hippy
Re: Gert's VGA add-on for the B+
Thu Sep 11, 2014 5:56 pm
jojopi wrote:On Model A/B Rev1, GPIO2/3 (V/H sync) are only available on the camera connector...
Ah yes, that's a change I'd forgotten about. Thanks. Should be okay though for Rev 2 A/B ...
http://www.raspberrypi-spy.co.uk/2012/0 ... -and-pins/
Gert van Loo
Thu Sep 11, 2014 6:02 pm
... reason to deep-dive into the Broadcomm docs
I did not say Broadcom docs. I said 'manual'....
mikronauts
Thu Sep 11, 2014 6:03 pm
oops!
Thanks for the correction, it will save me a lot of time looking in the wrong place.
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
ceteras
Thu Sep 11, 2014 6:21 pm
Gert van Loo wrote: There is no need for specific driver support. As all the pins are driven by hardware the signals ARE already present.
They just don't come out until you set the GPIO pins to DPI mode.
Now if you read the manual very carefully you should be able to find out how to get these signals out.
Hint: look at the installation section and at all the files present on github.
jdb wrote:As a manual workaround, use a GPIO-poking interface (wiringpi or similar) to directly set GPIO0 and GPIO1 to ALT2 to gain access to PCLK and DE.
Thank you!
The next thing is finding out how to set this up as early as possible in the boot process.
This is a very exciting way to get the older people (like me) to start reading and actually learning something!
jojopi
Thu Sep 11, 2014 7:44 pm
jojopi wrote:… only available on the camera connector, and on Rev2 GPIO21 (red7) is. So even 8 colour mode is difficult to wire.
I had not read the documentation. Using dpi_output_format=6, red7 can be moved to GPIO25, and then 8 colour mode presents no wiring difficulty on a Model A/B Rev2.
Better still, with board modification to free GPIO16 and GPIO6 (which can be remapped in the device tree), the four most significant bits are available for all three guns. So 4096 colours would appear to be possible without having to write non-standard data in the framebuffer.
Does hvs_set_dither work on the DPI peripheral? Would it be technically possible to extend it to support dithering to 4:4:4 bits?
redhawk
Thu Sep 11, 2014 8:41 pm
Would it be possible to convert this adapter to generate a composite video signal at 1vpp with a 50Hz retrace signal??
I am aware of the colour limitation but I would like to explore the possibility of drawing pixels in the VBI region and if genlock was possible mix / overlay this with the composite video port.
Basically I want to simulate the teletext service on my Pi and maybe add subtitles to video clips so they be recorded to S-VHS tape rather than putting the text over the frames. :)
Richard S.
mikronauts
Fri Sep 12, 2014 4:55 am
I've posted a couple of pics of my hand-wired prototype work-in-progress, and will blog about my build experience at:
http://www.mikronauts.com/raspberry-pi/ ... del-bplus/
I hope to see VGA output RSN!
mikronauts
Mon Sep 15, 2014 1:28 am
Update:
So far, I have 11 boards spoken for (7 for me, 4 for others)
If I order:
20 boards, I'll have to charge $5-$6 USD + s/h per bare board not to lose money
50 boards, I'll have to charge $4-$5USD + s/h per bare board not to lose money
100 boards, I'll have to charge $2-$3 USD + s/h per bare board not to lose money
I'll take the risk for carrying some stock - say 50 boards - but I'd really like to know that I won't be stuck with 89 boards, so if you want some, please speak up!
Note: at above prices I am not charging my time for filling orders etc
ceteras
Tue Sep 16, 2014 5:20 pm
Is there a way to set up the resolution on DPI port to custom values, such as 480x272, for using with a smaller LCD screen?
dom
Tue Sep 16, 2014 5:32 pm
ceteras wrote:Is there a way to set up the resolution on DPI port to custom values, such as 480x272, for using with a smaller LCD screen?
In theory. Start here:
http://jp.raspberrypi.org/forums/viewto ... 29&t=24679
If you set up a custom hdmi mode, then use:
dpi_group=2
dpi_mode=87
it will use the custom hdmi timings for DPI.
You may need a datasheet for the display to determine the timings required, although starting with the CVT settings may get you an image is the display is happy with that.
Burngate
Wed Sep 17, 2014 10:46 am
Just as an aside, what does DPI stand for? Google points me at http://www.dpi.state.wi.us/ but I'm not sure that's relevant
ceteras
Wed Sep 17, 2014 11:01 am
I believe it's Display Parallel Interface.
Wed Sep 17, 2014 11:02 am
Burngate wrote:Just as an aside, what does DPI stand for? Google points me at http://www.dpi.state.wi.us/ but I'm not sure that's relevant
http://en.m.wikipedia.org/wiki/Dots_per_inch
adieu
My other Computer is an Asus CS10 ChromeBit
Wed Sep 17, 2014 11:04 am
Did you mean DSI :?: :?:
http://en.m.wikipedia.org/wiki/Display_Serial_Interface
adieu
dom
Wed Sep 17, 2014 11:18 am
fruitoftheloom wrote:Did you mean DSI :?: :?:
No, as certeras said it is "Display Parallel Interface". Like DSI but simpler by using more pins.
hippy
Wed Sep 17, 2014 11:45 am
Yet Broadcom seem to think "DPI" means "display pixel interface", and that matches with MIPI DPI. Whatever it's called there doesn't seem to be a lot of detail in the public domain on the SoC hardware.
http://www.broadcom.com/press/glossary.php?index=D
ceteras
Wed Sep 17, 2014 12:13 pm
If DSI is display serial interface, it only makes sense for DPI to be "parallel"...
Anyway, you don't really find out anything about its existence any way you look it up in the internet.
dom
Wed Sep 17, 2014 2:42 pm
hippy wrote:Yet Broadcom seem to think "DPI" means "display pixel interface", and that matches with MIPI DPI. Whatever it's called there doesn't seem to be a lot of detail in the public domain on the SoC hardware.
I think this is right. I've checked the peripheral spec and it just refers to "DPI" - no mention of "display parallel" or "display pixel".
The internet has very few references to either. I believe we are compatible with MIPI DPI, and they do call it "display pixel interface".
I think I'll just stick to calling it DPI and DSI, with the former needing lots of pins due to its parallel nature, and the latter using fewer pins due to its serial nature...
ShiftPlusOne
Wed Sep 17, 2014 2:47 pm
"Display Parallel Interface" according to the internal documentation.
Burngate
Thu Sep 18, 2014 11:25 am
Thankyou for that.
Either makes sense, though parallel is aesthetically more pleasing to me.
I'm now wondering what else is hidden in the green <reserved> boxes, and how they might differ from the <internal> ones
ShiftPlusOne
Thu Sep 18, 2014 11:30 am
Burngate wrote:Thankyou for that.
Gordon did say in an interview that there's some documentation that's in the pipeline for release, but who knows how long that will take.
TonyD
Thu Sep 18, 2014 11:54 am
ShiftPlusOne wrote:..
I hope they release some documentation on the "secondary memory interface".
Tony
Gert van Loo
Thu Sep 18, 2014 12:04 pm
I did not document the DPI or the SMI as a the time they could not be used due to a severe lack of available pins.
There was never any 'secrecy' about these interfaces.
It was more 'what can I do in the limited time allocated: the important interfaces first'.
We now have a lot more pins on the B+ and there are now people working full-time on the PI
so I assume the details will appear in due time.
mikronauts
Thu Sep 18, 2014 2:08 pm
Gert,
I really appreciate your efforts in getting more features documented.
DPI is already giving me a lot of ideas, and I am sure SMI will as well.
Gert van Loo wrote:I did not document the DPI or the SMI as a the time they could not be used due to a severe lack of available pins.
mahjongg
Thu Sep 18, 2014 4:24 pm
I'm very curious as to what the secondary memory interface is good for. I noticed it has a wide data bus, but only a few address lines, so it it for some kind of paged block mode flash device, like a K9K2G16Q0M, or for some kind of FIFO RAM?
Or something else altogether.
Is it possible to add a fast swap mechanism (virtual memory) using it?
Or, I'm speculating even more, for a SATA interface....
