Hello All,
I would like to thank this entire community for the support on this subject. I have spent my weekend attempting to configure my pi with the pican board. I seem to be getting pretty close to being able to use this pican board with the canutils, but I cant seem to get any output from candump even when sending sending data to the can device from another terminal. I noticed I have two major issues:
1.) Bit timing not defined - in dmesg (provided below)
2.) no bittiming in the dir: /sys/class/net/can0
root@raspberrypi:/sys/class/net/can0# ls
addr_assign_type addr_len carrier dev_id duplex ifalias iflink mtu operstate power speed subsystem type
address broadcast device dormant flags ifindex link_mode netdev_group phys_port_id queues statistics tx_queue_len uevent
I'm not sure if this has anything to do with my issue, but I have tried just about everything, and still cannot seem to get this to work correctly
Please help!
Further details:
root@raspberrypi:~# uname -a
Linux raspberrypi 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l GNU/Linux
(full dmesg found below)
[ 166.221222] mcp251x spi0.0: unable to set initial baudrate!
[ 167.222442] mcp251x spi0.0 can0: bit-timing not yet defined
[ 167.222480] mcp251x spi0.0: unable to set initial baudrate!
[ 168.223704] mcp251x spi0.0 can0: bit-timing not yet defined
[ 168.223742] mcp251x spi0.0: unable to set initial baudrate!
[ 169.224965] mcp251x spi0.0 can0: bit-timing not yet defined
[ 169.225003] mcp251x spi0.0: unable to set initial baudrate!
[ 170.226204] mcp251x spi0.0 can0: bit-timing not yet defined
[ 170.226239] mcp251x spi0.0: unable to set initial baudrate!
[ 171.227436] mcp251x spi0.0 can0: bit-timing not yet defined
[ 171.227472] mcp251x spi0.0: unable to set initial baudrate!
[ 172.228669] mcp251x spi0.0 can0: bit-timing not yet defined
[ 172.228708] mcp251x spi0.0: unable to set initial baudrate!
[ 173.229941] mcp251x spi0.0 can0: bit-timing not yet defined
[ 173.229979] mcp251x spi0.0: unable to set initial baudrate!
[ 174.231030] mcp251x spi0.0 can0: bit-timing not yet defined
[ 174.231066] mcp251x spi0.0: unable to set initial baudrate!
root@raspberrypi:~# cat /sys/bus/spi/devices/*/modalias
spi:mcp2515
spi:spidev
root@raspberrypi:~# cat /proc/interrupts
CPU0
3: 7083 ARMCTRL BCM2708 Timer Tick
16: 0 ARMCTRL bcm2708_fb dma
32: 66894 ARMCTRL dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
52: 0 ARMCTRL BCM2708 GPIO catchall handler
65: 28 ARMCTRL ARM Mailbox IRQ
66: 1 ARMCTRL VCHIQ doorbell
75: 1 ARMCTRL
77: 6259 ARMCTRL bcm2708_sdhci (dma)
80: 10 ARMCTRL bcm2708_spi.0
83: 19 ARMCTRL uart-pl011
84: 9725 ARMCTRL mmc0
FIQ: usb_fiq
Err: 0
root@raspberrypi:~# ip -s -d link show can0
4: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT qlen 10
link/can
can state STOPPED restart-ms 0
bitrate 0 sample-point 0.000
tq 0 prop-seg 0 phase-seg1 0 phase-seg2 0 sjw 0
mcp251x: tseg1 3..16 tseg2 2..8 sjw 1..4 brp 1..64 brp-inc 1
clock 8000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 0 0 0
RX: bytes packets errors dropped overrun mcast
0 0 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
(sorry first time posting (hope this doesn't spam the forum))
root@raspberrypi:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.28+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #709 PREEMPT Mon Sep 8 15:28:00 BST 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1b800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c061dd90, node_mem_map c06cf000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=592 bcm2708_fb.fbheight=448 bcm2708.boardrev=0xe bcm2708.serial=0xf06ee0cd smsc95xx.macaddr=B8:27:EB:6E:E0:CD sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439532K/458752K available (4498K kernel code, 242K rwdata, 1344K rodata, 143K init, 701K bss, 19220K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05bca24 (5843 kB)
[ 0.000000] .init : 0xc05bd000 - 0xc05e0eac ( 144 kB)
[ 0.000000] .data : 0xc05e2000 - 0xc061e8a0 ( 243 kB)
[ 0.000000] .bss : 0xc061e8ac - 0xc06ce080 ( 702 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001171] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001231] pid_max: default: 32768 minimum: 301
[ 0.001750] Mount-cache hash table entries: 512
[ 0.002574] Initializing cgroup subsys memory
[ 0.002685] Initializing cgroup subsys devices
[ 0.002722] Initializing cgroup subsys freezer
[ 0.002755] Initializing cgroup subsys blkio
[ 0.002904] CPU: Testing write buffer coherency: ok
[ 0.003372] Setting up static identity map for 0xc04487f8 - 0xc0448854
[ 0.005322] devtmpfs: initialized
[ 0.021306] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.022887] NET: Registered protocol family 16
[ 0.028213] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.028898] cpuidle: using governor ladder
[ 0.028945] cpuidle: using governor menu
[ 0.029347] bcm2708.uart_clock = 0
[ 0.031432] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.031494] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.031529] mailbox: Broadcom VideoCore Mailbox driver
[ 0.031626] bcm2708_vcio: mailbox at f200b880
[ 0.031732] bcm_power: Broadcom power driver
[ 0.031769] bcm_power_open() -> 0
[ 0.031793] bcm_power_request(0, 8)
[ 0.532530] bcm_mailbox_read -> 00000080, 0
[ 0.532569] bcm_power_request -> 0
[ 0.532823] Serial: AMBA PL011 UART driver
[ 0.532997] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.891468] console [ttyAMA0] enabled
[ 0.918599] bio: create slab <bio-0> at 0
[ 0.924138] SCSI subsystem initialized
[ 0.928138] usbcore: registered new interface driver usbfs
[ 0.933845] usbcore: registered new interface driver hub
[ 0.939406] usbcore: registered new device driver usb
[ 0.945981] Switched to clocksource stc
[ 0.950255] FS-Cache: Loaded
[ 0.953421] CacheFiles: Loaded
[ 0.969314] NET: Registered protocol family 2
[ 0.975122] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.982536] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.989128] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.995576] TCP: reno registered
[ 0.998873] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.004745] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.011519] NET: Registered protocol family 1
[ 1.016504] RPC: Registered named UNIX socket transport module.
[ 1.022464] RPC: Registered udp transport module.
[ 1.027270] RPC: Registered tcp transport module.
[ 1.031993] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.039328] bcm2708_dma: DMA manager at f2007000
[ 1.044070] bcm2708_gpio: bcm2708_gpio_probe c05efef0
[ 1.049642] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.059225] audit: initializing netlink socket (disabled)
[ 1.064733] type=2000 audit(0.910:1): initialized
[ 1.235047] VFS: Disk quotas dquot_6.5.2
[ 1.239410] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.248380] FS-Cache: Netfs 'nfs' registered for caching
[ 1.255290] NFS: Registering the id_resolver key type
[ 1.260626] Key type id_resolver registered
[ 1.264834] Key type id_legacy registered
[ 1.269643] msgmni has been set to 874
[ 1.275384] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.283245] io scheduler noop registered
[ 1.287325] io scheduler deadline registered (default)
[ 1.292803] io scheduler cfq registered
[ 1.298016] BCM2708FB: allocated DMA memory 5bc00000
[ 1.303063] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.310846] bcm2708_fb_pan_display(0,0) returns=0
[ 1.313085] Console: switching to colour frame buffer device 74x28
[ 1.313635] bcm2708_fb_pan_display(0,0) returns=0
[ 1.336716] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.347262] uart-pl011 dev:f1: no DMA platform data
[ 1.354255] vc-cma: Videocore CMA driver
[ 1.359699] vc-cma: vc_cma_base = 0x00000000
[ 1.365790] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.372627] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.388974] brd: module loaded
[ 1.398759] loop: module loaded
[ 1.403541] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.414144] Loading iSCSI transport class v2.0-870.
[ 1.421756] usbcore: registered new interface driver smsc95xx
[ 1.429425] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.636811] Core Release: 2.80a
[ 1.641334] Setting default values for core params
[ 1.647582] Finished setting default values for core params
[ 1.854589] Using Buffer DMA mode
[ 1.859334] Periodic Transfer Interrupt Enhancement - disabled
[ 1.866611] Multiprocessor Interrupt Enhancement - disabled
[ 1.873592] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.879370] Dedicated Tx FIFOs mode
[ 1.884567] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 1.897241] FIQ FSM acceleration enabled for :
[ 1.897241] Non-periodic Split Transactions
[ 1.897241] Periodic Split Transactions
[ 1.897241] High-Speed Isochronous Endpoints
[ 1.919346] dwc_otg: Microframe scheduler enabled
[ 1.919442] WARN::hcd_init:473: FIQ at 0xc0321550
[ 1.925572] WARN::hcd_init:474: FIQ ASM at 0xc0321800 length 36
[ 1.932945] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
[ 1.940076] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.946438] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.956452] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.963378] Init: Port Power? op_state=1
[ 1.968720] Init: Power Port (0)
[ 1.973637] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.983215] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.993285] usb usb1: Product: DWC OTG Controller
[ 1.999477] usb usb1: Manufacturer: Linux 3.12.28+ dwc_otg_hcd
[ 2.006792] usb usb1: SerialNumber: bcm2708_usb
[ 2.013622] hub 1-0:1.0: USB hub found
[ 2.019006] hub 1-0:1.0: 1 port detected
[ 2.024825] dwc_otg: FIQ enabled
[ 2.024844] dwc_otg: NAK holdoff enabled
[ 2.024853] dwc_otg: FIQ split-transaction FSM enabled
[ 2.024874] Module dwc_common_port init
[ 2.025323] usbcore: registered new interface driver usb-storage
[ 2.033265] mousedev: PS/2 mouse device common for all mice
[ 2.041048] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[ 2.048472] bcm2835-cpufreq: switching to governor powersave
[ 2.055582] bcm2835-cpufreq: switching to governor powersave
[ 2.062790] sdhci: Secure Digital Host Controller Interface driver
[ 2.070462] sdhci: Copyright(c) Pierre Ossman
[ 2.076392] sdhci: Enable low-latency mode
[ 2.126047] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.136942] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.144413] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.151744] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.161534] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.176110] usbcore: registered new interface driver usbhid
[ 2.183272] usbhid: USB HID core driver
[ 2.193236] TCP: cubic registered
[ 2.200091] Initializing XFRM netlink socket
[ 2.207893] NET: Registered protocol family 17
[ 2.213989] Key type dns_resolver registered
[ 2.223140] Indeed it is in host mode hprt0 = 00021501
[ 2.234101] registered taskstats version 1
[ 2.247268] Waiting for root device /dev/mmcblk0p6...
[ 2.277310] mmc0: new high speed SDHC card at address 0002
[ 2.296265] mmcblk0: mmc0:0002 00000 7.32 GiB
[ 2.308827] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.401956] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.413226] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 2.431068] devtmpfs: mounted
[ 2.436223] Freeing unused kernel memory: 140K (c05bd000 - c05e0000)
[ 2.446238] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.454421] Indeed it is in host mode hprt0 = 00001101
[ 2.656481] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.666636] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.677890] hub 1-1:1.0: USB hub found
[ 2.683723] hub 1-1:1.0: 5 ports detected
[ 2.966344] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.086552] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.104980] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.131055] smsc95xx v1.0.4
[ 3.204285] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6e:e0:cd
[ 3.306290] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.437976] usb 1-1.3: New USB device found, idVendor=7392, idProduct=7811
[ 3.456195] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.480950] usb 1-1.3: Product: 802.11n WLAN Adapter
[ 3.495784] usb 1-1.3: Manufacturer: Realtek
[ 3.505600] usb 1-1.3: SerialNumber: 00e04c000001
[ 4.019073] udevd[156]: starting version 175
[ 5.086468] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 5.293068] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 6.209321] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 7.814742] usbcore: registered new interface driver rtl8192cu
[ 11.360636] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 11.832753] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 12.786682] spi_config_register: device description: bus=0:cs=0:modalias=mcp2515:speed=10000000:gpioirq=25:pd=20:pds32-0=16000000:pdu32-4=0x2002:force_release
[ 12.805642] spi_config_match_cs: SPI0: check CS=0 to be 0
[ 12.812881] spi_config_match_cs: SPI0.0: Found a device with modinfo spidev
[ 12.822901] spi_config_register:spi0.0:mcp2515: found already registered device
[ 12.833153] spi_config_register:spi0.0:mcp2515: forcefully-releasing already registered device taints kernel
[ 12.848997] spi_config_register:spi0.0: registering modalias=mcp2515 with max_speed_hz=10000000 mode=0 and gpio/irq=25/195
[ 12.880940] spi_config_register:spi0.0:platform data:da2b3e20: 00 24 f4 00 02 20 00 00 00 00 00 00 00 00 00 00 .$... ..........
[ 12.896561] spi_config_register:spi0.0:platform data:da2b3e30: 00 00 00 00 ....
[ 12.939403] CAN device driver interface
[ 13.008351] mcp251x spi0.0: probed
[ 18.590491] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 21.338968] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 21.940758] mcp251x spi0.0 can0: bit-timing not yet defined
[ 21.940799] mcp251x spi0.0: unable to set initial baudrate!
[ 21.941209] mcp251x spi0.0 can0: bit-timing not yet defined
[ 21.941236] mcp251x spi0.0: unable to set initial baudrate!
[ 21.941288] mcp251x spi0.0 can0: bit-timing not yet defined
[ 21.941306] mcp251x spi0.0: unable to set initial baudrate!
[ 21.941351] mcp251x spi0.0 can0: bit-timing not yet defined
[ 21.941369] mcp251x spi0.0: unable to set initial baudrate!
[ 21.941414] mcp251x spi0.0 can0: bit-timing not yet defined
[ 21.941432] mcp251x spi0.0: unable to set initial baudrate!
[ 22.945054] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 23.043474] mcp251x spi0.0 can0: bit-timing not yet defined
[ 23.043508] mcp251x spi0.0: unable to set initial baudrate!
[ 24.044719] mcp251x spi0.0 can0: bit-timing not yet defined
[ 24.044757] mcp251x spi0.0: unable to set initial baudrate!
[ 25.045936] mcp251x spi0.0 can0: bit-timing not yet defined
[ 25.046043] mcp251x spi0.0: unable to set initial baudrate!
[ 26.047229] mcp251x spi0.0 can0: bit-timing not yet defined
[ 26.047264] mcp251x spi0.0: unable to set initial baudrate!
[ 27.048440] mcp251x spi0.0 can0: bit-timing not yet defined
[ 27.048479] mcp251x spi0.0: unable to set initial baudrate!
[ 28.049674] mcp251x spi0.0 can0: bit-timing not yet defined
[ 28.049710] mcp251x spi0.0: unable to set initial baudrate!
[ 29.050899] mcp251x spi0.0 can0: bit-timing not yet defined
[ 29.050936] mcp251x spi0.0: unable to set initial baudrate!
[ 30.052143] mcp251x spi0.0 can0: bit-timing not yet defined
[ 30.052181] mcp251x spi0.0: unable to set initial baudrate!
[ 31.053386] mcp251x spi0.0 can0: bit-timing not yet defined
[ 31.053424] mcp251x spi0.0: unable to set initial baudrate!
[ 32.054648] mcp251x spi0.0 can0: bit-timing not yet defined
[ 32.054686] mcp251x spi0.0: unable to set initial baudrate!
[ 32.704411] bcm2835-cpufreq: switching to governor ondemand
[ 32.704444] bcm2835-cpufreq: switching to governor ondemand
[ 33.055892] mcp251x spi0.0 can0: bit-timing not yet defined
[ 33.055929] mcp251x spi0.0: unable to set initial baudrate!
[ 34.056260] mcp251x spi0.0 can0: bit-timing not yet defined
[ 34.056297] mcp251x spi0.0: unable to set initial baudrate!
[ 34.957990] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 35.057495] mcp251x spi0.0 can0: bit-timing not yet defined
[ 35.057533] mcp251x spi0.0: unable to set initial baudrate!
[ 36.058764] mcp251x spi0.0 can0: bit-timing not yet defined
[ 36.058800] mcp251x spi0.0: unable to set initial baudrate!
[ 37.060011] mcp251x spi0.0 can0: bit-timing not yet defined
[ 37.060046] mcp251x spi0.0: unable to set initial baudrate!
[ 38.061253] mcp251x spi0.0 can0: bit-timing not yet defined
[ 38.061288] mcp251x spi0.0: unable to set initial baudrate!
[ 39.062494] mcp251x spi0.0 can0: bit-timing not yet defined
[ 39.062530] mcp251x spi0.0: unable to set initial baudrate!
[ 40.063736] mcp251x spi0.0 can0: bit-timing not yet defined
[ 40.063771] mcp251x spi0.0: unable to set initial baudrate!
[ 41.064976] mcp251x spi0.0 can0: bit-timing not yet defined
[ 41.065014] mcp251x spi0.0: unable to set initial baudrate!
[ 42.066258] mcp251x spi0.0 can0: bit-timing not yet defined
[ 42.066294] mcp251x spi0.0: unable to set initial baudrate!
[ 43.067497] mcp251x spi0.0 can0: bit-timing not yet defined
[ 43.067535] mcp251x spi0.0: unable to set initial baudrate!
[ 44.068742] mcp251x spi0.0 can0: bit-timing not yet defined
[ 44.068781] mcp251x spi0.0: unable to set initial baudrate!
[ 45.069985] mcp251x spi0.0 can0: bit-timing not yet defined
[ 45.070021] mcp251x spi0.0: unable to set initial baudrate!
[ 46.071244] mcp251x spi0.0 can0: bit-timing not yet defined
[ 46.071283] mcp251x spi0.0: unable to set initial baudrate!
[ 47.072498] mcp251x spi0.0 can0: bit-timing not yet defined
[ 47.072536] mcp251x spi0.0: unable to set initial baudrate!
[ 48.073759] mcp251x spi0.0 can0: bit-timing not yet defined
[ 48.073797] mcp251x spi0.0: unable to set initial baudrate!
[ 49.075024] mcp251x spi0.0 can0: bit-timing not yet defined
[ 49.075063] mcp251x spi0.0: unable to set initial baudrate!
[ 50.076277] mcp251x spi0.0 can0: bit-timing not yet defined
[ 50.076315] mcp251x spi0.0: unable to set initial baudrate!
[ 51.077533] mcp251x spi0.0 can0: bit-timing not yet defined
[ 51.077572] mcp251x spi0.0: unable to set initial baudrate!
[ 52.078792] mcp251x spi0.0 can0: bit-timing not yet defined
[ 52.078831] mcp251x spi0.0: unable to set initial baudrate!
[ 53.080058] mcp251x spi0.0 can0: bit-timing not yet defined
[ 53.080097] mcp251x spi0.0: unable to set initial baudrate!
[ 54.081316] mcp251x spi0.0 can0: bit-timing not yet defined
[ 54.081355] mcp251x spi0.0: unable to set initial baudrate!
[ 55.082571] mcp251x spi0.0 can0: bit-timing not yet defined
[ 55.082610] mcp251x spi0.0: unable to set initial baudrate!
[ 56.083826] mcp251x spi0.0 can0: bit-timing not yet defined
[ 56.083865] mcp251x spi0.0: unable to set initial baudrate!
[ 57.085082] mcp251x spi0.0 can0: bit-timing not yet defined
[ 57.085122] mcp251x spi0.0: unable to set initial baudrate!
[ 58.086347] mcp251x spi0.0 can0: bit-timing not yet defined
[ 58.086386] mcp251x spi0.0: unable to set initial baudrate!
[ 59.087603] mcp251x spi0.0 can0: bit-timing not yet defined
[ 59.087642] mcp251x spi0.0: unable to set initial baudrate!
[ 60.088862] mcp251x spi0.0 can0: bit-timing not yet defined
[ 60.088900] mcp251x spi0.0: unable to set initial baudrate!
[ 61.090138] mcp251x spi0.0 can0: bit-timing not yet defined
[ 61.090175] mcp251x spi0.0: unable to set initial baudrate!
[ 62.091395] mcp251x spi0.0 can0: bit-timing not yet defined
[ 62.091434] mcp251x spi0.0: unable to set initial baudrate!
[ 63.092648] mcp251x spi0.0 can0: bit-timing not yet defined
[ 63.092687] mcp251x spi0.0: unable to set initial baudrate!
[ 64.093904] mcp251x spi0.0 can0: bit-timing not yet defined
[ 64.093943] mcp251x spi0.0: unable to set initial baudrate!
[ 65.095162] mcp251x spi0.0 can0: bit-timing not yet defined
[ 65.095200] mcp251x spi0.0: unable to set initial baudrate!
[ 66.096408] mcp251x spi0.0 can0: bit-timing not yet defined
[ 66.096444] mcp251x spi0.0: unable to set initial baudrate!
[ 67.097655] mcp251x spi0.0 can0: bit-timing not yet defined
[ 67.097691] mcp251x spi0.0: unable to set initial baudrate!
[ 68.098917] mcp251x spi0.0 can0: bit-timing not yet defined
[ 68.098982] mcp251x spi0.0: unable to set initial baudrate!
[ 69.100185] mcp251x spi0.0 can0: bit-timing not yet defined
[ 69.100220] mcp251x spi0.0: unable to set initial baudrate!
[ 70.101419] mcp251x spi0.0 can0: bit-timing not yet defined
[ 70.101458] mcp251x spi0.0: unable to set initial baudrate!
[ 71.102675] mcp251x spi0.0 can0: bit-timing not yet defined
[ 71.102716] mcp251x spi0.0: unable to set initial baudrate!
[ 72.103935] mcp251x spi0.0 can0: bit-timing not yet defined
[ 72.103976] mcp251x spi0.0: unable to set initial baudrate!
[ 73.105193] mcp251x spi0.0 can0: bit-timing not yet defined
[ 73.105234] mcp251x spi0.0: unable to set initial baudrate!
[ 74.106453] mcp251x spi0.0 can0: bit-timing not yet defined
[ 74.106494] mcp251x spi0.0: unable to set initial baudrate!
[ 75.107715] mcp251x spi0.0 can0: bit-timing not yet defined
[ 75.107789] mcp251x spi0.0: unable to set initial baudrate!
[ 76.109010] mcp251x spi0.0 can0: bit-timing not yet defined
[ 76.109046] mcp251x spi0.0: unable to set initial baudrate!
[ 77.110245] mcp251x spi0.0 can0: bit-timing not yet defined
[ 77.110283] mcp251x spi0.0: unable to set initial baudrate!
[ 78.111486] mcp251x spi0.0 can0: bit-timing not yet defined
[ 78.111523] mcp251x spi0.0: unable to set initial baudrate!
[ 79.112723] mcp251x spi0.0 can0: bit-timing not yet defined
[ 79.112758] mcp251x spi0.0: unable to set initial baudrate!
[ 80.113966] mcp251x spi0.0 can0: bit-timing not yet defined
[ 80.114000] mcp251x spi0.0: unable to set initial baudrate!
[ 81.115211] mcp251x spi0.0 can0: bit-timing not yet defined
[ 81.115248] mcp251x spi0.0: unable to set initial baudrate!
[ 82.116465] mcp251x spi0.0 can0: bit-timing not yet defined
[ 82.116502] mcp251x spi0.0: unable to set initial baudrate!
[ 83.117779] mcp251x spi0.0 can0: bit-timing not yet defined
[ 83.117817] mcp251x spi0.0: unable to set initial baudrate!
[ 84.119029] mcp251x spi0.0 can0: bit-timing not yet defined
[ 84.119065] mcp251x spi0.0: unable to set initial baudrate!
[ 85.120286] mcp251x spi0.0 can0: bit-timing not yet defined
[ 85.120324] mcp251x spi0.0: unable to set initial baudrate!
[ 86.121539] mcp251x spi0.0 can0: bit-timing not yet defined
[ 86.121577] mcp251x spi0.0: unable to set initial baudrate!
[ 87.122790] mcp251x spi0.0 can0: bit-timing not yet defined
[ 87.122828] mcp251x spi0.0: unable to set initial baudrate!
[ 88.124040] mcp251x spi0.0 can0: bit-timing not yet defined
[ 88.124077] mcp251x spi0.0: unable to set initial baudrate!
[ 89.125291] mcp251x spi0.0 can0: bit-timing not yet defined
[ 89.125328] mcp251x spi0.0: unable to set initial baudrate!
[ 90.126536] mcp251x spi0.0 can0: bit-timing not yet defined
[ 90.126573] mcp251x spi0.0: unable to set initial baudrate!
[ 91.127782] mcp251x spi0.0 can0: bit-timing not yet defined
[ 91.127821] mcp251x spi0.0: unable to set initial baudrate!
[ 92.129038] mcp251x spi0.0 can0: bit-timing not yet defined
[ 92.129077] mcp251x spi0.0: unable to set initial baudrate!
[ 93.130294] mcp251x spi0.0 can0: bit-timing not yet defined
[ 93.130333] mcp251x spi0.0: unable to set initial baudrate!
[ 94.131578] mcp251x spi0.0 can0: bit-timing not yet defined
[ 94.131616] mcp251x spi0.0: unable to set initial baudrate!
[ 95.132835] mcp251x spi0.0 can0: bit-timing not yet defined
[ 95.132871] mcp251x spi0.0: unable to set initial baudrate!
[ 96.134086] mcp251x spi0.0 can0: bit-timing not yet defined
[ 96.134124] mcp251x spi0.0: unable to set initial baudrate!
[ 97.135334] mcp251x spi0.0 can0: bit-timing not yet defined
[ 97.135372] mcp251x spi0.0: unable to set initial baudrate!
[ 98.136590] mcp251x spi0.0 can0: bit-timing not yet defined
[ 98.136630] mcp251x spi0.0: unable to set initial baudrate!
[ 99.137840] mcp251x spi0.0 can0: bit-timing not yet defined
[ 99.137881] mcp251x spi0.0: unable to set initial baudrate!
[ 100.139100] mcp251x spi0.0 can0: bit-timing not yet defined
[ 100.139140] mcp251x spi0.0: unable to set initial baudrate!
[ 101.140357] mcp251x spi0.0 can0: bit-timing not yet defined
[ 101.140398] mcp251x spi0.0: unable to set initial baudrate!
[ 102.141624] mcp251x spi0.0 can0: bit-timing not yet defined
[ 102.141664] mcp251x spi0.0: unable to set initial baudrate!
[ 103.143018] mcp251x spi0.0 can0: bit-timing not yet defined
[ 103.143059] mcp251x spi0.0: unable to set initial baudrate!
[ 104.144273] mcp251x spi0.0 can0: bit-timing not yet defined
[ 104.144313] mcp251x spi0.0: unable to set initial baudrate!
[ 105.145524] mcp251x spi0.0 can0: bit-timing not yet defined
[ 105.145560] mcp251x spi0.0: unable to set initial baudrate!
[ 106.146773] mcp251x spi0.0 can0: bit-timing not yet defined
[ 106.146810] mcp251x spi0.0: unable to set initial baudrate!
[ 107.148028] mcp251x spi0.0 can0: bit-timing not yet defined
[ 107.148065] mcp251x spi0.0: unable to set initial baudrate!
[ 108.149282] mcp251x spi0.0 can0: bit-timing not yet defined
[ 108.149319] mcp251x spi0.0: unable to set initial baudrate!
[ 109.150521] mcp251x spi0.0 can0: bit-timing not yet defined
[ 109.150555] mcp251x spi0.0: unable to set initial baudrate!
[ 110.151758] mcp251x spi0.0 can0: bit-timing not yet defined
[ 110.151791] mcp251x spi0.0: unable to set initial baudrate!
[ 111.152990] mcp251x spi0.0 can0: bit-timing not yet defined
[ 111.153028] mcp251x spi0.0: unable to set initial baudrate!
[ 112.154224] mcp251x spi0.0 can0: bit-timing not yet defined
[ 112.154257] mcp251x spi0.0: unable to set initial baudrate!
[ 113.155589] mcp251x spi0.0 can0: bit-timing not yet defined
[ 113.155623] mcp251x spi0.0: unable to set initial baudrate!
-Ethan
