fruitoftheloom wrote:sarf2k4 wrote:fruitoftheloom wrote:Xsane is the program used for Scanning and can scan to print, the only way to find out whether the speed and usability are acceptable is to try it.
Would recommend standalone Raspbian Wheezy Operating System, you can run headless via SSH / VNC, but you will need internet access to download / install software from the software repositories.
Getting raspi almost like a huge gamble for me
especially for my small printing store actually. Gonna need an hdmi to vga dongle and that probably gonna cost me usd$70 for the main board+8gb noobs loaded, hdmi to vga dongle, raspi case, not to mention that I need to add in an extra cash for good quality usb hub.
Sorry for going off-topic and rants above even though this thread is started by me. I wouldn't worry too much about raspi requiring internet access because I could bring the raspi to a place with internet access to download the software, xsane and cups but unsure if the driver will be included by default or need to download on demand upon connecting a new device?
By xsane, did you mean xsane.org? The latest version released was on 16th nov 2010
If you put the RPi on an internet enabled network you will not need to buy anything else, you can run it from another computer, ie headless
The RPi B+ has 4 USB ports and it should be able to cope with a USb powered scanner if that is what you have ?
You appear to be making life difficult, all you need to spend is $50.00 for a RPi and a SD Card, if it not suitable sell it
Unike Windows Software where one size fits all, Linux Software is often compiled by the Distribution, so the dates of release are irrelevent. ....
Haha.... yeah, I could sell it off but I also planned to use it as my own personal webserver and if I can't I just keep it for something else. 4 usb is enough actually but no more ports to plug in another usb storage for printing locally. My store doesn't have internet or computer network for local, printing from another computer would just mean I better off with that computer to print and scan on that document directly
. one of my aim is to reduce physical space usage and reduce pc downtime maintenance.
The hardware that are connected to my current full size pc are keyboard, mouse, scanner and printer, each take one usb slot and scanner can be powered from usb slot depending on the slot if provided enough power output, it will run with one port, if not enough another port must be plugged in.
Off-topic a little bit, I used NS2 on ubuntu several months back apparently NS2.32-2.34 can be installed in ubuntu 10.04 with an older gcc/g++ compiler. Newer compiler and newer ubuntu (12.04+) won't work with NS2 though.
I am still newbie on linux system
But thank you for your info, seems like most people would recommend a printer server compared to local print host
