BennyO
License issue
Wed Feb 11, 2015 8:41 pm
I'm new to this group and just entering because I've got al license issue when starting Mathematica.
When I start Mathematica I get the following screen:
$Failed. The Wolfram language kernel was not able to start due to license terms. For more information or assistance please contact Wolfram research.
I used a new NOOBS installation, as well as an update after removing the original installation.
No questions were asked about acceptance of some license using Wolfram software.
When starting Wolfram in the textbox I was asked for a licence and password. I saw that the generated MachineID was different fron the license in the license file in the version 10.0 directory.
Does anyone have a clou? I hope someone can help me out.
Thanks in advance.
Ben
Re: License issue
Thu Feb 12, 2015 12:40 am
What model of Raspberry Pi are you running? A/B/B+/A+ or 2B?
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
BennyO
Re: License issue
Thu Feb 12, 2015 6:00 am
I'm using the B+.
Registring at Wolfram does not work either.
Re: License issue
Thu Feb 12, 2015 3:46 pm
Try this:
sudo apt-get -y purge wolfram-engine
sudo apt-get -y install wolfram-engine
BennyO
Re: License issue
Thu Feb 12, 2015 4:20 pm
Hi tnx for your advice.
Unfortunately this was also the first option I tried.
But it didam not help. May be I should create a new sd card.
Afaik no registration is needed at Wolframs site?
So when someone has an idea how to solve this problem I'll give it a try.
Tnx Ben
r3d4
Re: License issue
Thu Feb 12, 2015 4:25 pm
BennyO wrote:I'm using the B+.
How is it failing to work ,.... have you tryed launching it from a terminal ?
When launching it from a terminal what out put is displayed if any ?
BennyO
Re: License issue
Thu Feb 12, 2015 6:14 pm
When I start from the terminal, wolfram.
I get sometimes the editor mode where I can enter my expressions.
But mostmy, after I started mathematica I get the message in the terminal
Mathematics cannot find a valid password
For automatic web activation enter your activation key
Then it comes with the machine name and mathid, asks the activation key again and stops working
Ben
BennyO
Re: License issue
Thu Feb 12, 2015 7:08 pm
I did a clean install again and now it seems te work. The former install was also a clean one.
Don't know what went wrong, I'm happy it works now.
Case closed
ssteel
Re: License issue
Thu Feb 12, 2015 8:43 pm
I wouldn't like to close this case just yet ;)
I have had the exact same problem occurring on my RPi2. I believe it triggered after I updated my Raspbian January 2015 firmware with rpi-update.
Wolfram in console would work but not Mathematica and I had not messed around with its files.
Purging and reinstalling wolfram-engine, also cleaning /home/pi related conf files did not work.
Only reinstalling again the Raspbian img got everything OK again.
My hunch is that Mathematica license is somehow linked to some machine ID which maybe is changing after modifying kernel files?
PS: contacting Wolfram through the License error message they kindly replied that Mathematica for RPi is supported by raspberrypi.org and to contact them for further info about this issue.
mimi123
Re: License issue
Fri Feb 13, 2015 11:55 am
ssteel wrote:I wouldn't like to close this case just yet ;)
The serial number format sent by the blob has changed. The SoC info for the RPi2 is BCM2709, unlike the Pi1. You can use a modified PRoot to bind a modified /proc/cpuinfo, it works(TM).
bobthechemist
Re: License issue
Mon Feb 16, 2015 3:02 am
There were some license issues recognized with earlier (pre Feb 03 2015) versions of Mathematica on the RPi 2. Check $Version to see if you have the latest (should have the Feb 3, 2015 date) and upgrade if necessary. If your still running in to problems, then the latest version isn't the issue.
dom
Re: License issue
Tue Feb 24, 2015 1:42 pm
Serial number is not used for licence check and registering is not required.
Report the output of "$Version" and also from console
vcgencmd version
uname -a
ssteel
Re: License issue
Thu Feb 26, 2015 10:26 pm
Thanks everyone, the issue I was having was solved several days ago with the february apt-upgrade of Raspbian and/or a recent update available for Mathematica package - it's been working solidly since.
Cheers!
PS: just for info:
In[1]:= $Version
Out[1]= "10.0 for Linux ARM (32-bit) (February 3, 2015)"
[email protected] ~ $ vcgencmd version
Feb 14 2015 22:23:03
Copyright (c) 2012 Broadcom
version 7789db485409720b0e523a3d6b86b12ed56fd152 (clean) (release)
[email protected] ~ $ uname -a
Linux raspberrypi 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux
richrarobi
Re: License issue
Sat Mar 07, 2015 2:06 pm
I am concerned about hidden costs behind the licensing deal with Wolfram. What do you get access to on Raspberry pi? Do you have access to the full Wolfram cloud system? Or is it a marketing ploy to get thousands of school-kids indoctrinated, and the schools paying the annual fees? What when they leave school?
Are you able to do the things that Wolfram talks about in his video on the Wolfram site without paying through the nose?
Can someone make a clear statement, please? Please.
While I do have dreams about this sort of data being available to everyone through an eye-screen headset (or better) all the time (Some people are already wearing blue-tooth headsets for their phones (aka that Dr Who episode!!)), I find the £15 a month it seems to cost to be prohibitive to even begin to think about using it.
We need all those young up and coming robotics scientists to have full and free access to this sort of technology, so that it can be developed to its full potential.
RichR
p.s. The free starter account is extremely limited.
The Wolfram Cloud is available with a free starter account, and has additional non-free accounts which enable additional functionality.
Re: License issue
Sat Mar 07, 2015 2:35 pm
richrarobi wrote:I am concerned about hidden costs behind the licensing deal with Wolfram. What do you get access to on Raspberry pi? Do you have access to the full Wolfram cloud system? Or is it a marketing ploy to get thousands of school-kids indoctrinated, and the schools paying the annual fees? What when they leave school?
RichR
You get what you get. Wolfram spent a lot of time and money producing this software, so you are not going to get it (other than the version of the Pi) for free.
Don't look a gift horse in the mouth is the phrase that comes to mind here. Yes, Wolfram want to get people interested in their product. No, you don't have to use it if you don't want to pay for it.
I'm not sure exactly what you get with the Pi version, but it is documented somewhere.
richrarobi
Re: License issue
Sat Mar 07, 2015 4:27 pm
Maybe:-
http://googleresearch.blogspot.co.uk/20 ... -with.html
RichR
gkreidl
Re: License issue
Sat Mar 07, 2015 5:02 pm
You can still do a lot with Wolfram/Mathematica without using the cloud.
Minimal Kiosk Browser (kweb)
kusti8
Re: License issue
Sat Mar 07, 2015 5:06 pm
gkreidl wrote:You can still do a lot with Wolfram/Mathematica without using the cloud.
+1
I opened Mathematica on my new pi2 and was shocked at how fast it was. You could now easily scroll through pages of commands and it was really great. You can do a ton with it!
Re: License issue
Sat Mar 07, 2015 8:25 pm
richrarobi wrote:Can someone make a clear statement, please? Please.
Maybe:-
RichR
How about this: http://blog.wolfram.com/2013/11/21/putt ... pberry-pi/
mob-i-l
Contact: Website Facebook Google+ Twitter YouTube
Re: License issue
Mon Apr 20, 2015 8:05 pm
richrarobi wrote:We need all those young up and coming robotics scientists to have full and free access to this sort of technology, so that it can be developed to its full potential
Maxima is a good FOSS alternative to Mathematica:
sudo apt-get install wxmaxima
Have Pi0&1A&1B&1B+&2B&3B&4B w/ Raspbian. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
lmqr15
Re: License issue
Sun Jul 12, 2015 1:37 pm
though a license number 1234-1234-123456 is accepted, you still need a pwd to use wolfram. It quits whatever pwd you try. And mind you I am not trying to crack this, just to see if i can use it for one of my projects
so, having it pre-installed on the noobs image does not help much.
carlosap78
Re: License issue
Sat Dec 12, 2015 7:02 pm
user pi works well
but with another user fails to run
mxue
Re: License issue
Thu Dec 17, 2015 9:57 am
Try this one:
http://www.vroomlab.com/omega
it is a free web CAS
marthasimons
Re: License issue
Mon May 07, 2018 5:36 am
Cool! Thank you
ejolson
Re: License issue
Mon May 07, 2018 7:13 am
Perhaps related to some of the posts on this thread is the fact that Mathematica returns a licensing error unless the current user is a member of the video group. While this is true by default for the pi user, best security practices encourage disabling the pi user and creating an account with a less easily guessed username. Add all users who want access to Mathematica to the video group and things should work fine.
Return to “Mathematica”
