will be done
for you without your ever having to know, so just shut up.
Windows Air
The terminal is pretty and colorful, with friendly stewards,
easy baggage check and boarding, and a smooth take-off. After
about 10 minutes in the air, the plane e
0K .xplodes with no warning
whatsoever.
Windows NT Air
Just like Windows Air, but costs more, uses much bigger planes,
and takes out all the other aircraft within a 40-mile radius
when it explodes.
Linux Air
Disgruntled employees of all the other OS airlines decide to
start their own airline. They build the planes, ticket counters,
and pave the runways themselves. They charge a small fee to
cover the cost of printing the ticket, but you can also download
and print the ticket yourself. When you board the plane, you
are given a seat, four bolts, a wrench and a copy of the
seat-HOWTO.html. Once settled, the fully adjustable seat is
very comfortable, the plan leaves and arrives on time without
a single problem, the in-flight meal is wonderful. You try to
tell customers of the other airlines about the great trip, but
all they can say is, "You had to do what with the seat?"
