jdb
The Raspberry Pi 2 Q&A thread
Tue Feb 03, 2015 12:04 am
Somewhat belatedly, here's the official Q&A thread.
Before posting, please read the blog post:
http://www.raspberrypi.org/raspberry-pi-2-on-sale/
and assorted comment responses from Foundation members:
http://www.raspberrypi.org/raspberry-pi ... /#comments
before posting in this thread.
Belated because our website was on fire for pretty much all of the launch day.
Rockets are loud.
https://astro-pi.org
mahjongg
Re: The Raspberry Pi 2 Q&A thread
Tue Feb 03, 2015 12:24 am
yeah, i only could get in and do some moderation after midnight!
Tue Feb 03, 2015 12:28 am
jdb wrote: Belated because our website was on fire for pretty much all of the launch day.
The forum was deliberately blocked from 10:30GMT until 23:30GMT.
jdb
Tue Feb 03, 2015 12:31 am
Our website was on fire *despite* load-shedding the forums. Your point?
Rockets are loud.
Tue Feb 03, 2015 12:34 am
<OFF-TOPIC type="annoyance">
The point being that the Foundation knew they were going to launch today, they could have rented extra capacity from Mythic to support the expected extreme workload (based on extrapolating figures from July (B+) and November (A+)). Removing a significant support resource isn't good for the community.
</OFF-TOPIC>
Normal service is now resumed.
jdb
Tue Feb 03, 2015 12:39 am
DougieLawson wrote: The point being that the Foundation knew they were going to launch today, they could have rented extra capacity from Mythic to support the expected extreme workload (based on extrapolating figures from July (B+) and November (A+)). Removing a significant support resource isn't good for the community.
So for a 13 hour period where the primary purpose of this site was to inform, rather than to discuss, we should have spent at least order of magnitude more on bandwidth, computational resource and logistics to ensure that the discussion platform was available for those precious 13 hours?
As far as I know, RS and element14 do not yet offer same-day delivery (unless you happened to be in London today and spotted a certain bicycle wandering around town). Therefore as a support resource (where discussion is required), having the site available in preference to an informational resource offers little value.
Edit: now that the conflagration is "over" and the load averages on our server are now back down in the sub-1000 range, we can resume normal service.
Rockets are loud.
TimG
Tue Feb 03, 2015 12:52 am
I'm curious about ARMv6 vs ARMv7. I understand from the announcement that the new CPU can run Raspbian ARMv6 code, but presumably standard Debian ARMv7 code will be faster. Can we switch between Raspbian and Debian repositories without running into problems?
Lob0426
Tue Feb 03, 2015 12:55 am
Has the Foundation ran any performance tests on the Micro SD and the USB that show improvement?
Though I have not seen any corruption issues with the newest software updates (in more than a year), do you expect any of these issues to reoccur in the new board?
I have seen mention that the USB on chip was not modified. I have not heard much mention about the SD transfers as yet.
512MB version 2.0 as WordPress Server
Motorola Lapdock with Pi2B
Modded Rev 1.0 with pin headers at USB
http://rich1.dyndns.tv/
(RS)Allied ships old stock to reward its Customers for long wait!
Tue Feb 03, 2015 12:57 am
The DebIan stuff should run OK. The problem with making that recommendation is that it WILL badly destroy the Raspbian installation for PI1 A,B,A+,B+ users.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
jdb
Tue Feb 03, 2015 1:01 am
Lob0426 wrote:Has the Foundation ran any performance tests on the Micro SD and the USB that show improvement?
uSD generally wasn't CPU limited on 2835.
There was a fix that went in recently that disables CMD23-prefixed transfers - a mode that predefines transfer lengths - there's some complicated state tracking in there that was getting messed up on the fastest of SD cards in extreme circumstances. We encountered this on rare occasions with certain types of SD card, but this became slightly more prevalent on Pi2. We need some bus-level analysis to be carried out before we can safely switch CMD23 back on again.
CMD23 simply allows higher-performing cards to perform faster - the flash controller knows how much data is getting written or read so it can pre-emptively compute which flash pages to open, etc.
USB performance is "better". The software overhead becomes less as you increase CPU power - for instance a USB SSD goes from about 27MB/s on Pi1 to 31MB/s on Pi2.
Rockets are loud.
jdb
Tue Feb 03, 2015 1:04 am
TimG wrote:I'm curious about ARMv6 vs ARMv7. I understand from the announcement that the new CPU can run Raspbian ARMv6 code, but presumably standard Debian ARMv7 code will be faster. Can we switch between Raspbian and Debian repositories without running into problems?
Currently the ARMv6 userland (Raspbian et al) is default.
Once we do some performance comparisons (v6 versus v7 compiled libraries/binaries etc) then we may decide to:
- Have a v6 userland as performance improvements are negligible
- Have a hybrid v6 / v7 userland that takes advantage of parallelism at the library level (dynamically selected at boot-time)
- Transition to a v7 userland (least desirable, mandates separate SD card images).
As yet there is insufficient data to formulate a plan. Raspbian is our officially supported OS and will remain so.
Rockets are loud.
mckenzba
Tue Feb 03, 2015 1:13 am
Since the new BCM2836 is a Cortex-A7 chip and we know it supports neon (and presumably vfpv4-d32/udiv/sdiv), does this chip also support hardware virtualization? (It would be really cool to run xen on this thing!)
jdb
Tue Feb 03, 2015 1:17 am
mckenzba wrote:Since the new BCM2836 is a Cortex-A7 chip and we know it supports neon (and presumably vfpv4-d32/udiv/sdiv), does this chip also support hardware virtualization? (It would be really cool to run xen on this thing!)
The Cortex-A7 architecture has built-in support for Hypervisor modes and some tricks that make virtualisation "easier".
Further reading:
http://www.slideshare.net/xen_com_mgr/h ... processors
Rockets are loud.
gdw35
Tue Feb 03, 2015 1:19 am
I currently have a Model B that I have set up for media and gaming, as well as a bit of development (also have LCD display attached). I was hoping I could just swap this out for the Pi 2. Am I able to just copy the SD card I am using for the Model B to a micro -SD for use on the Pi 2, or do I need to start from scratch again and set it all up again?
If I can just copy the SD card is there anything I need to do or change after booting the first time (i.e. config changes, setup, etc.)?
Thanks.
jdb
Tue Feb 03, 2015 1:24 am
gdw35 wrote:I currently have a Model B that I have set up for media and gaming, as well as a bit of development (also have LCD display attached). I was hoping I could just swap this out for the Pi 2. Am I able to just copy the SD card I am using for the Model B to a micro -SD for use on the Pi 2, or do I need to start from scratch again and set it all up again?
Thanks.
To use an existing card on Pi2 you need
- Recent firmware
- kernel7.img
- ARMv7 kernel modules.
To upgrade an SD card for Pi 2 use:
sudo apt-get update && sudo apt-get upgrade
Rockets are loud.
plugwash
Tue Feb 03, 2015 1:46 am
Are there new config.txt parameters to allow seperately specifying armv6 and armv7 kernels/initrds ?
Applicable_Robotics
Tue Feb 03, 2015 1:52 am
Does the foundation have a time frame for the release of the Compute Module 2?
Also, have you considered making a version of the compute module that uses a microSD card instead of a fixed size eMMC chip? That also might eliminate the eMMC disable circuit?
Maybe another solution is using a header similar to the one on the Intel Edison as a storage connector.
I think a lot of applications would benefit from allowing the user to increase the size of the storage as needed.
Nicholas
psergiu
Tue Feb 03, 2015 1:57 am
Will MPEG2 and VC-1 licences still be needed for hardware-decoding ?
Or is the new quad-core CPU fast enough that it would not matter anymore ?
Thanks.
gdw35
Tue Feb 03, 2015 1:58 am
jdb wrote:To use an existing card on Pi2 you need
- Recent firmware
- kernel7.img
Thanks for reply.
So prior to copying card do the update and upgrade to ensure all up to date and then repeat after running up copy on new Pi?
rpiswag
Tue Feb 03, 2015 2:11 am
Can I over clock the new Raspberry Pi 2 model B? Can I overclock it to 1.2ghz or higher? I was wondering this because windows 10 is quite intensive especially on a Raspberry Pi and overclocking would make windows run smoother.
A computer's power can't be just measured Gigahertz. It is the same thing with us humans.
Efcis
Tue Feb 03, 2015 2:19 am
According to other posts, Win10 for Pi2 won't have any GUI. Can you confirm ?
And what about the Ubuntu distro for the Pi2 ?
Thanks !
ric96
Tue Feb 03, 2015 2:28 am
will their be support for android (unofficially, i know their wont be any from the foundation itself) now that the hardware is more than capable?
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: [email protected]
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
ktb
Tue Feb 03, 2015 4:25 am
ric96 wrote:will their be support for android (unofficially, i know their wont be any from the foundation itself) now that the hardware is more than capable?
Since you know that Android on the Pi2 will be unofficial if it happens, how can that be answered by any person right now? If you build it, they will come.
ktb
Tue Feb 03, 2015 4:46 am
Efcis wrote:According to other posts, Win10 for Pi2 won't have any GUI. Can you confirm ?
Thanks !
Everything I've seen about Win10 IoT suggests that it is all CLI. Maybe the Pi2 can run (limited?) GUI apps that have been deployed to it though? I haven't found any certain information.
I've seen a couple seemingly relevant Ubuntu Snappy Core demo videos on YouTube. Those seemed to only demonstrate using it as a cloud server with remote web GUIs.
I'd like to know more too.
Nightwing2012
Tue Feb 03, 2015 4:48 am
Cannot find this item...
Will the RPI 2 handled above 32GB SDHC style cards.
Tnks for any information!
